HVAC Blog Blog
HVAC Blog
Previous in Blog: What's Your IAQ/IEQ?   Next in Blog: HVAC Tuning – Cool Savings or Hot Air
8 comments
On Demand Ventilation
Posted November 11, 2007 8:21 AM
In operating commercial HVAC systems, every bit of outside air channeled into a building must either be heated or cooled, depending upon the season. The obvious energy saving solution is to cut the amount of outside air used. But reducing outside air intake puts a serious damper on a building's IAQ. One approach to lowering HVAC energy usage is called Demand Ventilation. Used primarily in commercial construction, this HVAC design method provides for outside air to be pumped directly into populated interior spaces, but limits airflow to unpopulated areas. Maybe the key is eliminating the unnecessary use of ventilation air, but it does provide a significant cost savings. Can Demand Ventillation save energy?
Re: On Demand Ventilation
11/11/2007 9:26 PM
For space heating; would it be possible to preheat the air using solar arrays on the roof? Could these same arrays also serve to "shade" the collecting area in the summer reducing solar heat gain?
For cooling: What is being done with the air conditioning condensate? Could it be used to cool the intake air during the summer through evaporative cooling? Or used to increase the efficiency of the heat dissipation? If the condensate is misted or allowed to evaporate into the heat exchange feed air would it increase the thermal conductivity and thermal capacitance of the air passing over the fins? (By fins, I mean the metal used to dissipate the heat into the atmosphere.)
Gavilan
11/12/2007 4:16 AM
Good point..It seems to me that HVAC is incredibly crude.
They throw up buildings in short order with little insulation and less thought. Then just throw money at it trying to keep it warm or cool! The whole thing need planing at trick one.
Then in the UK if you try and build anything that doesn't look like a 1950's house a load of dim witted locals moan that it's 'not in character'... see if it's 'in character' when the North Sea sweeps 'em out of their complacent Nimby suburban smugness.... Oh yes they'll be laughing on the other side of their faces when they are paddling their bath like a canoe above the flooded remains of their 4x4 ...
(Ah..I needed that )
11/12/2007 7:31 AM
Sounds like KrisDelTM missed out on a significant business opportunity around 9th November whan a large hammer swung and made its first contact....
11/13/2007 9:08 PM
Sure its possible and has been done, but not necessarily with a reasonable payback. That's the big problem with solar, big investment, big maintenance, and long payback. Buildings requiring ventilation need it all the time, not just when the sun is shining.
This has been done for years on small window A/C units. A slinger ring around the condenser fan drops into a sunken portion of the AC unit's platform where the condensate runs. The slinger ring picks it up and throws it on the condenser, excess can then drip out the back.
Larger A/C systems could possibly benefit from it but by the time it was implemented, it would be more of a nuisance than it was worth, otherwise, the manufacturer's would have been doing it long ago. They don't even do that on any commercial rooftop units.
New advances in Air Conditioning efficiency come from better lubricating oils, high tech metals with less friction and better heat transfer, thinner walled copper and thinner fins ( less durable though ) And of course variable speed technologies.
Maintenance is already painfully high on mist or steam type humidifiers using pure potable water that's been run through an additional filter, compare that to skanky condensate dripped from a filthy evaporator coil. How would you like to dip your tongue down in an evaporator drainpan? Just imagine how long your spray nozzles would work. You'd also be poisoning the building occupants with air-borne bacterias etc.
Unless you're the lead dog on the sled, the view is always the same....
United Kingdom - Member - New Member Engineering Fields - Energy Engineering - New Member Engineering Fields - Piping Design Engineering - New Member Fans of Old Computers - Commodore 64 - New Member Technical Fields - Technical Writing - New Member
11/12/2007 11:11 AM
Could the future be CCHP
http://en.wikipedia.org/wiki/Trigeneration
Deseng
Those who believe in telekinetics, raise my hand - Kurt Vonnegut
11/13/2007 9:15 PM
I installed a small fan connected to a fresh air grille and ducted it up to a dedicated AC air handler in a school classroom where there were 33 computers (classroom training). The fan was controlled by a CO2 monitor. It works great! My son is the teacher at this high school and he hears the little fan kick on intermittently about 15 minutes after class begins.
The trouble is, the "el-cheapo" CO2 monitors have a limited life span and require re-calibrating. This one is in a year and still working like "day-one".
11/14/2007 2:58 AM
Hey I lick the CO2 monitoring concept...I've not heard of that before.
It could be usefull...Mrs Cat insists on having the bedroom windows open all night ans it's Bloody Freezing. Maybe it's another project beckoning?
11/14/2007 9:27 PM
There you go Del, just don't be doing anything to cause anyone to breathe heavy, thereby kicking in the CO2 fan, and you'll save plenty....hehe....
design-engineer (1); Gavilan (1); PWSlack (1); Sniccus (3); user-deleted-1105 (2)
