Previous in Forum: Over Unity Magnet Motor or TRICK?   Next in Forum: What is the Thinnest Cut?
VASIMR Magnetic Plasma Rocket Could Send Humans To Mars In Just 39 Days
04/07/2015 6:36 PM
Looks like ion propulsion on steroids...
http://unbonmotgroundswell.blogspot.com/2015/04/vasimr-magnetic-plasma-rocket-could.html
NASA has selected Texas-based Ad Astra Rocket Company for a round of funding to help develop the Variable Specific Impulse Magnetoplasma Rocket, or VASIMR. The new rocket uses plasma and magnets, not to lift spacecraft into orbit but to propel them further and faster once they've escaped the planet's atmosphere.
"It is a rocket like no other rocket that you might have seen in the past. It is a plasma rocket," Dr. Franklin Chang-Díaz, a former shuttle astronaut and CEO of Ad Astra said in a video describing the rocket. "The VASIMR engine is not used for launching things into space or landing them back but rather it is used for things already there. We call this 'in-space propulsion.'"
Pathfinder Tags: Magnetic Plasma Mars rocket VASIMR
Re: VASIMR Magnetic Plasma Rocket Could Send Humans To Mars In Just 39 Days
04/07/2015 7:16 PM
I've said before, here on CR4, that a manned trip to Mars is a non-starter until a propulsion system is developed that can get men there in weeks, not months. The risk of equipment failure is too large, and the risk of radiation exposure is too great, to risk sending humans to Mars in a mission that takes months.
This engine has potential, but I think a think a system of in-flight refueling will also be needed. No matter how efficient the engine is, it still needs mass to squirt out the nozzle to get sufficient thrust, and a single rocket that carries all the propellant to get to Mars will be unrealistically large. A system for in-flight refueling will allow for a smaller manned rocket yet still provide the fuel for the Mars trip.
04/07/2015 11:29 PM
Probable complexity nightmare.
04/09/2015 12:08 PM
accelerated plasma rockets with particle velocities in the millions of degrees compared to thousands of degrees for chemical rockets are (1) intrinsically safer (no particular pressure explosion hazards), and (2) require about 1/1000th the amount of fuel to produce the same thrust integral, or maybe 1/1000000th, since
K.E. = 1/2 m v2 and this would seem to indicate that specific impulse is totally proportional to the kinetic energy of the propellant.
Is = 1/2 m V2 (or not), since actual Isp = V/g (g is earth's gravitation constant). It is most likely the specific impulse is 1000X with plasma engine (VASIMR) than it could ever be with same mass units of chemical engine. I like those odd, but also the spacecraft terminal velocity would be vastly higher than with the chemical rocket.
Register to Reply 3 comments
James Stewart (1); Tornado (1); Usbport (1)
