Previous in Blog: Ariane 5 - Fifth launch of 2008   Next in Blog: Men claim they have body of Bigfoot
18 comments
U.S. scientists claim world record in solar cell efficiency
Posted August 15, 2008 1:49 PM
From TG Daily - All News:
Scientists at the U.S. Department of Energy's (DoE) National Renewable Energy Laboratory (NREL) claim to have set a new world record in solar cell efficiency: A new photovoltaic device can convert 40.8% of the light it is exposed to into electricity - which is more than twice as much as average solar cells can achieve today. Improving the efficiency of solar cells is a key research area in the photovoltaic segment, as current mas market solar cells are converting less than 20% of sunlight into electricity, but high-end solar cells made by Boeing-Spectrolab and used by the DoE and NASA have been approaching 40%. A new material now allowed the NREL to increase the efficiency by a few more percentage points. Instead of using a germanium wafer as the bottom junction of the device, the new design uses compositions of gallium indium phosphide and gallium indium arsenide to split the solar spectrum into three equal parts that are absorbed by each of the cell's three junctions for higher potential efficiencies. This new "inverted metamorphic triple-junction solar cell" design proved to be highly effective, hitting an efficiency of 40.8% under concentrated light of 326 suns (326 times the amount of light that hits Earth on a sunny day.) The NREL said that the solar cell is "extremely thin and light and represents a new class of solar cells with advantages in performance, design, operation and cost." Just don't expect this device to become available for the roof of your home or a future Toyota Prius anytime soon: According to the NREL, the solar cell technology will be targeting the space satellite market as well as photovoltaic arrays which are typically sued by solar cell power plants and use lenses or mirrors to focus sunlight onto the solar cells.
Re: U.S. scientists claim world record in solar cell efficiency
08/15/2008 7:39 PM
I wonder what the point is of testing them at 326 times the amount of light that hits Earth on a sunny day. What's the efficiency for real-life use?
Canada - Member - Specialized in power electronics
Good Answers: 80
08/15/2008 11:13 PM
Since the PV cell is one of the most expensive component, it makes sense to use relatively cheap mirrors to concentrate a large surface exposed to the sun onto a small PV cell. This should reduce the overall cost per KW and simplify the electrical connections.
Experienced is earned, common sense is taught, both are rare essentials of life.
08/16/2008 10:49 PM
That does make sense - kinda. 326 suns works out to about 32.6Kw per square foot. I hope they come with some big heatsinks.
08/16/2008 2:26 AM
I agree that is like the test for miles per gallon ran with 100 octane gas. Then the car dealers push those cars to the public but the public can not buy 100 octane gas anywhere. We have not been able to buy 100 octane in over 40 years.
Hobbies - Musician - New Member Hobbies - Car Customizing - New Member Hobbies - Target Shooting - New Member Engineering Fields - Power Engineering - New Member
08/18/2008 7:53 AM
"but the public can not buy 100 octane gas anywhere"
I have to disagree. There is a station here, about 15 miles fom my house, where you can buy 110 at the pump. I used to fuel up my S10 pickup there. It was $4.80 a gallon, back when regular was around $1.75/gal. Very expensive, but the truck had an 11.5:1 CR V8 so it would ping on anything less. I had to get rid of the truck a couple years back, though. So, I don't know what it goes for now, but I'm sure it's insane.
08/18/2008 11:20 AM
you live near a NASCAR or someohter race track. That is the only place they sell it on the East coast.
08/18/2008 11:46 AM
A few years back, a guy I worked with drove a '68 Camaro muscle car that took the higher grade, and he bought it at the local small craft airfield. Aviation gasoline is typically 108 Octane number or thereabouts...
08/18/2008 12:09 PM
"you live near a NASCAR or someohter race track"
Believe ot or not, there are no tracks within an hours drive. I wish like hell there was one closer. I have been told that there used to be a 1/4 or 1/8 mile drag strip, in North Melbourne (about 20mi from me) so maybe that's why the 110 is here. It closed back sometime in the early eighties. It's rumored one of the older guys I work with used to co-own it. I'll have to ask him about it sometime.
The Engineer
Good Answers: 129
08/16/2008 9:03 PM
I'm only guessing, but I would imagine it's (using 326x sun power) to get a better signal to noise ratio so they can get as accurate a measure of the efficiency as possible.
08/15/2008 11:26 PM
From other articles read:
Recent comments also said increased efficiency by cooling the solar cells, taking heat away from the cells.
Another recent comment was solar cells developed that can also work at night, the materials used to build the cells are typically used in night vision and infrared camera detectors.
Two companies are building solar power plants in California that will produce 200MW and 500MW, and they say 1MW is the typical energy consumption of a Walmart store. The utility that will buy the power prefers solar to wind, because the solar is present during the utility peak load time of day.
"I believe we are masters of our lives - we hold all the cards and it is up to us to use them right." Vesna Vulova - survived 33,000ft fall
Good Answers: 230
08/16/2008 1:49 AM
Did they allow for the energy required for the heat removal equipment, when the achieved that 40.8% efficiency?
All too often, the figures are improperly stacked up, leaving out the ones which "go against what the researchers want to say".
Kind Regards....
Popular Science - Cosmology - New Member Popular Science - Paleontology - New Member Popular Science - Weaponology - New Member Popular Science - Evolution - New Member Popular Science - Genetics - New Member Popular Science - Biology - New Member
Location: The Nevernever as much as possible, Earth when I have no choice.
Good Answers: 11
08/18/2008 11:06 PM
Good Answer, Sparkstation.
Dragon
Ignorance is the beginning of knowledge. Heresy is the beginning of wisdom. The ignorant heretic is the wisest of all.
Good Answers: 80
08/16/2008 8:38 AM
People, don't be so negative. If they tested them the same way the old technology was tested, they still improved the light conversion efficiency by 2X. Of course there will be a price to pay for the higher efficiency. At least, it is going in the right direction.
The IC engine is about 40% efficient and we use millions of them. Once you take the losses for the other systems in the car it is much lower but we still use them.
The important point here is that some people are making the conversion technology progress and eventually, PV systems will pay for themselves in a reasonable time without subsidies.
08/16/2008 10:52 AM
Yes, and hopefully before the sun puts out 326 times as much energy as today. I too am wondering what the data would show at 1 solar input vs 326 solar input. Perhaps it would still double the current average, but we have not heard that yet. Perhaps this is just DOE puffery to make us think they're doing something useful. Pardon me, but I shall retain my cloak of skepticism for a while yet...and still remain hopeful!
Good Answers: 80
08/16/2008 11:25 AM
What makes PV cells so expensive is their large size. One has to get a huge crystal with perfect structure. The yield is low, the price is high.
Their device could be made out of small chips, mounted under cheap lenses to concentrate the sun ray from 326 times the chips surface. Small chips have better yeild. It could be a neat little assembly. This would bring the PV world into the mass produced electronics. Imagine the savings...
As I said earlier, since price of the PV cell is a major component of the total cost, any technology that allow the replacement of PV by cheaper light collecting material for the same output is a winner. It is even better if they increase the efficiency along the way.
I congratulate their effort and success.
08/16/2008 11:32 AM
I do too, I just want a demonstration of practicality before I open the champagne.
Good Answers: 93
08/16/2008 1:18 PM
I'm with Marcot philosophically as I feel that the perfect is too often the enemy of the good in these discussions of Solar Energy, or other Alternative Energies to Oil and Coal, in general. At some point to my mind a thing that works, is 100 percent efficient. My comparison is the old Dutch windmill, and the Sailing ship of the 1500s. Of course it is proper to work to create a better PV cell, or a better more productive system, but this does not mean we ought not commit to the materials and systems that exist. Just like I do not have to be perfect, but only ask for forgiveness to go to heavan, our machines and technologies have only to do what we need them to do in the time we are in. As a working man of the streets exact numbers are not my forte`. If I was President of BP for instance I would turn it into an energy store taking account of the infrastructure and franchise already in place. The direction you take, is more important than the numbers.
Good Answers: 11
08/18/2008 11:10 PM
"The direction you take is more important than the numbers."
Good Answer, and very true.
Dragon
Bayes (1); bhankiii (2); CoronaCameraMan (1); dadw5boys (2); Dragonsfarm (2); EnviroMan (3); IanR (2); marcot (3); Sparkstation (1); Transcendian (1)
You might be interested in: Photovoltaic Cells, Fuel Cells
