Previous in Blog: Doing Square Roots in Your Head?   Next in Blog: Take Mentoring to the Max
Right References Ring True
Posted October 05, 2007 8:36 AM
Smart employers check references, and smart job applicants should make best use of their references by following guidelines laid down in this UCIrvine Paul Merage School of Business article. Key tips are to think strategically about reference choices, consider different reference categories, inform your references, and enlighten them as needed.
The preceding article is a "sneak peek" from Power Generation, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Power Generation today.
Re: Right References Ring True
10/05/2007 11:49 AM
Very good advice,
On the other side of the interview, having operated a business, due to one bad experience I had an employee that claimed to have writtten an spreadsheet program for doing cost anylses for quoting and examples of OEM equipment he design claiming that it was a work of art.
I knew of that piece, what I should have done was follow through since he brought it up was to have called the customer, of which was one of my customers.
Found out after hiring him that alot of his equipment that he designed was not performing, (it was junk) and as far as the program he claimed to have written. Later uncovered that he plagaized it from the true author. (He claimed it becaused it worked, he had very little work he called his own that performed)
He just kept moving on before things when critical, and took with him the items that were handy or worked. And than calling it his own creation. Just a matter of time, when he runs out of places.
If an prospect employee gives and open example, follow through with inquires.
