Workbench Creations Blog
Workbench Creations
Previous in Blog: DIY Solar Hot Water Panels   Next in Blog: Animation Render Farm
6 comments
Fixing a Broken Laptop
Posted February 27, 2008 12:00 AM by frankd20
Pathfinder Tags: laptop power connector repair
I have encountered many an older laptop with the same simple technical problem, the damn power connector has come lose from the board. In this case, the laptop belonged to a co-worker who brought it in and began taking it apart.
Having done this same procedure on a few laptops in the past, I jumped right in. I have found two things with taking apart electronics, particularly laptops. The first is that the manufacturers are damn good at hiding screws. The second rule of thumb for taking apart laptops is don't force anything.
With the laptops I have taken apart, I find that you unscrew everything you can see on the bottom with the expectation that it will come off, but it doesn't. You then flip the laptop over and find the hidden cover on the keyboard side. This cover comes off along with the screws under it, as well as any that may be under the keyboard. After you disconnect a few ribbon cables, it's often the top of the laptop that comes off and not the bottom. This particular laptop wasn't much different and it turned out that the motherboard was mounted to the bottom, not the top as it first appears.
After taking out the motherboard, I was able to put a few dabs of solder on the power connector to secure it in place. It really didn't look bad, but all it takes is a small crack in the solder, which can be very hard to see.
After soldering, we re-assembled the laptop. I connected the few ribbon connectors and left the countless screws for the laptop owner to put back in. Luckily, at the end there were no spare screws and everything seemed to go back into place. We connected the power, pressed the button, and waited for the moment of truth…success!
Re: Fixing a Broken Laptop
02/27/2008 4:41 AM
NO SPARE SCREWS!
That can't be right...I'm sure we can all send you a few
And if they can't be repaired they are pretty effective as body armour...they stop arrows quite nicely
Good Answers: 70
02/27/2008 10:52 PM
This does seem to be the most common cause of death in laptops. What a ridiculous design flaw - to use solder as a strain relief! It would be so easy to have the power input socket mechanically attached to the laptop case, with two wires running from the socket contacts to two pins on the motherboard, but nooo. The additional cost would probably be less than $1.00!
Canada - Member - New Member
Good Answers: 11
02/28/2008 8:46 AM
Same reasoning applies to MP3's audio jacks. $1x1E6 units=$$$!!!
I repaired may son's Sensa twice. Last time the pcb traces were damaged, added UV acrylic glue.
Told my son to be careful, but then again, it is always fun to take things apart.
''What the hell has my a** got to do with magic?" Don Quixote
02/27/2008 11:44 PM
No spare screws? Are you sure? too bad you didn't have Guiness rep there to document it. You could be famous
Kindness knows no boundaries.
Reply Off Topic (Score 6)
02/28/2008 4:36 AM
Why do manufacturers hide screw heads. It's only going to irritate: never stop someone who wants to get in.
Reply Off Topic (Score 4)
02/28/2008 6:00 AM
This reminds me of some of my first electrical experiences as a kid. Walkmans or portable cassette players would invariably stop working and more often then not it was the headphone jack solder connection. So that was my first forray into soldering was taking apart Walkmans and resoldering the head phone jacks.
Shawn
gigaconcept.com (1); johnfotl (1); Randall (1); Shawn33 (1); Techart (1); user-deleted-1105 (1)
