Previous in Blog: Photos: Cities Go Green   Next in Blog: Superconductor Electric Vehicle
3 comments
Solar Soft House Converts Household Curtains into Household Current
Posted June 12, 2008 8:24 AM
From Engadget:
Filed under: Household Bravo Sheila Kennedy, bravo. You might just save us from our gadget-obsessed selves if the Soft House you've designed can pump the 16,000 watt-hours you predict. The design features thin photovoltaic films woven into semi-transparent curtains. The idea is similar to the solar power ski-suits (seriously) we've seen. Unfortunately, a home fitted entirely in solar textiles is still too costly at the moment. Cost measured in cash, apparently.Read | Permalink | Email this | Comments
United States - Member - American by birth,southern by the grace of GOD Popular Science - Weaponology - you can't carry that! Technical Fields - Technical Writing - why can't I use a pencil? Hobbies - Target Shooting - New Member
Re: Solar Soft House Converts Household Curtains into Household Current
06/13/2008 11:06 AM
This would be good to add to sail boats for supplemental power. This could also be used in super hero capes to keep the utility belts charged. ( with respect to Marvel and DC comics)
The more complex the mind, the greater the need for the simplicity of play... If you think you can or think you can't you'll always be right
06/13/2008 12:52 PM
Abosolutely. We should have hundreds or thousands of sailboats, all chained together in a long loop across a body of water, and the chains holding them together will be wound around a capstan at each end, attached to a turbine to generate power. Each boat will have automatic helm and sheet control. All the sailboats on one side of the loop will be on a starboard tack and the sailboats on the other side will be on a port tack. This too will be a great way to generate power.
06/13/2008 12:59 PM
Now that would be a site to see from the air. If you could get enough boats it would look like a giant pinwheel!!
You might be interested in: Industrial Curtains, Solar Water Heaters, Solar Mounts
