Previous in Forum: Interlocking Requirement Between Grounding Systems   Next in Forum: Insulation Co-ordination of Power Transformer
9 comments
Datasheet for IC LCKH
06/29/2015 6:59 AM
Dear anybody,
I am finding the IC without ID or part number, just found on the surface of this IC (Rectangle shape IC) is "LCKH N854 110".
I had searching but could not found this IC's datasheet.
Does anyone know this IC please ?!
Thank you for your help !
Re: looking datasheet IC LCKH
06/29/2015 7:15 AM
Well, I would have thought that a telephone call to the equipment manufacturer would be the quickest route to an answer, then I'm funny that way.
Good moaning!
06/29/2015 8:10 AM
Dear Cabtre, Thank you for your help but I could not found any infomation indicated the manufacture on the surface of this IC. BRs
Hobbies - CNC - New Member
Re: Looking Datasheet IC LCKH
06/29/2015 9:02 AM
Where is the IC installed?
  • A printer?
  • A CNC mill?
  • A blender?
  • A remote control cat toy?
  • Why do you need to know
  • Who makes the PC board?
  • Etc. Etc. Etc.
That's 8 questions out of 20.
OP it's your turn!
06/29/2015 9:53 AM
There is no point in using an IC, the properties and characteristics of which are not understood, in any design!
Simply use a different IC, the properties and characteristics of which are given in a datasheet that is accessible.
If the Quest is to reverse-Engineer a product that contains an IC that is proprietary and the details of it are unknown, then any invitation to assist is declined on the basis of not wishing to be an accessory after the fact.
06/29/2015 11:35 AM
Take a picture of it and attach it with a new post.
06/29/2015 5:03 PM
How many things does it have?
Re: Datasheet for IC LCKH
06/29/2015 8:04 PM
06/30/2015 11:36 PM
Thank you Rixter, this IC look like same as this IC but the mark indicated on the surface is N854 nor N292.
I could not found any info indicated the difference between these marks in the datasheet of this IC.
Does anyone can help !
07/01/2015 6:09 AM
Did you look at the data sheet for the Linear part LTC6102CDD?
It specifies part marking for some of the parts as just LCKH.
The other markings on the device are probably for factory of manufacture and date code.
Anonymous Poster (2); Crabtree (1); lyn (1); Mikerho (1); Original_Macgyver (1); PWSlack (1); Randall (1); SolarEagle (1)
