Previous in Forum: What is This?   Next in Forum: Alphanumeric Reader Device
41 comments
Tractor AC
07/25/2015 10:47 PM
Hi All . We need some help troubleshooting slow leak in A C system in farm tractor . We tried leak detector dye , no evidence on fittings or hoses, Pump is 2 Colorado seasons old. Sevice trucks are not available out here in the boonies . Continueing to add freon is a hassle All responses are appreciated , Thanks
User-tagged by 1 user
Re: Tractor AC
07/25/2015 11:34 PM
"no evidence on fittings or hoses" leaves condenser, evaporator and compressor.
Re: Tractor AC
07/25/2015 11:38 PM
You need to section off the system, pull a vacuum on each section, should show failure to hold vacuum within 20 min....otherwise you just start changing parts....evaporator coil, expansion valve, condenser coil, dryer accumulator....leaks can be so small as to be nearly impossible to find...sometimes there is a flaw in the tubing...
Good Answers: 225
Re: Tractor AC
07/26/2015 4:00 AM
In many jurisdictions it's illegal to replace lost refrigerant without first fixing the leak.
If you're only losing gas but not getting air into the system, then the leak is likely on the high side - compressor - piping - condenser - piping - dryer - piping - metering device.
It's possible that a very minor leak is in the low side if your losses occur during non-run times, this can be due to delamination of hosing allowing gas out when stationary but not air in when running.
Best way to find a difficult leak is with an electronic leak detector, you can pick up a cheap one for under $100, but make sure it will detect your refrigerant. Soapy water is an old and tested method.
If you're getting air into the system then both high and low side pressure should be elevated and disclose this fact and the leak will be on the low side, you need to decontaminate the whole system.
When you find the leak - keep looking - there may be more.
Good Answers: 88
Re: Tractor AC
07/26/2015 4:35 AM
Leak detector dye is not only for fittings or hoses, it is for everything. And assuming you haven't found any coloring after carefully examining ALL accesible spots (including compressor shaft seal and condenser) it must be the evaporator., but you must get it out to see the dye leak. Good luck. S.M.
Re: Tractor AC
07/26/2015 4:59 AM
On first go-around, look for any places where oil might have exuded. In addition to injected dyes (typically red), which you have already tried, there are fluorescent dyes that are somewhat more sensitive, requiring an ultraviolet light to be seen. Everyone has given good advice so far, but these leaks can be hard to detect, and may require more trying. Good luck on chasing this down.
Re: Tractor AC
07/26/2015 7:05 AM
You may need a leak detector, they range in price. The cheaper ones can be purchase at China outlet Harbor freight. This will help track down the leak.
http://t.harborfreight.com/electronic-freon-and-halogen-leak-detector-92514.html
It actually sounds like a damaged line during assembly. Which happens.
Re: Tractor AC
07/26/2015 9:25 AM
I find em with something like this.........works everytime
Re: Tractor AC
07/26/2015 12:03 PM
Depending on the age and type of refrigerant being used one often overlooked leakage point is in the rubber hoses themselves. Years ago I had a car that would loose it AC over a period of a few weeks and as with you I tried everything to find it and didn't come up with any single point of leakage.
Turned out the hoses themselves were the problem and they were letting the refrigerant out without letting enough of the dye through to show up as a noticeable leak source.
A guy I knew said that the hoses were likely seeping so try changing them out and see what happens.
New hoses and life was good!
Other than that if your compressor you put in two seasons ago was a rebuilt unit there is a good chance you got one with a bad shaft seal assy and that's letting your charge out around the shaft when its running.
Its a well known problem associated with remanufactured compressors that got rebuilt with cheap parts and seals that are not actually compatible with all of the refrigerants and oils the compressors may get used with when put back into service.
Re: Tractor AC
07/26/2015 12:07 PM
did you use the red dye? should have used the glow stuff!
Re: Tractor AC
07/26/2015 12:11 PM
I don't recall its exact color but yes it was not the fluorescent type. I didn't know much about AC systems back then as I do now nor did I have much for dedicated AC tooling or equipment to work with.
It's amazing how a guys knowledge base and tooling improves over 15 - 20 years to avoid the service industry crooks.
Re: Tractor AC
07/26/2015 12:14 PM
did you just call me a crook???
Re: Tractor AC
07/26/2015 1:55 PM
Depends. How many pounds of freon did you bill your customers for out of a 30 pound cylinder. If it was more than 30 then yes you're a HVAC crook.
Around here at the HVAC contractor supply places I have heard that you're not a real HVAC tech until you're billing out at least 60 to 100 pounds from your average 30 pound cylinder.
Re: Tractor AC
07/26/2015 2:03 PM
usually I bill a 2 hour min even if I'm there 10 minutes. when you add up all the phone time windshield time etc it's about right. a 30 lbs can of juice varies from around 40-100 bucks I always guess how much I use and usually charge 5-10 bucks a pound....and usually use around 2 pounds if I'm just topping off a charge. if I repair a leak and do a complete recharge I use the nameplate weight....if its got a plate that can be read. in residential applications its almost always well under 10 lbs.
Re: Tractor AC
07/26/2015 4:45 PM
Sounds like a yes to me.
I never charge let alone factor in phone time toward any service calls of any sort I have ever done and never will.
I also do not guess at the amount of consumables that I use when they cost more than a couple dollars a pound or each. If I can afford to buy a $20 portable digital scale and carry it with me I would think that any HVAC tech who is charging for 2 hours billable for 10 minutes of work could too.
As for travel its by the mile with fairly generous discounts when I can set up two or more service calls in one trip. Heck if I can put a service call to someone on a day that I have to go in their general direction anyway I usually will do the call free of travel charges. I see no honestly in getting someone to pay me to go someplace I had to go regardless of their need for my services or not.
My point is I have worked for companies that did that sort of stuff and I never ever felt good about my job when I found out how my time and travel was being billed. Exspecially so when I was doing upto 8 - 10 easy service calls in one area in a single trip and I found out that all 8 - 10 customers were getting billed for the minimum show up rate plus round trip travel.
Even more so when I found out that added up to as much as 16+ hours billable and nearly 1000 miles of travel for a less than 100 mile round trip and I only got paid for 8 - 10 hours of it.
Re: Tractor AC
07/26/2015 4:58 PM
if you drove from south Orange county to LA a couple of times I think your tune would change
Re: Tractor AC
07/26/2015 5:41 PM
Fortunately I am from North Dakota and we have a different set of morals and ethics relating to business practice and how we treat our fellow man. For us not liking the trip or 'because everyone else is does it' does not justify ripping off the customer.
Re: Tractor AC
07/26/2015 5:51 PM
you'd go broke here, its expensive to live here. it costs what it costs, I don't carry a gun
Re: Tractor AC
07/26/2015 6:03 PM
A cash register works better, anyway. A POS credit card reader even better. (The acronym ambiguity is intentional.)
Re: Tractor AC
07/26/2015 6:07 PM
the readers you plug into a cell phone are super convenient but the fees are a rip
Re: Tractor AC
07/26/2015 8:10 PM
If being a honest person and treating my customers like I want to be treated makes me broke then obviously I am living in the wrong area and doing the wrong kind of work for me.
But then that's largely what separates us North Dakota farming people from the typical Californians. We might never be rich but we do get to sleep with a clean conscious at night and look our customers in the eye with the same conscious in the day.
Unless of course we're one of the local HVAC techs. Then we have $10K mattresses to sleep help us sleep and $500 mirrored RayBan sunglasses so no one can see we don't look anyone in the eye in the day time.
Re: Tractor AC
07/26/2015 8:24 PM
although many of my customers are people who I occasionally socialize with for the most part our relationship is on a corporate level, they aren't my "friends." I get paid well because I respond quickly and minimize their downtime. most medium to large businesses have an IT and in some cases a corporate computer or data center. these rooms are the nerve center of their entire show. if they go down their business slows to a crawl. when they get a high temp alarm or water cascading out of the ceiling they want me there 2 hours ago. they don't flinch when I charge them 200 bucks to get there, they just want it fixed. I never rip off any of my customers. I will charge them everytime they call on the amount we've already agreed upon.my bill has nothing to do with what someone personnally thinks of me.
Good Answers: 54
Re: Tractor AC
07/28/2015 9:12 PM
We have Sit and Sleep stores here, so we can get a Stearns and Foster mattress for about $2-3K.
We also don't wear mirrored Ray Bans ... but a nice pair of Persol, Oliver Peoples or Tom Ford sunglasses! Now you're talking. And they should be around $300- 450, not $500.
And a Tesla S 85 is the same $80K here or anywhere else in the US - of course the wealthy buy the 85D or the bad boy P85D, but that one's over $100K and if you're going to spend that much on a car, you can afford an S550 - Geez!!
See, we're just like everyone else.
Re: Tractor AC
07/26/2015 5:59 PM
So move to LA.
Good Answers: 102
Re: Tractor AC
07/27/2015 6:08 AM
Would you have felt better if your employer also gave you a bigger slice of the action?
Double dipping for mobilisation that doesn't happen is a bit cheeky though. I don't do it but I also don't travel for free either.
Charging for gas weight that isn't even decanted comes into the minimum price per topup category. Has to be done. You can't sell your consumables for cost price.
Charging for phone calls or other electronic communication? I do that. They are called teleconsultations. If it can save a mobilisation then the customer wins.
It's the ones who charge and and keep coming back to fix the same fault that bother me.
Re: Tractor AC
07/27/2015 9:24 PM
"Would you have felt better if your employer also gave you a bigger slice of the action?"
I would have been happy with getting paid the same hours I got billed out for or paid the national rate for my type of work which at that time was 20 - 30% of billable for my daily hours or the customer getting billed for the actual time and part of the trip miles they made up.
The thing was, this was around 1999 - 2000, I was being billed out at $76.50 an hour plus $1 a mile and making $8.41 an hour with no over time and a $4 a day meal per diem provided I supplied receipts for buying food more than 50 miles from the base shop/store.
On a really good day that I brought in 16 hours billable and every customer on my route paid the $1 a mile, even though there were ten of them all in one location, meant I could have brought in at least $1224 time and ~$1000 mileage while I got paid $67.28 before taxes and cost the company less than $100 for vehicle expenses and fuel plus my $4 meal.
Towards the end of that job I started unpadding my billable time and whatever else I could get away with to make the service charges the most fair for my customers.
Good Answers: 102
Re: Tractor AC
07/28/2015 2:41 AM
GA mate.
That job doesn't sound ideal at all.
I see and feel where you're coming from now.
BTW, is that former employer still in business? Doesn't sound sustainable.
Good Answers: 225
Re: Tractor AC
07/26/2015 6:48 PM
Don't complain about your refrigerant costs or price gouging. When the - then - Australian Labour Government introduced our famous Carbon tax, refrigerant, which was about $50/kg rose to over $350/kg almost overnight. So your 30 pound bottle was costing around $5000 here.
The industry was not happy.
Re: Tractor AC
07/26/2015 2:58 PM
That's what an MBA is all about.
Re: Tractor AC
07/30/2015 12:37 PM
A little off-topic here, but one practice in the automotive rip . . . I mean repair business is that when you take your car in for A/C work, they will vacuum out whatever freon charge is left in your car, then after the repair they will charge your for the entire amount even though they are recycling what they pulled out. They never give allowances for the free freon you just gave them.
That's when I bought my own vacuum pump and manifold gauges.
Re: Tractor AC
07/26/2015 12:20 PM
the little meter in #7 is the ticket. if you really know how to use it can pinpoint any leak down to less than an ounce a year. I swear by mine its basically a small pump. it draws in a sample of air. it then burns it over a heating element, depending on what you have it set for it will alert when it detects a burning sample. various "freons" burn at different temps so you need the type that selects different types.
Good Answers: 19
Re: Tractor AC
07/26/2015 7:39 PM
Might have been covered in another post.
Have you checked the schrader valves?
Most people discount these items because they are so dependable but sometimes they get loose or have a bit of trash in them.
Just a thought.
Re: Tractor AC
07/26/2015 7:47 PM
actually I ALWAYS suspect them first. a lot of guys miss them when doing a leak test....usually because they have their gauges hooked up onto them..also the terminals of the compressor are usually never checked and they can leak too
Re: Tractor AC
07/26/2015 10:35 PM
I will need some information as to the color of the tractor: Green ones are easy, you just need a lot of cash to solve repairs. Red ones are harder, you need cash and parts. Blue ones are less expensive but the parts are hard to get, they come from Italy. While you await a solution do what your grandad did: open the cab door and let the dust fly.
Re: Tractor AC
07/26/2015 10:42 PM
Re: Tractor AC
07/27/2015 6:42 AM
AC in a tractor is just decadent! My grandad sat on top of his John Deere and wore a straw hat!
Re: Tractor AC
07/27/2015 6:47 AM
That and a spray can would probably do the trick.
Re: Tractor AC
07/26/2015 10:41 PM
Can we use waste heat in exhaust gas for heating/airconditioning.
pnaban
Re: Tractor AC
07/27/2015 12:51 AM
Some of us can. And probably you, too.
Good Answers: 16
Re: Tractor AC
07/26/2015 11:26 PM
If you don't want to become an HVAC technician with a pickup full of specialized gear, go to WalMart or your local big box automotive parts place, or go on the internet and get a bottle of AC Pro LeakStop for about $25 and add to your system per the instructions and then top off the refrigerant charge. If it's a small, slow leak that should fix it for several years.
Re: Tractor AC
07/27/2015 7:37 AM
When hi tek methods fail,go back to the basics.
A leak on an inside turn of a multi-layer coil is very hard to find.
Use nitrogen to pressurize the system,then use a soapy water solution (Mr Bubble works well,kids use it to blow bubbles) to find the leak.
Most leaks will occur at the factory solder joints,so check all of these first.
Then remove the condenser coil (most likely culprit) and lay it flat on a sheet of plastic.
The condenser coil is vulnerable to debri damage due to it's location.
Pressurize it with nitrogen,spray with soapy solution,and watch for bubbles.
By laying the coil down, you can localize the leak instead of following a trail of
bubbles down the fins.
Last resort is remove the evaporator coil and test it likewise.
Good luck!
Good Answers: 122
Re: Tractor AC
07/28/2015 9:36 AM
More than likely the compressor shaft seal needs to be replaced.
The seal is under the compressor clutch assembly and it is extremely hard to identify any leaks at that location.
Because of the distance from the front and sides of the clutch assembly to the seal, a sniffer cannot detect small leaks and it is not possible to see the seal without removing the clutch assembly.
I suggest you change the clutch assembly as well as the seal because the premature seal failure is most likely due to bad surface finish. (rough or undersized)
Be sure to evacuate the AC system before starting the clutch removal, keep the area very clean, follow all directions, use the correct tool(s) to remove and install the clutch assembly, pull the correct vacuum on the system, and replace the compressor oil charge with the correct amount and type of refrigerant oil before recharging the system.
CAUTION! Do not overcharge the system with too much refrigerant as it can be deadly. If you do not have the proper HVAC tools and know how to use them or do not know how to correctly charge the AC system, it is in your best safety interest to pay a competent service technician to perform the needed work.
Good luck and stay safe
Register to Reply 41 comments
Autobroker (1); Brave Sir Robin (1); Fredski (10); Graycav (1); HiTekRedNek (1); lyn (2); phoenix911 (1); pnaban (1); sharpstick (1); SHOCKHISCAN (1); SimpleMind (1); SolarEagle (1); spades (2); tcmtech (7); Tornado (6); Wal (2); wayneelowe (1); Wrench twirler (1)
