Electrical Components Blog
Previous in Blog: Electronic Project I (Part 1) – 555 Timers   Next in Blog: Electronic Project I (Part 3) – 555 Timer with a Speaker
17 comments
Electronic Project I (Part 2) – 555 Timer with an LED
Posted September 01, 2009 12:00 AM by Jaxy
555 Timers are very fun to encounter and experiment with. They can be used as a timer and can be set to a certain frequency. Adding an LED will allow you to see the frequency. The higher the frequency, the faster the LED will blink and the lower the frequency, the slower the LED will blink.
Components and Cost Estimate
  1. 555 Timer Chip ($1.69)
  2. Resistors (Included in Radio Shack's 500-Piece Resistor Assortment - $.03 each)
    • (1) 6.8KΩ Resistor ($.03) – Blue Grey Red
  1. (1) 10k Potentiometer ($1.49)
  2. (1) .01μF Capacitor ($1.49)
  3. (1) 10μF Capacitor ($1.19)
  4. (1) LED (Included in Radio Shack's 20-LED Assortment - $.15 each)
The cost estimate comes to $6.04.
Schematic
The schematic at left will have the LED blink fast or slow depending on how far and in which direction the potentiometer is turned.
Instructional Video
I have created a step-by-step instructional video in addition to the written instructions below. It can be viewed here.
Building the 555 Timer With Blinking LED
First we will start by inserting the chip into the breadboard as shown at left. For a refresher on how to insert chips into board, see Part V. Next, make power and ground connections to the chip as shown to the right. It is typically a good habit to have red wire be exclusively power and black exclusively ground. If problems arise, you can easily pick out where power and ground is traveling.
Add the LED from pin 3 on the chip to ground. Insert the potentiometer anywhere on the board. Then wire pin 2 to pin 6 (orange wire).
The 10μF capacitor can then be connected from pin 2 or pin 6 (because they are both connected with orange wires) to ground. I used pin 2 because that side of the chip is closest to ground. Connect the .01μF capacitor from pin 5 to ground.
Connect the potentiometer to pin 6 and pin 7 (above left). Pin 6 should be should be connected to the middle pin on the potentiometer and pin 7 should be connected to one of the outer pins. The final step is to add the resistor to the circuit (below).
Now try plugging power from the 9 volt battery into the board. If the LED seems to stay lit instead of blinking, that is okay. What the LED is really doing (in most cases) is blinking so fast that it seems to just stay lit. As you turn the potentiometer, the light should blink at different speeds. Congratulations to those who accomplished this feat. If yours isn't working right away, there is a basic checklist that you should walk through before becoming too discouraged. Chances are it is only a minor issue.
Debugging Checklist
  • Is your battery good?
    • If you used an old battery, try a new one.
  • Make sure that power and ground are connected directly to the right pins on the chip.
    • Pins 4 and 8 should be connected to power.
    • Pin 1 should be connected directly to ground.
  • Double check wiring
    • Make certain that not only the components are wired correctly (it is easy to be just one row off), but also that they are inserted correctly. Capacitors and LEDs are likely culprits of not being inserted correctly as they are polarized.
  • Is a component broken?
    • Does something smell like it is burning? Is there a black area on a component? If this is the case, swap out the component and double check the value and the wiring. Something was not wired correctly to make the component break.
Tune in tomorrow to learn how to use the 555 timer to produce sound through a speaker. Most of the components you will need tomorrow, you already have in your possession from making this circuit.
Previous Blogs in Series:
Electronic Projects for Beginners – Components (Part I)
Electronic Projects for Beginners – More Components (Part II)
Electronic Projects for Beginners – Reading Components (Part III)
Electronic Projects for Beginners – Translating the Schematic onto a Breadboard (Part IV)
Electronic Projects for Beginners - Notes Concerning Chips (Part V)
Electronic Project I (Part 2) - Video
Good Answers: 213
Re: Electronic Project I (Part 2) – 555 Timer with an LED
09/02/2009 11:35 AM
It would be nice to see a little more discussion of the function of each component- i.e., the caps are apparently grounding out AC signals, but what impact does the value have? I see the voltage divider, but no discussion as to the purpose or function (i.e., what voltages should I read at each terminal?). What happens if we vary the input voltage- say 5 to 24 V? Two of the pot's pins are shorted. Why not leave the free end free and connect pins 2 and six and the cap just to the wiper?
I have built this circuit before, and it is a great way of exploring the 555 (and gaining an understanding of building circuits. What is also interesting is running these through a Spice simulator to explore various variations to the basic design, without risking blowing up your parts first (plugging polarized caps in backwards can be VERY exciting!).
Keep up the good work.
Good Answers: 25
09/03/2009 3:23 AM
Cwarner7_11
If you leave the wiper disconnected from one end of the pot and the wiper hits a speck of dust the circuit will be open instead of just the maximum pot value.
Jon
Good Answers: 213
09/03/2009 8:05 PM
Thanks. Alsways wondered why that was the standard configuration...
Good Answers: 25
09/03/2009 9:22 PM
CW,
This is especially important on 3 terminal voltage regulators that use an adjustment pot to vary output voltage. If the wiper looses contact the voltage goes to maximum.
Jon
Location: Next to the Prime Merridian (51°29'34.50"N 0°13'32.85"W)
09/04/2009 8:37 AM
Crikey!!! That looks like my BB which went for a walk about since you've started these blog projects.
Making mistake is part of learning.
09/22/2009 4:47 PM
The 555 requires 4.5V min and 5V to trigger so what changes would be needed to use 6V not 9V?
09/22/2009 6:17 PM
Off the top of my head the 555 timer in flash mode charges and discharges the cap through two resistors and the cap is charged between 1/3 to 2/3 of VCC.
The charge and discharge waveforms can be set as square, triangular nd sawtooth types with the above resistors, however, the frequency is set by the time constant of the cap and the charge resistor. If the charge resistor has to be fixed for current reason then you have to compensate for it by the cap value to achieve the desired time constant.
For serious design purpose you'd better refer to the data sheet.
I had to familiarise myself with the 555 timer's schematic during my course by heart but now, I can vaguely remember its pin configurations even.
It is a good device but I think these days learning to program a microcontroller is a much better option as they can generate so much more types of wave-forms and they do precission work/control as well as they can run from like 2v to 5v and your worries will be suddenly over.
Good Answers: 25
09/22/2009 6:27 PM
Guest,
With a 5Volt Supply the trigger Voltage is 1.67V.
Jon
09/22/2009 6:46 PM
(Formely Guest, now registered)
Hi thank you for your support. I will get components tomorrow to test. I think I'm trying to achieve a triangular wave creating a steady blink on and off, and trying to set the delay to about 2 seconds - if possible. I'll get a few 555 timers and some battery holders for my breadboard but have a zillion resistors and capacitors to test with. Once I find something that suits, I'll probably run with that though it could take some playing to get the correct delay length based on my supply voltage and space restrictions (watch sized)
Part two of the project is to add toggle switch to select a 2 second or 4 second blink.
Part three of my project is to include a 'digital' bip sound..
Amateurs built the ark, professionals built the Titanic..
Good Answers: 25
09/22/2009 6:50 PM
kodama,
Looks like you are ready.
Jon
09/22/2009 7:10 PM
Hmm.. might as well get all components. Guess I'll need a 450 - 800 Ohm Piezo Transducer for the beep? Will post my results as they develop.
Good Answers: 25
09/22/2009 7:13 PM
Kodama,
I just ran my 555 timer noise maker circuit from 3.2 to 9Volts with no change in frequency. Only a change in amplitude of the output.
Jon
Good Answers: 25
09/22/2009 7:18 PM
Kodama,
I used an 2 inch 8Ω 0.2W speaker.
Jon
09/25/2009 9:05 AM
Do you want to build a Piezo beeper from the 555 timer?
Then you have to set your CR time constant lot shorter than the chick's on youtube.
You also need to make sure to generate bursts of beeps otherwise it will be just a continuous one and I don't think you want that, do you?
09/25/2009 7:55 AM
Talk about rusty.. The close up images are very useful, but I can't decide which way round the 555 goes. With the notch/marker to my left, is pin 1 the top left? Which order do the pins run?
09/25/2009 11:06 AM
See this blog: http://cr4.globalspec.com/blogentry/9861/Electronic-Projects-for-Beginners-Notes-Concerning-Chips-Part-V
It has a picture of a 555 timer chip and discusses how to read pins on chips. Let me know if this does not clarify your questions.
09/25/2009 11:28 AM
Brilliant that - thanks very much.
Anonymous Poster (1); cwarner7_11 (2); Isti80 (3); Jaxy (1); kodama (4); kudukdweller9 (6)
You might be interested in: PIN Diodes, IC Pin Probes, Plug and Pin Gages
