Previous in Blog: The Line Illusion (September 2026 Challenge Question)   Next in Blog: Odometer Delight (Oct. 2026 Challenge Question)
3 comments
Breaking up a horseshoe (Oct. 2026 Challenge Question)
Posted October 01, 2026 12:00 AM
You have this iron horseshoe. You are also a talented machinist.
1. Can you cut this horseshoe into 6 different pieces, using two straight cuts, without repositioning the workpieces?
2. Can you cut this horseshoe into 6 different pieces - each piece with a hole - using two straight cuts? Yes, you can reposition the workpieces.
Answer, updated 10.22.26
@Rixter gets it in comments No. 1 and 2.
5
Re: Breaking up a horseshoe (Oct. 2026 Challenge Question)
10/01/2026 10:37 AM
Here's the first part...
Reply Good Answer (Score 5)
6
10/01/2026 10:51 AM
Make cut1.
Rotate bottom piece 90 degrees and move it between the two top pieces
Make cut2 across all three pieces between the holes.
Reply Good Answer (Score 6)
10/01/2026 11:22 PM
I can get 8 pieces with 3 cuts and no holes.
