Previous in Forum: Building a Scale Model of the Solar System   Next in Forum: Boeing Is Doing What?
53 comments
SR71 Engine
09/20/2015 2:43 PM
ever wonder why the engines have a cone at their inlet? I did
https://www.youtube.com/watch?v=F3ao5SCedIk
Re: SR71 engine
09/20/2015 4:13 PM
Nothing about this spacecraft is ordinary.
Re: SR71 engine
09/20/2015 4:27 PM
To spear the geese before they enter the engines.
Re: SR71 engine
09/20/2015 4:36 PM
every plane needs a cow catcher after 7000 feet
Re: SR71 engine
09/20/2015 5:41 PM
Re: SR71 Engine
09/20/2015 6:50 PM
I could give a short, and inadequate, serious answer to this question but for a better and more complete answer including the design and operation of this SR-41 (Blackbird) Pratt and Whitney Engine go watch the below 5 minute U-Tube video I discovered. Trust me, it will be worth your time
Re: SR71 Engine
09/20/2015 7:04 PM
Not exactly sure what you are talking about.
Fredski's opening post has the same web link to information about the SR-71 engine.
What's a SR-41?
And his link is live.
Re: SR71 Engine
09/20/2015 7:12 PM
clearly nothing gets past you
Re: SR71 Engine
09/20/2015 8:12 PM
I simply scanned the picture and his comment, totally overlooked the link and went on to review the responses; which, to be honest, seemed to be so off subject that I didn't think any real information had been given on the engine. I will be more diligent next time.
Re: SR71 Engine
09/20/2015 8:23 PM
its all good
Re: SR71 Engine
09/20/2015 8:26 PM
It's no big thing.
We're a tough audience here and give no quarter.
Hang around and join the fun.
Re: SR71 Engine
09/20/2015 8:36 PM
Wait.....there was a picture?
Reply Off Topic (Score 4)
Good Answers: 70
Re: SR71 Engine
09/21/2015 4:34 AM
I could tell you more about the the J58 but then I'd have to kill you!!!
The technology Kelly Johnson came up with in the early '60s was amazing for his time. And he also used the old tried and true technology- anything "Tarred and Feathered " can and will run really fast !!
Never had the opportunity to crew a SR 71, but a fellow Inspector did and had storied to tell, one that stuck out was when the Black Bird was setting in the hanger the fuel would leak like a sieve out of the wings and was some really nasty $hit to deal with. But still a pretty cool bird!!
Re: SR71 Engine
09/21/2015 6:11 AM
Designed with slide rules, same as when we went to the moon. Makes ya think!
Re: SR71 Engine
09/21/2015 10:09 AM
I spent a good of part of my early engineering career using a slide rule (yes, I admit it, some will say I am "old"; but, I prefer to say "experienced").
In fact, I still have my trusty Post Versalog with its last performance upgrade, a magnifying glass that clips to the viewer so to better interpolate those last 4 digits; and, I am not giving it up because when that emp from the sun hits I am going to be in great demand.
Also, I don't know what the big deal is with portable calculators, my Versalog case came with belt loop.
Re: SR71 Engine
09/21/2015 10:21 AM
when you began your career was the building electrified or did you just lite the whale oil lamp?
Re: SR71 Engine
09/21/2015 10:32 AM
When I studied chemistry in school, there were just four elements!
Re: SR71 Engine
09/21/2015 12:01 PM
I was a materials engineer working on satellites in the days of T squares and drafting tables. Late 60's through late 80's.
I remember seeing 30-40 drafters working on tables with Velum drawings. They all had electric erasers hanging from their tables.
Good Answers: 75
Re: SR71 Engine
09/21/2015 7:38 PM
They still work. I still use the 30+ I have in my collection. But few know how to use one any longer.
Re: SR71 Engine
09/22/2015 12:58 PM
Were slide rules in existence when they designed the Brooklyn Bridge?
It's still standing.
Re: SR71 Engine
09/22/2015 1:34 PM
Re: SR71 Engine
09/21/2015 8:56 AM
The cone causes a shockwave to form behind it. This shockwave causes an increase in pressure behind the cone. The increased pressure behind the cone causes the cone to be pushed forward......Think about that for a while.
Re: SR71 Engine
09/21/2015 9:24 AM
Okay, then we can dispense with the fuel....
Re: SR71 Engine
09/21/2015 9:27 AM
Nice, you do have to get to mach 3 first though for it to work.
Re: SR71 Engine
09/21/2015 10:55 AM
No, because, at least according to Bernoulli, the exhaust velocity would, at a maximum only equal the inlet velocity. I think that means "No Thrust". I will have to get my slide rule out and verify that though.
Re: SR71 Engine
09/21/2015 11:23 AM
The spinning engine parts inlet may not be where you think it is. This engine has 3 separate and discrete functional systems that provide "thrust".
Re: SR71 Engine
09/21/2015 11:52 AM
My post was in response to jhotmer's statement and was totally related to the theoretical aspects of the translations from inlet velocity to static pressure to discharge velocity. It was not intended to relate to the actual mechanics of the operating engine.
Re: SR71 Engine
09/21/2015 11:43 AM
I don't think the pressure moves the cone. I believe there is an actuator that adjusts the cone position for the airspeed.
Re: SR71 Engine
09/21/2015 11:51 AM
Ah; the actuator moves the cone correlated with velocity to place the shockwave for best overall efficiency. I am not an expert, but a co-worker is an actual aerospace engine expert. Its all about efficiency after you get to mach 3.
Good Answers: 179
Re: SR71 Engine
09/21/2015 11:07 AM
The SR-71: more proof that by putting enormous HP (as in thrust) behind it a Brick can fly.
Or was that the McDonnell-Douglas F-4 Phantom II????? Hehehehheee
Re: SR71 Engine
09/21/2015 11:10 AM
who woke you up?
Good Answers: 179
Re: SR71 Engine
09/21/2015 11:17 AM
Mr. Coffee did....
Good Answers: 97
Re: SR71 Engine
09/21/2015 1:38 PM
I happened to be in the wrong place at the right time when two F-4's scrambled, right behind them when they punched AB, J-79's were impressive.
CRTL-Z
Re: SR71 Engine
09/21/2015 1:46 PM
still have eyebrows?
Good Answers: 97
Re: SR71 Engine
09/21/2015 2:00 PM
They grew back. A benefit was, no stinking Key West NAS mosquito's for a while, they must be repelled by burnt hair.
CRTL-Z
Re: SR71 Engine
09/21/2015 11:22 AM
About the below the line quote.
I didn't know they had a Mafia problem in Rome during Julius Caesar's reign. If so, were they with him or against him?
Good Answers: 97
Re: SR71 Engine
09/21/2015 12:10 PM
Naked J bird.
CRTL-Z
Re: SR71 Engine
09/21/2015 12:37 PM
Interesting post about one of my favourite all time aircraft, many thanks.
Concorde was not as fast, but carried far more passengers.....
It also had the same problems to get air into its engines, here is a good explanation for anyone interested:-
Concorde's Powerplant
Re: SR71 Engine
09/21/2015 1:16 PM
I thought these were interesting:
Re: SR71 Engine
09/21/2015 1:32 PM
Nice, Thanks.
Re: SR71 Engine
09/21/2015 2:49 PM
Nice film about the Blackbird...
https://www.youtube.com/watch?v=OBVmYi7mkZM
Good Answers: 179
Re: SR71 Engine
09/21/2015 4:18 PM
Here's an interesting explanation of how the P&W J-58 engines operate relative to MACH:
http://www.airspacemag.com/military-aviation/how-things-work-supersonic-inlets-35428453/?no-ist
Re: SR71 Engine
09/21/2015 5:36 PM
not bad info....for a cement guy
Good Answers: 179
Re: SR71 Engine
09/21/2015 7:43 PM
Concrete guy, concrete....
Re: SR71 Engine
09/21/2015 7:46 PM
so left out a little aggregate. don't get Psi'd
Good Answers: 179
Re: SR71 Engine
09/21/2015 8:02 PM
And water, and admixtures....hehehehhehe
Re: SR71 Engine
09/21/2015 5:50 PM
Every time I go to San Diego, I visit the SR-71 at San Diego Aerospace Museum.
This is my favorite "ultimate" Blackbird story:
The Ultimate Ground Speed Check - Tales from the Blackbird
Good Answers: 97
Re: SR71 Engine
09/22/2015 1:52 PM
Finally got a chance to read the ultimate story. Fast, just doesn't cover it. Thanks.
CRTL-Z
Re: SR71 Engine
09/22/2015 2:08 PM
not too many people have a similar tale
Re: SR71 Engine
09/22/2015 5:15 PM
A small excerpt:
Written by Brian Schul - former sled (SR-71 Blackbird) driver
Under Attack
Walt continues to update me with numerous reactions he sees on the DEF panel. He
is receiving missile tracking signals. With each mile we traverse, every two
seconds, I become more uncomfortable driving deeper into this barren and hostile
land. I am glad the DEF panel is not in the front seat. It would be a big
distraction now, seeing the lights flashing. In contrast, my cockpit is 'quiet'
as the jet purrs and relishes her new-found strength, continuing to slowly
accelerate. The spikes are full aft now, tucked twenty-six inches deep into the
nacelles. With all inlet doors tightly shut, at 3.24 Mach, the J-58s are more
like ramjets now, gulping 100,000 cubic feet of air per second. We are a roaring
express now, and as we roll through the enemy's backyard, I hope our speed
continues to defeat the missile radars below. We are approaching a turn, and
this is good. It will only make it more difficult for any launched missile to
solve the solution for hitting our aircraft. I push the speed up at Walt's
request. The jet does not skip a beat, nothing fluctuates, and the cameras have
a rock steady platform. Walt received missile launch signals. Before he can say
anything else, my left hand instinctively moves the throttles yet farther
forward. My eyes are glued to temperature gauges now, as I know the jet will
willingly go to speeds that can harm her. The temps are relatively cool and from
all the warm temps we've encountered thus far, this surprises me but then, it
really doesn't surprise me. Mach 3.31 and Walt is quiet for the moment. I move
my gloved finder across the small silver wheel on the autopilot panel which
controls the aircraft's pitch. With the deft feel known to Swiss watchmakers,
surgeons, and 'dinosaurs' (old- time pilots who not only fly an airplane but
'feel it'), I rotate the pitch wheel somewhere between one-sixteenth and
one-eighth inch location, a position which yields the 500-foot-per-minute climb
I desire. The jet raises her nose one-sixth of a degree and knows, I'll push her
higher as she goes faster. The Mach continues to rise, but during this segment
of our route, I am in no mood to pull throttles back. Walt's voice pierces the
quiet of my cockpit with the news of more missile launch signals. The gravity of
Walter's voice tells me that he believes the signals to be a more valid threat
than the others. Within seconds he tells me to 'push it up' and I firmly press
both throttles against their stops. For the next few seconds, I will let the jet
go as fast as she wants. A final turn is coming up and we both know that if we
can hit that turn at this speed, we most likely will defeat any missiles. We are
not there yet, though, and I'm wondering if Walt will call for a defensive turn
off our course. With no words spoken, I sense Walter is thinking in concert with
me about maintaining our programmed course. To keep from worrying, I glance
outside, wondering if I'll be able to visually pick up a missile aimed at us.
Odd are the thoughts that wander through one's mind in times like these. I found
myself recalling the words of former SR-71 pilots who were fired upon while
flying missions over North Vietnam They said the few errant missile detonations
they were able to observe from the cockpit looked like implosions rather than
explosions. This was due to the great speed at which the jet was hurling away
from the exploding missile. I see nothing outside except the endless expanse of
a steel blue sky and the broad patch of tan earth far below. I have only had my
eyes out of the cockpit for seconds, but it seems like many minutes since I have
last checked the gauges inside. Returning my attention inward, I glance first at
the miles counter telling me how many more to go, until we can start our turn
Then I note the Mach, and passing beyond 3.45, I realize that Walter and I have
attained new personal records. The Mach continues to increase. The ride is
incredibly smooth. There seems to be a confirmed trust now, between me and the
jet; she will not hesitate to deliver whatever speed we need, and I can count on
no problems with the inlets. Walt and I are ultimately depending on the jet now
- more so than normal - and she seems to know it. The cooler outside
temperatures have awakened the spirit born into her years ago, when men
dedicated to excellence took the time and care to build her well. With spikes
and doors as tight as they can get, we are racing against the time it could take
a missile to reach our altitude.It is a race this jet will not let us lose. The Mach eases
to 3.5 as we crest 80,000 feet. We are a bullet now - except faster. We hit the turn,
and I feel some relief as our nose swings away from a country we have seen quite enough
of. Screaming past Tripoli , our phenomenal speed continues to rise, and the screaming
Sled pummels the enemy one more time, laying down a parting sonic boom. In seconds,
we can see nothing but the expansive blue of the Mediterranean . I realize that I still
have my left hand full-forward and we're continuing to rocket along in maximum
afterburner. The TDI now shows us Mach numbers, not only new to our experience
but flat out scary. Walt says the DEF panel is now quiet, and I know it is time
to reduce our incredible speed. I pull the throttles to the min 'burner range
and the jet still doesn't want to slow down. Normally the Mach would be affected
immediately, when making such a large throttle movement, but for just a few
moments old 960 just sat out there at the high Mach, she seemed to love and like
the proud Sled she was, only began to slow when we were well out of danger
Good Answers: 97
Re: SR71 Engine
09/22/2015 5:25 PM
Absolutely astounding!
CRTL-Z
Re: SR71 Engine
09/22/2015 5:37 PM
A good read. Thanks,
Re: SR71 Engine
09/22/2015 9:16 PM
Reminds me of a quote by a former SR-71 pilot:
"You haven't been lost untill you've been lost at Mach 3,"
Good Answers: 61
Re: SR71 Engine
09/30/2015 12:12 PM
I remember reading this a while ago. Remind me where it was published - Wings, Airpower? Sadly defunct now.
Reply to Forum Thread 53 comments
Andy Germany (1); Calnet42 (2); CaptMoosie (5); Casper71 (2); dj95401 (1); energyconversion (1); Fredski (10); jack of all trades (1); JAlberts (6); jhotmer (5); lyn (6); micahd02 (1); Rixter (3); SolarEagle (1); Tornado (2); Unredundant (5); Usbport (1)
