Electrical Components Blog
Previous in Blog: Supercapacitors: A New Use for Paper?   Next in Blog: Electronic Projects for Beginners – More Components (Part II)
40 comments
Electronic Projects for Beginners – Components (Part I)
Posted July 21, 2009 12:00 AM by Jaxy
This series will take the most inexperienced beginner through a series of basic electrical projects. The first few blog entries go over the basics, then present projects in latter blogs for all to enjoy. These projects are tailored to help promote learning and fascination with the concepts of electronics and electricity.
What You'll Need
There are many places that sell basic electrical parts. Online is probably the best option for the most competitive prices. Make sure to read any reviews on the products being purchased; a lot of product reviews can be helpful when debating between buzzers or resistor assortments.
One of the best places to buy electrical components is Radio Shack. This is where price estimations will calculated from. Do not be limited to a singular place to buy electronics; it is always a good idea to do research to find the best deals.
Keep in mind that like everything else in stores, buying in bulk is a good way to save money, but only in the long term. When buying assortments of components, make sure they contain values that will be implemented in these projects. Many components presented in this blog can be used over and over again for different projects.
For the basic electrical projects in this series, you'll need the following parts:
  • breadboard
  • resistors and potentiometers
  • capacitors
  • light-emitting diodes (LEDs)
  • battery and battery holder
You may also want to purchase some supplemental tools (discussed in Part II).
Breadboard
One of the most basic necessities in building electrical parts is a breadboard. Breadboards come in many shapes, sizes, and colors. Binding posts are sometimes an added feature to these boards (located at the top of the picture to the right), but are not absolutely vital. They may be handy if you have your own variable power supply.
The connections on the breadboard are as shown in the picture on the left. To the left-and-right of the board are two vertical busses (in between the red and blue lines - although note that not all boards have these colorful indicators) that are electrically connected for the whole length of the board (imagine a wire connecting each and every hole vertically underneath the board); this holds true for boards that are longer.
In the center of the board you see labels a - j horizontally as well as numbers 1 - 30 vertically. The connections on this portion of the board run horizontally, but do not extend across the "trench" (the indentation between "e" and "f"). This means that 1a, 1b, 1c, 1d, and 1e are all connected beneath the board. But these connections do not connect to 1f, 1g, 1h, 1i, and 1j.
Resistors and Potentiometers
An assortment of resistors is desirable when creating circuits. Make sure that the assortment has multiples of 1kΩ, 10kΩ, and 100kΩ resistors. It also helps to have a wide variety to ensure that if a certain value is needed, but is not in the assortment, it can be "created" by using other resistors and the series / parallel rules.
Potentiometers are just a fancy name for variable resistors, meaning that the resistance value changes as it is turned. It is suggested that potentiometers should be bought as the projects are presented, but 1kΩ, 10kΩ, and 100kΩ potentiometers are most useful in circuit projects.
There are many different potentiometers to choose from. Some take many more turns to reach the threshold (maximum resistance of the potentiometer). The blue potentiometer (right) takes about twenty turns to reach the threshold, while the gray potentiometer (left) only takes one turn. Trimming potentiometers are most handy when building circuits, but make sure the component has wire leads that will connect to the breadboard easily (both pictures show good lead examples).
Well, that's plenty to think about in Part I. In the next installment of this multi-part series, the rest of the basic parts will be discussed: capacitors, light-emitting diodes (LEDs), and a battery and battery holder. Supplemental tools will also be discussed in the upcoming entry.
Re: Electronic Projects for Beginners – Components (Part I)
07/21/2009 7:34 AM
Oh dear, I fear you may have stumbled at the first hurdle by confusing Electrical and Electronic.
Maybe it's just me but I thing the two disciplines are distinctly different.
Dunno what the rest of CR4 thinks...
Other than that I applaud the concept and the blog.
07/21/2009 8:38 AM
You are correct. They are two distinct disciplines.
My interchanging of the terms comes from my college experience where we have two branches of engineering concerning electronics. There is electrical engineering which main concentration is electronics. We also have a separate electric power engineering which refers mainly to electricity as you are probably referring to. When I refer to "electrical" with my fellow peers, it is known that I am referring to electronics and not to power engineering.
If the non-distinction bothers people, I will change it. To specify: This blog will not teach you how to wire your house. This blog will teach you about wiring small electronic circuits on breadboards.
Good Answers: 11
07/23/2009 7:52 AM
Del, I rarely disagree with you, because I lack the expertise, experience and training, but here you are treading on my home territory, ignorance of electricity. I still don't know why the stuff doesn't leak out of the socket when you take the plug out.
So let Jaxy use the words that make it easy for him to explain, and let him get us ignoramuses building something that works, even if it is boring and pointless. We will have finally cracked it and actually done something with electricity.
If we don't need fuses, don't lets get into discussing them, if somebody carries a bigger range of breadboards, great, but I'm still trying to work out whether a motherboard eats a breadboard, or uses it for making sandwiches.
This is the area where ignorance rules, and all we want to do is make something. Once we have got over that hurdle, we will be a lot more likely to learn, and to want to learn.
We almost need a parallel discussion for the guys at the next level up and so on ad infinitum, hey i've just had a really good idea, why don't we get groups of kids and get people who are keen on this sort of stuff to teach them, and don't say that's what schools are for, it may be what they are for, but it isn't what they are.
Jaxy, keep plugging along for guys like me, and pretty soon, we will be intelligent enough to argue with Del, which is always educational and a pleasure. But keep hanging in there Del because when confusion starts you are great at sorting it.
What i am trying to say here is that this is a topic where the questions have to come from the ignorant. Jaxy is dealing with the dumb so he has to dumb it down for us. Let's keep this really simple.
Simon
horsepower measures work, ponypower measures pleasure!
07/23/2009 8:37 AM
Thank you for your support.
But I hate to burst your bubble: I am a girl.
07/23/2009 9:36 AM
You have now made this blog even more interesting than it was before , more power to your elbow Jaxy and keep up the good work....
Good Answers: 11
07/23/2009 10:29 AM
Sorry, I try to not make that assumption, and I do try to keep my writing as non sexist as I can since I have four daughters, all of whom, I assume can do anything that interests them, or that they want to do for any other reason, but it is terribly difficult to stay non sexist and write readably.
Part of the reason is, of course, that we are totally familiar with the language of sexism, and find the language of equality, dissonant. I can write about engineers collectively and say "they" but when writing about an individual engineer, the problem returns. Any suggestions.
I am sure i will make the mistake again, so apologies in advance, but it is due to being an old fogey rather than malice. Keep up the good work as I still need to learn electricity in all its manifestations.
Simon
07/23/2009 9:32 AM
I know you mean well, I also understand where you are coming from but Del is still right!!
When I started my education, it was wrong generalities just like the one Del mentioned, that made it hard for me (and others).
I eventually learnt in the end that the person teaching the class simply does not know everything.....I could certainly tell you of some hair raising arguments that went to a phsyical proofing, that came out to show I was correct.
Professor with red face and blustering......it may not have improved my relationships with a few of the faculty members, but it certainly helped me get good marks......why? BECAUSE I UNDERSTOOD CORRECTLY AND NOT WRONGLY.....
Many errors are just a result of bad habits by the teacher concerned.....
Del and many others (I include myself) will tend to correct any "errors" we see, for the good of the uneducated who may get a wrong impression......which may make learning something correctly even more difficult.
Thats the way things work here, its as simple as that.
When it happens to me, I put a good face on it and be good enough mannered to thank the person concerned.......at the end of the day, it was my error not theirs!!!
Think of it as "assisting", not criticising.....
Good Answers: 11
07/23/2009 10:35 AM
I work with ponies predominantly, and I am permanently depressed that a "good judge of a horse" is the person who can find faults with them. I work with a pony called Obama and am proud of showing "He can do it". He does everything, but he is easy to fault if that is what floats your boat.
I did point out that this blog is about getting idiots like me to build something. If Jaxy is telling me the wrong way to build it, or if there is a simpler way to explain the concept, that is really helpful. But if the terminology is sloppy, but i can still build the thing, so what.
Simon
03/27/2013 8:03 AM
you know, the first electrical computers were made with relays! funny isn´t it...
“For no man can forbid the spark nor tell whence it may come.” ? Francis Bacon
Technical Fields - Education - Seasoned Vet in the Classroom United States - Member -
Good Answers: 19
07/21/2009 9:04 AM
Wow...love the images. It really helped explain what you were talking about. This was informative and very well explained. It makes me wish I paid more attention in high school physics class instead of saving all of my energy for double block AP biology which I had right after physics.
I look forward to expanding my knowledge base from this series. Nice job, so far, Jaxy.
StE - "For 'tis the sport to have the enginer/Hoist with his own petard" -Hamlet Act III, scene 4, 202–209
07/21/2009 9:07 AM
I am glad that you are learning. I tried to explain the best that I could and it seems that images may be the best way to accomplish this.
Thank you for the support!
Good Answers: 19
07/21/2009 9:10 AM
There is just a lot of terminology to absorb for the novice and visuals help make the connection of what you are talking about.
07/21/2009 10:38 AM
Radio Shack used to be a good place to get parts ten or fifteen years ago. Today their selection is pretty limited.
Mouser and Digikey are good for all sorts of parts.
Locally, in the Capitol District Trojan Electronics and E. E. Taylor have a good selection.
Charlie don't surf.
07/21/2009 10:54 AM
While Radio Shack may have had a better selection of quality components at one time, I am still using them as a reference. They are still one of the only local (and widely known) stores that I can walk into and walk out of with electronic components.
That being said, I agree that Digikey and Mouser are good places to find parts if you are looking for something specific. I am trying to keep it simple and make sure people can find the parts without confusion. Also, I wanted to point people to a place where you don't have to use a credit card online and can walk into a store instead, with the online security threats these days.
07/22/2009 10:22 AM
"Radio Shack used to be a good place to get parts ten or fifteen years ago. Today their selection is pretty limited."
I was thinking the same thing... the decline of useful electronic bits and pieces to be found at Radio Shack was noticeable when I was in High School, working on projects for the Science Olympiad. By the time I was a Senior, you were lucky if you could find a decent battery holder there!
Nice article, Jaxy-- wish I remembered more about electronics from too-long-ago physics classes. I look forward to reading your next entry.
Good Answers: 15
07/21/2009 1:20 PM
Jaxy, great blog. Hopefully you will inspire some budding young engineers to take interest!
Sharkles
Good Answers: 11
07/22/2009 3:23 AM
And some budding old farts as well. I like it, it looks like it is really written for people who need to start with the basics. Thanks.
07/22/2009 10:33 AM
Thank you very much for your support. I really appreciate it.
07/22/2009 10:48 AM
Nice work Jaxy. Very Nice...
One suggestion. For me when I was learning all of this. It was very helpful to have definition of common terms. Like allot of things, Electronics, Math, Physics have their own language and I found that if I understood the meaning of the terms it helped me to grasp the "concept" faster.
Just food for thought....
Bill12780
I'm fix'in to do somethin' stupid as hell...But I'm gonna do it anyway.
07/22/2009 11:14 AM
I will keep that in mind for the future. If I do not define terms, it may also be helpful for me to link to a page that can define them (perhaps better than I could ever explain).
Engineering Fields - Systems Engineering - New Member Popular Science - Weaponology - New Member
Good Answers: 62
07/22/2009 10:23 PM
Hey! Good to see you back!
"If you want to get somewhere else, you must run at least twice as fast as that!"
Good Answers: 11
07/23/2009 7:37 AM
Good to be back. Things looking up in my world. Currently looking at electronic horse ddrawn vehicle release systems and load sensors for use when doing row cro work with small ponies. Also looking at electronic pony control systems as hauling head round with a bit of metal or hitting with whips are so last millennium as communication systmes.
Simon.
Good Answers: 62
07/23/2009 7:40 AM
Well yeah, just because you are working with chariots is no reason to be old-fashioned
07/22/2009 6:08 AM
Thanks that you put your time and effort on this.
Good Answers: 11
07/22/2009 7:49 AM
It's a good effort. But don't forget fuses....
Eric
07/22/2009 10:30 AM
For the projects I am going to be doing, fuses aren't a part of them. We won't be dealing with such an extremely high voltage to where fuses would be necessary to prevent injury.
07/23/2009 6:37 AM
Fuses generally speaking, do not protect directly from high voltages, only high currents. They are a current activated device only.....
Naturally there are fuses down to 250 ma or less as well, but they still do not protect from high voltages. Sorry......
The Blog is otherwise really great.....
07/23/2009 8:39 AM
duhhhhhh. Good point. Don't be sorry, you corrected a very stupid mistake.
07/22/2009 6:58 PM
Hi Jaxy,
This is good idea. Although Radio Shack is the only local store here for these kinds of parts, they don't have a very good selection. Here are more links that my son and I have found useful in addition to the ones mentioned:
http://www.allelectronics.com/
http://www.alliedelec.com/
http://www.electronicsurplus.com/
http://www.electronix.com/
http://www.parts-express.com/home.cfm
http://www.bgmicro.com/
http://www.goldmine-elec.com/
http://www.jameco.com/
I have more for mechanical and special needs, but this is a good start for a beginner.
regards,
-S
07/23/2009 8:42 AM
Thank you for contributing links. I am sure that people will find them useful when trying to find parts.
Good Answers: 88
08/12/2009 2:27 AM
<flame>
Radio Shack has culled its component stock and has been doing so for years now. There once was a time where you could walk in and ask for, say, Fahnestock clips, and they knew exactly what you were looking for. Not anymore. These days their entire component selection resides not on three, floor-to-ceiling pegboard walls, but in six or eight shallow drawers. I suspect RS will eventually drop their component lines altogether in favor of yet more floor space for their B/C/D-grade consumer electronics. Kinda like Best Buy, but in Last Place.
Given the choice, I will not buy from Radio Shack. My experience has shown that their products are often of marginal quality - but always at premium prices. More than once I've purchased damaged goods that had been placed back on the shelves after a customer burned them out and then returned them for a refund.
Example: when RS decided to stop carrying loudspeakers, they marked all their remaining stock at half off. I was working on a project that used a kind of tweeter RS carried, and as these were now at a more reasonable price (still way too high, IMHO), I bought Radio Shack's entire West Houston stock. Every single one. I'm a sucker for sales, it seems. But I do test my stuff, just to make sure I'm not getting ripped off.
On average one tweeter in twelve was burned out. These were not manufacturing defects. These were used parts, dammit! Useless parts! The Shaft hadn't even tested them and just put them back on the shelves for the next sucker to buy - and return. Like many stores, Radio Shack lets us do their quality-control work for them. Wal-Mart is worse, but I digress (don't even get me started on that one)!
One bit of advice concerning hookup wire: Do Not use Radio Shack's so-called 'hookup wire' to make your protoboard-circuit's jumpers. The gauge is too large, for one thing. You know what I'm talking about: that horrid, where-in-Bog's-name-did-they-find-this crap? with the cheesy vinyl insulation that melts and shrinks back over the wire leaving a transparent non-conductive residue if you so much as fart out of turn? Yeah, that stuff. The Wire from Hell. It's gotta be; nobody here knows how to make anything that bad.
</flame>
Thanks for the links! Jameco and some of the others I've used before, but not all. And don't forget to mention DigiKey. They're a great outfit.
Engineering Fields - Chemical Engineering - New Member
07/24/2009 3:42 PM
I have limited to no experience in this field and this is very much appreciated. How often are you going to be posting?
Dan
07/24/2009 3:46 PM
I am going to be posting every Tuesday.
Good Answers: 25
08/12/2009 2:09 AM
Jaxy, (Nice sketch)
I dusted this off.
Got parts cabinets with various parts too.
Jon
08/12/2009 8:28 AM
Interesting topic, and one that I am not very familiar with. I was curious whether anyone knows if there is a 'virtual' breadboard that can be used for these experiments. I realize it is not quite the same as physically building something. It just seems like someone would have come up with this by now and it could save on time and money.
If you want to know what God thinks of money, just look at the people he gave it to. - Dorothy Parker
08/12/2009 10:18 AM
DM:
There are some, but none that are worth using are cheap. Probably the best known is called Spice, with another version of which I've heard called PSpice (that may be a Linux version of it. I don't know). But the Spice circuit simulator has been around for a long time. I don't know how well it works, but it must have SOME value, to have survived this long in the commercial marketplace. I know that through the years there have been some others, also, and some were reasonably inexpensive, but most that I knew of, and used, are only useful for drawing the circuit, and the board-etching art, for circuit board making, both of which require you to build and debug the circuit first.
But breadboarding a circuit is half the fun. The other half is watching the cotton packing out of a "smoke-tested" capacitor drift down from the ceiling, after it pops. Or watching the components do glow-worm imitations, when you wire them up wrong, or supply too much voltage. And that stuff you can't get from simulators.
Oh, and it provides valuable lessons on what not to do next time, also.
I've "let the evil smoke out" of components a few times, and it usual isn't all that big a deal, but I can suggest you don't do it in the presence of your wife/SO, as it tends to make them worry about what happens to you when they aren't around to see it. My most memorable was about 36 years ago, when I smoke tested 12 electrolytic can capacitors (reverse wired every one of the suckers) on a board (actually, the schematic had + and - reversed on the traces, so it wasn't REALLY my fault. Although, since I labeled the traces, it was, still, technically ... well, you know
) and the whole dozen blew almost simultaneously. My wife and baby daughter looked up to see my whole closet workshop wreathed in gently descending cotton batting, and smoke. Fun. But only once.
Micah
08/12/2009 10:44 AM
I have had ample time with PSpice (I have used it on windows; I don't know if there is a Linux version of it) and it is a very good tool to simulate circuits. But there will always be something special about building them on a board and trying to figure out what went wrong. For me, it is a better logic puzzle than crosswords or sudokus! A great sense of accomplishment comes from seeing something nice on a board in working order.
In one of the classes I was an assistant for, we used a capacitor in a disposable camera and would charge it up and use a paper clip to discharge it and watch the spark and hear the pop. Scared half the students to death, but it was always a joyous experiment.
Good Answers: 25
08/12/2009 10:34 AM
d m Rosenberg,
Google "virtual breadboard" and "spice software"
Jon
08/12/2009 10:46 AM
Sometimes programs do a very good job of simulating circuits. PSpice has already been mentioned. But like everything else in the world, just because it looks good on paper doesn't mean it works in reality.
05/10/2012 9:41 AM
Jaxy,
Welcome, welcome, especially to a girl.
As a 75 yr old who built his first circuits about 60 years ago, I have forgotten much but will be following you as you try to teach us the direction to move in.
Well done for this initiative.
Sleepy
Reply to Blog Entry 40 comments
Andy Germany (3); Anonymous Poster (1); bill12780 (1); ca1ic0cat (1); d_m_rosenberg (1); danman285 (1); edignan (2); electronick (1); Jaxy (12); kudukdweller9 (2); Mello (1); micahd02 (1); saddlechariot (5); ShakespeareTheEngineer (2); Sharkles (1); Sleepy (1); StandardsGuy (1); stevem (1); user-deleted-1105 (1); user-deleted-13 (1)
