Electrical Components Blog
Previous in Blog: Electronic Projects for Beginners – Translating the Schematic onto a Breadboard (Part IV)   Next in Blog: Why Do Industrial Accidents Happen?
13 comments
Electronic Projects for Beginners - Notes Concerning Chips (Part V)
Posted August 18, 2009 12:00 AM by Jaxy
Part I and II focused on components, but I felt that chips needed more clarification before I begin to use them in a project. This entry focuses on all you need to know about chips before you insert them into the breadboard. Different projects will focus on different kinds of chips, which will be discussed as they are presented.
Inserting Chips Into Breadboards
When inserting chips into the breadboard, it is very important to insert them as pictured to the left. Notice that four pins of the chip are on the left side of the trench that is running through the center of the breadboard and four pins are on the right side.
Not inserting the chip over this trench can lead to chip malfunction and even breaking (in the electrical sense, you will not see a large crack running through the chip denoting its disrepair). Chips may do various things when they break like let out smoke or get very hot. Sometimes they get so hot that the top of the chip starts melting away and you can see the glowing red of the internal connections (I have witnessed this once, not my doing, mind you), so proceed with utmost caution when touching chips if you think they are bad while power is on.
If you ever see smoke or smell burning after turning the power on or attaching the battery, turn it off or remove the battery immediately. This indicates that something is not wired right and you fried a component and it will no longer work. If you hear a "pop" noise, this could indicate an LED or capacitor has broken. If you see black or brown scorch marks on an LED, capacitor, or other component, replace it.
Orientation and Pins
The next most important step besides inserting the chip in the right part of the breadboard is to have the right orientation. As a basic rule of thumb, it is best to keep all chips on the board all orientated toward the top of the board, or at the very least, facing the same direction.
The image at the right has labeled the 555 timer chip. Every chip has either a notch or an indented spot. The notch indicates the top of the chip with the top left pin being pin one. The pins are sequentially numbered counter clockwise around the chip. Most chips have more than eight pins, but they are still counted in the same fashion. The indented spot usually indicates pin one on the chip and can also be used as a reference as to which end is the top.
Type of Chip We Will Be Using
When choosing chips, there are many different package types available. Certain packages are meant to be used for various things, which I will not discuss in this blog. The package type that is used for a breadboard is DIP, which stands for dual in-line packaging. Variations of these packages include CERDIP and PDIP which are distinguished for their packaging material.
Chips and Schematics
As you can tell from the example schematic to the right, the pins on the chip are labeled, although not in the correct orientation around the chip. On the schematic, the first pin (top left) is labeled "2". This corresponds to pin 2 on the chip (second down on the left side), NOT the first pin on the left (as the orientation on the schematic would suggest). When connecting wires to the pins, make sure that the pin number on the schematic corresponds to the pin number on the chip.
Notice also in the example schematic that lines cross. The lines that cross and have dots on them are electrical connections, but the lines that cross without dots are not meant to be electrically connected. Sometimes in order to make schematics visually appealing, they need to cross lines, but make sure there is a dot on them before connecting them electrically.
Part VI of this series will kick off the project making portion of the series. This project starts by using a 555 timer to make LEDs blink. This project will also lay out the steps needed to produce the resulting frequency from a speaker.
Previous Blogs in Series:
Electronic Projects for Beginners – Components (Part I)
Electronic Projects for Beginners – More Components (Part II)
Electronic Projects for Beginners – Reading Components (Part III)
Engineering Fields - Chemical Engineering - New Member
Re: Electronic Projects for Beginners - Notes Concerning Chips (Part V)
08/19/2009 2:56 PM
But what do the chips actually do? It sounds like this specific one is a timer. Do all of them do that? Do different legs correspond to different time delays? These seem like magical black boxes to me. Thanks
Dan
08/19/2009 3:08 PM
A 555 chip is a timer. It basically corresponds to a multivibrator, or flip-flop, if those terms mean anything to you. What it does is switch its output from roughly 1/3 Vcc to 2/3 Vcc, where Vcc is the maximum voltage applied to its power pins. The voltage it can switch is usually set at +5 Volts DC (+5VDC), but some military grade timers can switch up to 12 volts, I believe. The pins don't determine the timing. That is determined by a very simple external circuit consisting of a couple of resistors and a couple of capacitors. Depending on how they are connected, it can switch constantly, making a square-wave oscillator, or as either a "one-shot" (switching states in reponse to a stimulus, then, switching back at a predetermined time interval) or as a monstatble flip-flop, toggling from whichever state it is in to the other state with each input.
What's handy about these, and I'm sure Jaxy will get to this later, is that there are many kinds of inputs you can use to switch them. Very versatile chips.
08/19/2009 3:15 PM
There are a vast number of IC chips which have various functions. I used the 555 timer as an example because the first project of this series will be implementing that chip and there I explain in more detail. micahd02 went into the detail of the 555 timer (thank you), but I figured I would answer the rest of your questions.
Different legs on the chip correspond to different functions. In order to know the full use of each pin on the chip, it is helpful to have the data sheet. Just like any other data sheet for a part, it gives you limitations on the chip (temperatures, voltages, currents, etc.) and it also provides you a description of the pinout or pin diagram of the chip. All of the information can be useful, but in general, we will be mostly concerned with voltage/current thresholds and pin functions. Feel free to ask more questions. I am sure that the CR4 community (including me) are willing to answer you.
08/20/2009 2:27 PM
I applaud your use of the 555 for this project. This IC can and is used for a multitude of functions. I used to build different sound producers for the kids toys. I made sirens and raygun sounds among others. I also used them in several projects at work.
08/19/2009 5:11 PM
At this point I'd like to add a common mistake that happens with the installation of a DIP chip on a bread board. Frequently, brand new chips come with the lead tips of each row spread a little wider than the pin spacing of the bread board. The preferred technique to align these pins is the use of some needle nose pliers, but an acceptable technique is to use the table surface to gently bend the row of leads closer to the center line of the chip. A tempting solution is to just squeeze the pins closer together using your fingers. This will make for a non-uniform pin tip location and can cause this frequent mistake. Sometimes a pin tip will end up in the trough under the chip instead of in the breadboard socket for that pin. Pressing the chip in place will feel normal for only 1 of the 8, 14, or 16 pins will be bent under the chip. But this one pin will not be connecting to any circuitry. Only the closest of examination will show the missing connection.
08/19/2009 9:47 PM
Using the fingers to bend the pins often also ends up with static fried chips, since most of us forget to wear a grounding strap, and a lot of chips are now designed with CMOS, or some other high-impedance structure. Best to use at least a tool, such as needle-nose pliers, which, because it connects all the pins in a row at one time to a conductor, establishes at least a common reference voltage level across all the pins being bent.
Good Answers: 25
09/01/2009 2:01 AM
Micahd02 et al,
09/01/2009 9:41 AM
Yes, there are a multitude of wonderful precision tools for doing prototype work. But I made my comment not to scare Jaxy into trying to procure more funding because she needed only the finest prototype tools for her class. My comment, and the static discharge comment (Micahd02?) were made to warn a teacher of common mistakes everyone will do at one time with a prototype board. I would expect that in a class with more than 15 proto-board based circuits that on the first day that a chip is inserted into the board somebody will have a bent pin. If Jaxy warns her students of this problem before circuit assembly, they will at least be aware of this possible problem and may correct or prevent it from happening before wasting time trying to take data on a failing circuit.
Good Answers: 25
09/01/2009 11:44 AM
RedFred,
We each offer a little. I thought it would be cool if folks knew about that cool tool.
Jon
09/01/2009 1:41 PM
To you and Redfred (Thanks, Redfred!), I agree wholeheartedly with you both, and add "That's a cool tool! Where can I get one?" I admit I haven't googled it, but if you have a source, I'm all eyes!
09/01/2009 2:48 PM
Pricey, indeed. Did you see the flat-jawed pliers (their item18I)? $52.50 for a pair of small pliers. Must be good, to be worth that much. Assuming they are worth that much, that is.
09/01/2009 3:10 PM
Precisely why I warned Jaxy that these toys can get expensive quickly.
danman285 (1); Jaxy (1); Jim_Wright (1); kudukdweller9 (3); micahd02 (4); redfred (3)
