Previous in Forum: Mustang 2054 Skid Steer   Next in Forum: Which Steel Has This Composition?
28 comments
Long Suction Pipe in Pumping Station
05/30/2015 8:37 AM
Hello,
We are now reviewing a design of a very, very large (HUGE!) reservoir and pumping station site, with capacities of a single pump from 0.4-1.85 m3/s (1500-6650 m3/h), and having 5-6 duty pumps in operation. The reservoir is split into 6 cells, which are connected by two common DN2200 headers (arranged as mirror reflection 3+3). The water column in reservoirs is approx. 5 - 10m above pump center line. The problem is that the common suction headers are quite long, even up to 500m from exit of the furthest reservoir to the pump suction flange. The distance to the closest reservoir cell is naturally smaller - up to 200m.
Our senior reviewer is arguing that in such case, the pump will not be able to start, i.e. the mass of the water in 500m long suction pipe is too large for pump to cope with, so the pump will work in cavitation regime for a prolonged period and than just simply trip. His opinion is that 5-10m static head in reservoir is not sufficient to "push" the water towards the pump.
The designer is simply denying everything, claiming the pump will have no problems at all.Their calculation shows only the working regime, not the pump start-up.
My opinion is that it just might work with the closest reservoir cell, but when it drains down, the remaining cells truly won't be able to push water towards the pump.
Any suggestions?
Pathfinder Tags: head losses piping pump
Good Answers: 38
Re: Long suction pipe in pumping station
05/30/2015 9:58 AM
Contact the pump vendor independently and ask questions. He probably has experience with similar poorly designed installations. Your consultant is correct, you simply cannot place the pumps at any distance from the reservoir and expect them to work properly.
Cavitation and flow instabilities can occur with these kind of pumps if the intake stream is poorly configured or if the pump is started too quickly. Investigate how fast that the pumps will start and if a very slow start is possible.
Both the venerable "Pump Handbook" by Kassarik and Hydraulic Institute guidelines contain limitations on suction channel configuration design.
It would not be unusual to have a pump vendor perform scale model studies to verify flow. This scale model testing is expensive. I have personal experience with this kind of testing that was done for a nuclear power plant in Sweden.
05/30/2015 10:13 AM
Calculate the average velocity of the fluid in the pipe under all conditions of pump operation intended, ready to discuss with the pump manufacturer. Note that doubling the number of pumps in use does not double the flow, as the operating point moves to a different place on the pumps' pressure-flow characteristic curves on the basis of what the piping system presents to them.
Using the Darcy-Weisbach equation for the process fluid at the temperatures experienced, calculate the pressure drop in the pipeline feeding the pump set(s). Subtract it from the lowest head condition in the upstream reservoir. If the pump inlet pressure under any operating condition is below the fluid boiling pressure at the ambient temperature, the fluid will cavitate, placing the pump impellers at great risk. If so, then a redesign or reselection may be necessary. Once these calculations are to hand, challenge the other parties involved to come up with their calculations to justify their statements.
And go from there.
Good Answers: 266
05/30/2015 11:03 AM
There is not enough information provided to say whom is right. Diameter of the 500m run to the diameter of the pump input(suction side). These could be 2m runs to the pumps with 150mm suction inlet to the pump. With a 1m line connecting the two. Where it's being pump to and at what pressure. You give a large variance in pump volume. Is that due to motor controls installed or head pressure. There are a lot of variables involved isn't that why you choose some one to design it. And not the senior reviewer. We have no way of knowing their knowledge of the subject.
05/30/2015 11:14 AM
"Our senior reviewer is arguing"
Go back to your client and tell them that your organization is incapable of performing a technical review of this project, due to the incompetence of your staff.
Or, hire a mechanical engineer with the proper education to perform the technical analysis.
05/31/2015 3:45 PM
lol I've considered it many times and still do
but our senior consultant already told'em straight - "your project falls into category of BS"
05/31/2015 3:54 PM
Good for him!
Tornado's suggestion of slow ramped pump start may solve the cavitation problem.
Depending on the lift and flow required, your power may, or may not, be enough. If your pumps are properly designed and adequately powered, you won't have any problems.
05/30/2015 11:58 AM
Can you set this up with VFD motor control and a fairly generous ramp-up time?
05/31/2015 7:30 AM
Yes, the motors shall be equipped with VFDs, but the opinion is that the power won't be sufficient, and that the pumps will not be able to deliver water.
05/31/2015 11:53 AM
Power is a different problem altogether. Why do they think the power will be insufficient?
05/31/2015 12:02 PM
With 5-10 meters of positive head, you don't need a pump.
You also don't indicate if there is any lift required, or the quantity of water you want to move per unit of time.
You still need someone on staff who has something other than an opinion.
Good Answers: 137
05/31/2015 2:10 PM
He said "The water column in reservoirs is approx. 5 - 10m above pump center line." He hasn't given the level in the downstream tank, but I think we can assume it's higher than the suction tank.
05/31/2015 2:42 PM
Maybe.
05/31/2015 4:14 PM
The pump delivers to downstream reservoirs which are approx 20m higher than the suction reservoir, through pumping main of some 40km length (depending on the operation scenario). Pumping station output can go as high as 5.2 m3/s.
However, the start up and initial operation is questionable here.
Good Answers: 137
06/01/2015 5:35 PM
As there is some static head, if you ramp up the speed no need to go up slowly from zero speed, as there is no flow until the generated head = the static. Can speed up quickly to speed corresponding to that head, then slowly from there. The inverter or PLC will be able to handle it.
06/01/2015 5:58 PM
Wow.
That's 25 miles.
That changes everything.
Getting 25 miles worth of water moving is not going to be easy.
That's 36 tons.
Or, did I miss something?
06/02/2015 1:57 AM
Yeah, you're absolutely right.
06/01/2015 3:37 PM
Ditto this. You must have slow spin up, and have back-pressure build up at low flow condition. Water has some inertia.
Good Answers: 137
05/30/2015 12:17 PM
Out of curiosity I did a basic calculation assuming total flow 3*6650m3/h per 2.2m pipe, 500m long. Allowing 10 seconds for acceleration of the water, and using Newton's laws, I make head required ~ 7.5m. Pipe friction ~ 0.5m.
But as you say the pump capacities vary from 0.4-1.85 m3/s, there should be no problem in practice, whether that is by variable speed or throttling the discharge. Minimum flow (3 pumps on) gives 1.7m and 0.025m friction. Unless the pumps are axial flow you're unlikely to draw excessive power even if throttled more.
Also you can start one pump, ramp it up, and start others sequentially.
That's my take anyway.
Good Answers: 92
05/31/2015 7:09 AM
I don't pretend any expertise in this, but shouldn't that have been based on the 200m distance??
If these cells really are as huge as claimed (no figures given) and the size and shape of the header connections are scaled accordingly it seems to me that the initial surge would draw somewhat evenly between the first cell and the remaining header to the other 2 cells, then splitting again for the remainder. Once the draw was established the effects of the water column height would take over; providing the header connections are not restrictive, the draw from the further cells would then increase until the flow was somewhat equalized. Have I missed something in this?
Good Answers: 137
05/31/2015 11:37 AM
200 vs 500m - I wasn't sure about the layout, so I took worst case.
05/31/2015 7:28 AM
05/31/2015 7:32 AM
Will apply this to the particulars of the project. Thanks!
Good Answers: 102
Re: Long Suction Pipe in Pumping Station
05/31/2015 12:43 AM
Is any of this built yet?
05/31/2015 7:25 AM
Earthworks going on.
Good Answers: 102
06/06/2015 6:06 AM
Has any piping or other apparatus been ordered and paid for yet?
06/10/2015 3:08 AM
No, no purchasing yet. Technical specs are also under reivew.
Good Answers: 102
06/10/2015 4:35 AM
At least this project is being done in the correct sequence.
06/01/2015 8:04 PM
For long delivery pump runs, we start on closed head and then open the line (slowly). We have a couple of runs that are 45km running 0.5m3/s.
Thus the starting situation is at no flow and the total flow ramps up with no sudden acceleration needed.
The valves used are at outlet end of pipeline. There are also valves at the pumps, but mostly used to isolate the second pump in the set so that it can be started later.
We have "balance" tanks on the line so that on pump "shutdown" there is water available to maintain the line full as the water column decelerates.
The seals on the valves are regarded as service parts, since closing against that flow/pressure/momentum causes significant wear. Those valves are in enclosed rooms due to noise (cavitation) during the closing process.
You REALLY need to discuss with operators of similar water systems to understand the dynamics of what you are dealing with.
You are right in one respect though. There is significant difference between the steady state conditions (either off or running) and the transition states of starting and stopping.
How big are the thrust blocks at the pipe bends and direction changes. Be prepared for SUBSTANTIAL ground movement whenever starting or stopping any of these pumps!
Register to Reply 28 comments
Codemaster (4); drift (8); James Stewart (1); JNB (1); Just an Engineer (1); lyn (5); MJCronin (1); ozzb (1); PWSlack (1); Tornado (2); Wal (3)
