Previous in Forum: Pocket Milling   Next in Forum: China Motor Schematic
16 comments
Milling Machine Selection
06/03/2015 10:00 AM
what is the best milling machine is to be selected for machining thru pockets on "100*100*40 mm", comercial Alumium block? (max 40mm diameter hole).
please mention power ratings.
Re: milling machine selection
06/03/2015 10:10 AM
Call HAAS, they can tell you:
http://haascnc.com/home.asp#gsc.tab=0
06/03/2015 10:11 AM
    Go to the section:
    Send them your COMPLETE machine requirements and let them make proposals regarding the best machine to use.
    Maybe ask a local machinist for their recommendations.
    The information you provide is not adequate for any good analysis or recommendations.
Hobbies - CNC - New Member
06/03/2015 10:18 AM
khannaji,
  • How many parts are you going to mill, 1? 100? 1000000?
  • How much money do you have?
  • How much money do you want to spend?
  • CNC machine?
  • Manual machine?
Re: Milling Machine Selection
06/03/2015 3:01 PM
That would depend upon what <...best...> means.
06/03/2015 9:24 PM
Not sure about any of this but make sure you use cutters suitable for Aluminium.
06/03/2015 9:37 PM
Suitable for aluminum?
06/04/2015 1:50 AM
I did not say commercial one!
06/04/2015 5:01 AM
OP did specify alumium.
06/04/2015 7:54 AM
I'm still trying to figure out what a "thru pocket" looks like, but just about any mill capable of ~2000 RPM with coolant will suffice.
06/05/2015 3:44 PM
What is this mysterious Alumium you refer to? Is it solid at room temperature? We already know it is bigger than a breadbox. We know what size the desired holes in it are to be also from your post (40 mm) Are these to be round holes? Square holes, hexagonal holes, triangular? I assume you meant round, since you mentioned diameter. If this is for engine blocks you need a large, industrial robotic mill.
There is noone here by that name.
06/05/2015 5:12 PM
If those are 40 mm round holes, I have two Glock drills in that diameter.
Good Answers: 102
06/07/2015 10:50 PM
....burred holes mate. Effective but rough.
That's a big Glock drill.
This one is nice but 40mm might be a big ask...
Good Answers: 102
06/07/2015 11:04 PM
What is your geographic location?
New or second hand?
Any mill that has a vice big enough for the work to be securely held will be fine really.
Others have mentioned different considerations.
When shopping, don't do this 100% by phone or email, take a test piece of material with you, the cutting tool you intend to use and ask to see the mill in action.
Listen, look, measure and feel.....
.....and haggle. It's a buyer's market at present. Look for bankrupt businesses liquidating their assets.
06/08/2015 9:55 AM
You initial post is somwhat confusing. Please explain yourself, and your machining needs more thoroughly, if you want a really good answer from one of the crew here.
For all I know you are attempting to bore a 40 mm hole in 40mm commercial aluminum block, why not just grind it all up, and give up?
06/28/2015 2:50 AM
Dear Khannaji,
It's obvious to ask further data.
Please provide.
Call or what's app * if in India.
Or mail *
Ajaybhai Sanghrajka
CR4 ADMIN - phone number removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
CR4 ADMIN - email address removed From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
linear motion system designing. Ajay
06/29/2015 2:54 PM
Ajay: Not that any of here are nefarious bastages that will steal your private information, but you should reply privately to the OP, rather than in the open forum.
Register to Reply 16 comments
ajaybiotek8 (1); DeputyDawg (1); IdeaSmith (2); James Stewart (3); lyn (3); Massey (1); Original_Macgyver (1); phph001 (1); PWSlack (1); Wal (2)
