HVAC Blog Blog
HVAC Blog
Previous in Blog: Sick Building Syndrome   Next in Blog: The High Costs of HVAC Dependency
6 comments
Schools Educated in Humidity Control
Posted December 11, 2007 8:20 AM by Sharkles
It's December and it's cold. The nation's schools feel the impact of expending heating energy and simultaneously attempting to provide the safest carbon neutral IAQ possible. How can academic facilities improve heating energy efficiency? One way is to eliminate the need for running HVAC systems at full bore. What other ideas can you offer?
Re: Schools Educated in Humidity Control
12/15/2007 1:39 AM
Even though the technology is NOT new, air-to-air heat exchangers I believe are an excellent way to save money on ventilation air, but few schools have embraced this idea.
Kids get sick so quickly in schools and the majority of schools I believe, do NOT have adequate or even state / federal minimum standards for fresh air.
These heat exchangers save big $$ in operating costs and run a long time IF properly maintained.
These things will become a higher priority as fuel costs rise.
Unless you're the lead dog on the sled, the view is always the same....
12/19/2007 9:32 PM
Schools have windows which are to take-in and to throw-away energy, at the same
as to have good view.
I propose everybody to consider "SOLAR BLINDS" to save heating energy, and
during the summer time to save energy for cooling classrooms.
SOLAR-BLINDS are available in USA, made in USA, and not know to many people
yet.
If you are serious to save energy through windows, please contact Richard
at 858-752-6140.
12/29/2007 11:06 PM
Sounds to me like you're making a sales pitch for your solar blinds. I don't think this CR4 forum is for marketing.
12/20/2007 2:57 PM
In humid areas of the country, after hours humidity control is more important than temperature control. Generally speaking, humidity control requires about one building air change per hour, while temperature control uses about six air changes per hour. An energy efficient mechanical dehumidifier uses 75% less power than running an air conditioning system. By installing a humidistat, the dehumidifier cycles off and on as needed for humidity control. The main air conditioner would not even be needed during overnight and weekend hours, unless called for to provide comfort to school staff.
12/29/2007 11:20 PM
Is this a new dehumidification process or is 75% a little exaggerated? It is a good idea though. After hours internal gains should presumably be mostly sensible as the outdoor air should be minimized thereby saving THAT load. And it is not good to let moisture permeate a building during un-occ period
Its been my experience that most school's HVAC systems are NOT closely monitored or controlled for best operation and cost savings. They run things till they break because of budget constraints.
Newer buildings with automation are much better controlled.
12/30/2007 8:39 PM
The 75% energy reduction with the mechanical dehumidifier should be fairly accurate. Normal air conditioning requires about six to eight times as much air flow as dehumidifiying with refrigeration.
Anonymous Poster (1); DrycoTom (2); Sniccus (3)
You might be interested in: HVAC Ductwork, HVAC Services, Heating Furnaces
