Previous in Forum: EX MACHINA   Next in Forum: Search Engines
55 comments
What Is it? (Sorry, Again I Haven't a Clue.)
04/29/2015 2:57 PM
I was working in someones house between tenants, and, we found this in the garden. It most resembles a mangle but I suspect that it's for flattening / shaping some kind of soft metal.
The rollers are about 2 inches/5cm in diameter and about 6 inches/15cm long.
The handle is very robust:-
The cogs are designed so that the distance between the rollers can be adjusted by tightening down the the two screws at the top:-
The rollers are "wrinkled" at one end and flat at the other:-
The whole thing is very heavy; the frame is made from solid metal and the feet are designed to be fixed to a floor:-
Any ideas?
Pathfinder Tags: mangle metal forming pasta press
Re: What Is it? (Sorry, again I haven't a clue.)
04/29/2015 3:13 PM
Looks like a slip roll machine...
04/29/2015 4:05 PM
Don't they normally have three rollers adjustable so that you can bend the sheet / wire in a given radius?
04/29/2015 4:56 PM
Nope, I don't think you get the cigar.
Too many grooves and there's no provision to remove the sheet once it's rolled.
Good Answers: 69
04/29/2015 3:14 PM
A sheetmetal pre-form (ribs for added stiffness) ?.
Good Answers: 76
04/29/2015 3:17 PM
Well, the question really isn't what it is... it's a Roller Press... but the question is what in the heck did they press with it.
No clue, but I'll look around.
04/29/2015 3:23 PM
Tin can body former?
04/29/2015 3:27 PM
Sounds good...er looks right....
04/30/2015 8:46 PM
How the heck do you get the can OUT of the machine, one done???? :-)
04/29/2015 4:07 PM
GA
Seems very reasonable.
Good Answers: 76
04/29/2015 4:56 PM
but the profiles are opposite rather than mating, so don't think it would create corrugated but rather thick/thin... and to bend you'd need an offset, and a way to get it off ;-)
It's a Rolling Press... as others have mentioned it could be for jewelry, but it seems rather robust... so I'm thinking it is a Blacksmithing Combination Rolling Press. And by 'combination' it can roll flat billets/bar... or round. Maybe the user made ornamental wrought iron work.
04/29/2015 5:08 PM
Its hard to say, the ridges don't appear to have been manufactured uniform across the length of the roller either.
Thanks for the mental picture of 'ye old ornamental wrought iron jewelry'
Good Answers: 97
04/29/2015 3:32 PM
Progressive wire gauge reducer? Make a short big wire into a longer little wire....
CRTL-Z
04/30/2015 9:09 PM
Why are you marked off topic? You are correct! We had one at the Uni i worked at. The rolls were once very smooth/shiny and the flat section was to thin down bar/sheet. This is small and may have been for jewelry.
Jim
04/30/2015 9:19 PM
Shoulda read all posts before posting . Still doesn't answer why you are OT!
Good Answers: 29
04/29/2015 3:58 PM
Once again, Solar Eagle is right. It's a slip roll machine. I found a few videos on youtube that show them in action. Here's one:
https://www.youtube.com/watch?v=puBLjpAmXAg
The grooves at one side are for forming wire and tubing.
Hobbies - CNC - New Member
04/29/2015 4:43 PM
I disagree with the Slip roll answer because with a slip roll, you are able to "ROLL" the cylinder and then "SLIP" it off of one end.
This one does not have the capability to open up and "SLIP" the newly formed cylinder off!
It is an OLD wire former or flattener of some sort, possibly for jewelry or another soft metal application. Very possibly someones own special application metal former?
With this machine, there is no way to remove anything yo rolled in a circle!
Below is a 2 roller jewelry former.
Good Answers: 25
04/29/2015 5:14 PM
I agree,
It looks like a Jewelers rolling mill to me.
A slip roll former would have three rollers.
Troy
04/29/2015 5:34 PM
Yep! Click on the picture.
04/29/2015 8:23 PM
Well maybe it's a combination....if you notice the outside of the rollers looks like a working surface...
04/29/2015 8:32 PM
My thoughts too. Almost looks like it could be for shaping something the size of a tin can lid.
04/30/2015 5:11 AM
GA: you mean here?
The odd thing here is that the top roller is smooth and the bottom one has "troughs".
Good Answers: 97
04/29/2015 5:09 PM
Is that rust on the rollers, or did someone get behind in their work?
CRTL-Z
04/29/2015 6:50 PM
Pasta maker?
Good Answers: 122
04/29/2015 6:51 PM
A cavalier owner body part press?
Good Answers: 61
04/29/2015 7:07 PM
A mangle for people who wear stainless steel underpants? Just guessing.
04/29/2015 7:25 PM
What ever it is if you lived closer I'd give you at least $100 for it.
I like finding odd old things like this and repurposing them for new work.
Good Answers: 445
04/29/2015 9:42 PM
It's a combination rolling mill for flats and rounds, use the flat side for bar, sheet, and rectangular sections, and the ribbed side for rounds and wires. Some shapes require multiple passes to get the desired look. What goes in flat and straight comes out flat and straight (not curled like a slip mill), as long as the centerlines and tangents of the rollers are aligned properly where they meet the feedstock.
04/29/2015 10:47 PM
Maybe a very heavy duty laundry press for wringing water out of clothes?
04/29/2015 11:48 PM
This is a multipurpose pasta extruder. On one side you get various diameters of round stuff like angel hair and spaghetti; on the other side, flat stuff like linguine and fettuccine. With the post-processing accessory, you can get farfalle, lasagna, etc.
04/29/2015 11:56 PM
A sugar cane or sorghum press. I saw one like that when I was in Macon County, Georgia.
04/30/2015 5:18 AM
GA.
Trouble is we don't get much sugar cane or sorghum in Hemel Hempstead. But maybe there is a clue in the name "Hempstead".
04/30/2015 9:05 AM
I thought that at first but I have never seen a cane mill with horizontal rollers. All of the ones I've seen have vertical rollers and they were turned (at first) by a long shaft that was powered by a farm animal.
They were later powered by tractors or stand-alone engines driving a belt and pulley system.
I have found some horizontal roller mills but none of them have the exposed rollers on the side.
When I saw the picture the first time I wanted it to be a cane mill but I don't think it is. The fact that the top roller is height adjustable on both sides instead of in the middle leads to a metal-working tool. There would be no reason to be able to have a tapered gap between the rollers if it was a cane mill.
Also, if anyone has an old cane mill they would like to get rid of let me know. I'm trying to put together some of the things my father and grandfather used as a means of survival during the depression. Lets see if any of you know what this is:
I recently found one in my father's barn that I didn't know he had. I know what it is and have used it many times.
04/30/2015 2:23 AM
Sugar cane juice crusher
B +ve
04/30/2015 2:56 AM
This looks more like a wire or rod straightening machine, probably a blacksmiths tool.The fourth roll points to it being a universal production tool.
Good Answers: 94
04/30/2015 4:18 AM
I think it only has 2 rollers, the 4 gears are just to allow for the roller spacing to be adjusted. The suggestions of a sheet/wire roll seem to be about right.
Re: What Is it? (Sorry, Again I Haven't a Clue.)
04/30/2015 5:33 AM
Looks like a rubber mixing mill to me....
04/30/2015 5:43 AM
It reminds me of a scrap cable recycling machine where the insulation of long lengths of cable are crushed and stripped from the conductors.
04/30/2015 7:04 AM
The only thing that comes to mind is a device for stripping plastic from electrical cables but the smooth part of the roller does not fit the possible use. Then again if they found some rollers and had the various groves turned into them and did not need a full range this could be the reason for smooth area. If it is for stripping wires then the knife part is missing also it seems a bit massive but that happens when built by a DIY.
04/30/2015 8:02 AM
its a pasta maker.........roll your own
04/30/2015 8:08 AM
Is there an echo in the room?
04/30/2015 8:25 AM
Good Answers: 266
04/30/2015 9:29 AM
Old roller mill. Which had many uses. A blacksmith or farrier to reduce bar stock. Used to crush hemp or jute to release the fiber. Many trades used them.
Good Answers: 445
04/30/2015 10:31 AM
Nonbelievers!!
http://www.riogrande.com/Product/Durston-130mm-Combination-Rolling-Mill/113514?Pos=1
04/30/2015 2:09 PM
GA. Thanks
I think this confirms it; even has the "D" grooves.
04/30/2015 2:54 PM
I believe!
Good Answers: 34
04/30/2015 12:36 PM
Sugar cane juicer
https://www.youtube.com/watch?v=gk73z7y3tKo
04/30/2015 2:03 PM
This is just a sugarcane juice extracting machine still being used in India on road sides.
05/01/2015 4:08 AM
Dear Mr.Randall,
It may be (In my opinion it is) Sugar Cane Crusher to extract juice from the Sugar Cane.
DHAYANANDHAN.S
05/01/2015 5:16 AM
Ramconsult's rolling mill at #40 is so close it has to be the correct intended use.
As for the sugar cane juicer: it would be incredibly difficult/inconvenient to mount a sensible way to collect the juice on the machine we found.
Good Answers: 445
05/01/2015 9:00 AM
A cane mill or most any press for extracting juice would be mounted over the collection system and it would probably have relatively inert rollers like brass or rubber:
Like this sugar cane mill.
05/01/2015 12:32 PM
Look at the second picture at post 27.
It is definitely not incredibly difficult.
B +ve
Good Answers: 445
05/01/2015 12:53 PM
Never said it was, but compare the robustness of the unit in the original posting and the juicer in #27. Since form follows function it would be unnecessary to have all that heavy metal and gearing on a juicer, unless what it was compressing was a material that required a lot of force.
The generic term "to mill" means to grind or crush something so the function is the same, but the form that the mill takes is dependent upon what is being crushed. I think that you'll agree that putting a 25mm² piece of iron into the juice crusher would result in its destruction, while the unit in the original posting would be able to flatten that into a sheet 4x6mm, no juice catcher required.
05/01/2015 1:04 PM
I was only commenting on expression that it would be difficult to collect the juice.
Yes I agree that the structure is way too heavy for a simple sugar cane juice maker.
B +ve
05/01/2015 1:38 PM
Even faced with clues that lead away from the cane mill - the robustness of the design, the outside rollers, the ability to cant the rollers separately, etc. - some people are still stuck on the cane mill idea. A 1945 Volkswagen Beetle is a car, just like a 2013 Bugatti Veyron is a car, but they do not serve the same purpose. You can do a lot of the things in a Veyron (roller mill) that you can do in a Beetle (cane mill) but you can't put that piece of metal that you run through through the roller mill (Veyron) through the cane mill (Beetle) without causing some serious damage!!
12/10/2024 7:15 AM
So THAT'S where it has gone!
Any chance of returning it, please?
Register to Reply 55 comments
acumenalex (1); capri (3); dhayanandhan (1); don.ras (1); energyconversion (1); Fredski (1); horace40 (1); jack of all trades (3); JavaHead (2); JIMRAT (2); Lo_Volt (1); lyn (3); Nigh (1); Original_Macgyver (1); ozzb (1); Pekanmin (1); PWSlack (1); r&ddoc (1); RAMConsult (4); Randall (6); rashavarek (1); Rixter (1); roeblinggrid (2); roy hammy (1); SHOCKHISCAN (1); SolarEagle (3); tcmtech (1); tonyhemet (1); Tornado (2); Troy36 (1); Unredundant (2); wayneelowe (1); Whitephone (1); Yahlasit (1)
