Workbench Creations Blog
Workbench Creations
Previous in Blog: FIRST Robotics Game Clue   Next in Blog: DIY Oxy-Acetylene Profile Cutter
5 comments
DIY Chimney Cabinet
Posted January 02, 2008 12:01 AM by Steve Melito
Pathfinder Tags: DIY blog DIY projects
Editor's Note: CR4 would like to thank Andy Germany for sharing this DIY story and pictures. Recht schönen Dank!, Andy.
Here is a "halfway" picture of a built-in cupboard that I made a few years ago to go on the sides of a chimney which divides a wall unevenly, and that once made the space on either side of unusable. I used what we call OSB boards, which are made of wood shavings instead of chips.
Here is a picture of my completed chimney cabinet. To speed up the work, I used some ready-made pine doors. I also decided to include an open area as a sort of "display cabinet" that my wife could use. It has small T5 fluorescent tubes for lighting. From time to time, she changes the display to something else. Although she is displaying photos now, this is picture is from 4 years ago, when the display cabinet housed China cups. Note how the solid part of the structure hides the old chimney breast completely.
This unit was made of 15-mm OSB, screwed together, filled and painted. All of the shelves can handle my full weight without creaking or movement. Since this photo was taken, I have varnished the doors to darken them down a shade, and to match the dining room suite.
This project took about 3 weeks of part-time building. All major and a lot of minor parts were cut at the shop to cut (no pun intended) on the work I needed to do at home, and to get all edges exactly at 90°. In the end, it went together like a pre-cut kit!
I did make exact drawings (first one, then several) until we were happy with the design. I have a drawing board at home that I use for such things. It saves time in the end. Once the basic drawings are finished and scanned, I can make changes on my PC pretty quickly. I recommend that method, as the final job was exactly the same as the final drawings.
Editor's Note: Do you have a DIY story to share with CR4? If so, please message Moose or frankd20. We'd like to hear from you!
Re: DIY Chimney Cabinet
01/03/2008 8:34 AM
Hi Moose.
What is so new about this?????????????????????????????????????????????????????????
In England the Victorians did this to all of their chimmeny breasts!!!
Spencer.
01/03/2008 3:55 PM
Hello Scapolie,
The "newness" of a project isn't a requirement for inclusion in the Workbench Creations blog. Instead, our goal here is to highlight the work of those CR4ers who have do-it-yourself projects under their proverbial belts. Say, do you have any projects that you might like to write up for us?
Moose
01/03/2008 9:23 AM
Something equivalent has just been completed in the bothy, though in a more traditional "village carpenter" style appropriate to the building, and without lighting.
The space between the chimney breast and an interior wall, less an allowance for the frame and divided in two, gave a non-standard door size (in the UK, standard interior doors are 2ft 6in x 6ft 6in, or whatever that is in the new-fangled metric) and so required two custom-size doors assembled from what is called "siding" here, i.e. best quality tounge-and-groove edged pine plank 45/8in wide x 13/16in thick with one side smooth and double-bevelled 1/8in. Inside the cupboard space is a framework built in-situ from four pieces of oak plank left over from another project, covered with decorative coat hooks. A couple of decorative hinges and a couple of catches from the same local ironmonger (they are getting few and far between) finished it off. Now, when the stove is on and the chimney is warm, all the coats in the new cupboard become warm and dry. It looks right for the building, too.
That O-level in Woodwork has come in handy after all.......
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
01/03/2008 2:44 PM
Hehe ... it's words like ironmonger and tinker that make me miss my time across the pond. So Olde World. Makes me wanna throw back a flagon of mead!
I used to live down the road from an olde Saxon wall build in AD 800, in Shaftesbury. Currently I live down the road from the OK Corral which is famous from the 1880's. And that's what we call old! It's funny how relative a term the word "old" is.
01/03/2008 4:08 PM
Hi Out of Box.
I visited Tombstone and the surrounding area way back in 1998, I had been to visit the Tuscon mineral fair and I decided to hire an RV and travel south in Arizona. I can still remember sitting in Big Nose Kates saloon quaffing beer, and I still have my copy of the Epitaph. Great place Arizona.
Spencer.
Out of Box Experience (1); PWSlack (1); Scapolie (2); Steve Melito (1)
