Quality Control Blog
Quality Control
The Quality Control Blog is the place for conversation and discussion about product inspection technology, quality control methods & software, quality standards and compliance testing, defect prevention analysis. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Electrical Safety Audit   Next in Blog: Power conditioning
17 comments
Switchgear layout and location
Posted September 26, 2006 11:00 AM by nvmani
Pathfinder Tags: Layouts
Switchgear layout and location shall satisfy following minimum requirements:- 1.Locating switchgear near the load: 2.Access for installation,operation,and maintenance / repairs: 3.Sufficient space at front to withdraw switchtrucks,at the rear for cable terminations: 4.Weather,dust,vermin proofness: 5.Appropriate to hazardous area classification: 6.Well ventilated, to avoid excessive temperature: 7.Avoid corrosive environment:
Re: Switchgear layout and location
10/03/2006 12:21 PM
Sir
The points enumerated take care of the issue fully however future expansion might also be looked into,while deciding the switchgear layout.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member Technical Fields - Technical Writing - New Member Engineering Fields - Construction Engineering - New Member India - Member - New Member Engineering Fields - Nanoengineering - New Member Safety - Hazmat - New Member
10/06/2006 9:34 AM
Very well stated.
Future expansion should also definitely be considered.
Thank you.
nvmani
02/13/2007 7:01 AM
Ingress protection rating?
02/14/2007 8:03 AM
Ingress protection rating is essential cosideration for outdoor installations.
nvmani
01/18/2008 2:13 AM
Dear sir,
This is Coco lee with China Hope Electrical Alloy Co.ltd.
Pls check the following information,could you help me transfer to your purchasing&technologe department. Thanks in advance.
China-Hope Electrical Alloy Co.ltd can offer: bimetal contact rivet, contact sheet, powder metallurgy rivet, different type contact rivet, silver alloy wire, fiber silver graphite, alloy strip, welding material, contact component and copper based alloy etc. Now it has more than 120 types of products, more than 2000 specifications, the annual aggregate yields are 600 ton. Used for widely used in high -low voltage appliance, electron, motorcar, communication, navigation, aviation and war industry etc.
For mor information about our products&company, pls check our website: www.longsun.cc
Any questiones or assistanence,pls contact me free time!I will pay special attention.
Sinercely hope to have the chance to cooperate with you in the near future.
Looking forward your inquiry&business!
Best wishes,
Coco lee
SHANGHAI CHINA-HOPE Electrical ALLOY CO. LTD
Coco Lee
Email: coco@longsun.cc
Msn : cocochina-hope@hotmail.com
Phone No:. :86 21-57661222-8063
Direct No :86 21-57663172
Fax No. :86 21-57661521
Website: http://www.longsun.cc
Address: No 2098 Shetiankun Road ,Songjiang District , Shanghai, China.
11/13/2006 4:25 AM
Will you please tell me that 125A air circuit breakers are available for L.T Panels
02/05/2007 11:59 PM
2 hour fire rated wall enclosure and "B" lable rated doors. Room can be mechanically ventilated based on 3% of the total KW load. KW (3415) / 20 (1.08) = EXHAUST CFM.
Fire Alarm device, smoke detector installed in room above switchgear. Any wall penetrations for ducted ventilation shall have a fire damper installed.
(KISS) Keep it simple, stupid
02/14/2007 8:06 AM
Quite useful suggestions and need to be considered as well.
nvmani
03/22/2007 3:17 AM
Hello Sir,
Sir can u please give me a layput drawing, so that i can study how to locate the switch gears in the layout, for example: 1 how to locate the 3-Phase sockets in the layout, near the Equipments, Telephone points, DATA Points, Single phase sockets, CFL Fixtures, Switch locations and many more
Sir please tell me how to represent above mentioned item in the Plant layout, sir i need with symbols..
I hope u will do the need full.
Thanking u
My E-mail id is
mcgan007is@hotmail.com
thank you .
Regards
Gangadhar.M.C
04/07/2007 1:48 AM
Dear Sir,
It is better to consider the cost/sqft also during the design as real estate prices going HIGH &HIGH.
Regards,
Hareesha
Nothing is impossible, Impossible is nothing
04/15/2007 11:12 AM
You are right .
The system in India is yet to acknowledge this factor .
The Architects , Electrical Consultants & End Users are , on an average , are not giving due weightage for this factor .
There are solutions available , even indigenously , like the D Pan of L & T Make .
RK
04/16/2007 2:34 AM
sir
please can you tell me that why we usually use LA's near to the transformers only
is there any specific reason?
if so please make me clear
priyanka
04/17/2007 10:56 PM
I assume LA means Lightening arrestors.
It is protection provided for the transformer (more of) if it is an outdoor transformer
05/30/2007 7:46 AM
lightning arrestors are used to protect electrical equipments such as transformer, transmission lines,etc..from lightning stroke which causes undesirable effect in transformer operation or may cause burning effect also it can damage all appliances which are connected to it.
you can directly contact me at
shrikantr@adityabirla.com OR shrikantramtekkar@yahoo.co.in
regards
shrikant Ramtekkar
Safety - ESD - New Member India - Member - New Member Engineering Fields - Energy Engineering - New Member
Good Answers: 42
05/11/2007 12:48 AM
The minimum requirements of switchgear layout and location are well briefed. I would like to add that design factor will change depending on the voltage range of switcher vis 0.44 KV , 11KV , 33 KV ,132 KV etc.and type of transformer used ( Dry type or OFT). Hazardous area classification will have to be strictly followed in case of installations handling Explosives / chemicals
06/07/2009 9:51 PM
Hello Sir,
This is lory from China Songfa Alloy Material CO.
Songfa alloy company can offer the exact contact rivets for the switch gear. Any questions, please feel free to contact with me or visit our website.
We have been in this fields more then 20 years, we have won good reputation from our customers: Panasonic, GM(China), Mutsubishi, Sharp, Abb and so on.
Please feel free to send me the drawing or sample, we would like to do something for you and offer you the free sample for your test and comparation.
Best Regards
lory
2009-06-08
Export Manager Web: www.china-songfa.com E-mail: sales1@china-songfa.com Ph: 86-21-67763074 Fax: 86-21-67891183 Mob: 86-13472642466 MSN: loyrial125@hotmail.com Skype: loyrial125 Add: No. 155, Red Peony Road, Xinbang Industry Zone, Songjiang, Shanghai, China
07/24/2010 7:19 AM
Thanks admin nice post dizi izle
Anonymous Poster (6); hara143 (2); K.Priyanka (1); nvmani (3); PWSlack (1); Shaleshwar Rana (1); shrikant ramtekkar (1); TLGEngrCo (1); V.I.Abraham (1)
You might be interested in: Panelboards and Switchgear, Cable Bus Systems
