Previous in Forum: Minimum Distance of weld of an insert or flush patch from an existing weld   Next in Forum: Trip Oil Pressure Low Alarm During Lube Oil Coller Change Over
14 comments
Polymer Shafts
04/10/2015 6:54 PM
Hi
I want any information(document) about polymer shafts please.
Re: polymer shafts
04/10/2015 7:12 PM
Well, Google it then!
Re: polymer shafts
04/10/2015 7:42 PM
I found documents about polymers, but there is no details around polymer shafts.
Re: polymer shafts
04/10/2015 7:50 PM
Welcome to the real world of doing research. You have found documentation about polymers. Now you have to research the meaning of the word "shaft" and see how it applies to concept of a shaft made of a polymer.
Re: polymer shafts
04/10/2015 8:01 PM
Any analytical or theoretical research will be supported by references.
Re: polymer shafts
04/10/2015 9:45 PM
why? how about hardened steel instead?
Re: polymer shafts
04/10/2015 8:18 PM
Here are some polymer shafts you can purchase.
http://www.sears.com/unicorn-xl-co-polymer-dart-shaft/p-00611764000P
Re: polymer shafts
04/10/2015 10:09 PM
This is obviously yet another homework question.
Do your own homework. CR4 is not a homework cheat site; however, if you have questions about understanding concepts or how a portion of a problem is derived, these types of questions will be accepted.
Re: polymer shafts
04/11/2015 12:42 AM
This is what predictably happens when you ask to be given the shaft.
Re: polymer shafts
04/13/2015 9:41 AM
"Tactless, yet rude." -Slappy Squirrel
You made me spit soda all over my monitor, have a GA for that.
Re: polymer shafts
04/11/2015 4:59 AM
It would be a shaft made of polymers.
It might be different ones for different applications.
An internet search for "polymer shafts" is recommended.
Or more information has to be given to evaluate the application and usefulness of polymer as a shaft material.
Re: polymer shafts
04/11/2015 11:50 AM
OK. What sort of information do you want, then?
Good moaning!
Re: Polymer Shafts
04/13/2015 1:44 PM
Mine shaft, or tunnel shaft? Mechanical rotating shafts, or oscillating shafts? Shafts of light? Polymer light shafts? Drinking straw shafts? Shafts tied in knots? If so, what kind of knots? Inorganic polymer or organic (green) polymer?
Shafts of polymer woven into something (useful) to sit upon?
Shafts of polymer extruded from a machine into rods? And then cut into tiny bits of plastic to send around and extrude again? Not very efficient, that.
Please do elaborate.
Hobbies - CNC - New Member
Re: Polymer Shafts
04/15/2015 10:11 AM
I see you also posted to another engineering forum
  • http://www.crazyengineers.com/threads/polymer-shafts.80002/
Here is my answer:
  • A polymer shaft is a shaft made from polymer!
  • Any more questions?
Why don't you post an actual question that is asking for specific answers regarding the:
  • Chemical makeup?
  • Strength?
  • Min/Max sizes?
  • Machinability?
  • Where to purchase it?
  • What are you using it for?
  • Is this a HOMEWORK question?
  • I guess I gave you "any" information?
  • Maybe not?
Register to Reply 14 comments
Anonymous Poster (1); Brave Sir Robin (1); Crabtree (1); Fredski (1); IdeaSmith (1); James Stewart (1); kahaten (2); lyn (3); Original_Macgyver (1); redfred (1); Tornado (1)
