Previous in Forum: To Displace Helical Gear Wheel   Next in Forum: Question for the Mechanical/Structural Engineers: Shelf Load Limit
34 comments
A Technical Question
09/29/2015 7:42 AM
i need to know if i had a pump gives maximum pressure 420 bar the power needed from the motor would be how many horses??
Re: A technical question
09/29/2015 7:44 AM
The power requirement of any liquid pump is the pressure rise multiplied by the flow through it divided by the overall efficiency. The rest is arithmetic.
If the flow through the pump were zero, the power requirement would be zero too.
09/29/2015 7:57 AM
Do u have any contact so i could discuss with you my question ??
09/29/2015 8:00 AM
Yes. Pump suppliers can be found either with a Google search or by using the Products & Suppliers tab at the top of this page. The rest is telephone calls. Good luck.
09/29/2015 8:20 AM
SOORY i had anthor question ??
i had a pump pressure =420 bar carries a pistone mass=20 ton and its area = 3500c.m2 this pistone moves with velocity =10 cm/s so the motor needed how many horses should be and it r.p.m ??
09/29/2015 8:24 AM
Simply look it up on the label attached to the motor on the pump.
If it doesn't exist yet then a figure in excess of 200kW is suggested.
Apologies come across as abstruse.
A 6in pipe at that pressure is going to have a thick sidewall, and may not be readily available off the shelf.
The purpose of this pump is a curiosity, being too high a pressure for seawater reverse osmosis by a factor of 7.
09/29/2015 10:03 AM
dear,
IS it logic to get out 3500 liter of hydrolic oil from a nozzel 1 cm2 area in 1 sec ??
and if not i need to know the nozzel area if i had 3500 liter and time 1 sec ??
09/29/2015 10:51 AM
That's nonsense. The velocity would be hypersonic. You didn't mention that in the original message. Why are you bringing it up now?
My homework alarm just went off. This can't be a real-world matter. Lyn is right.
Good moaning!
09/30/2015 4:27 AM
You need to stop and think...
Imagine 3,500 litre bottles of your favourite beverage.
Imagine an aperture 1cm2 area.
Now imagine the two at the same time and picture how you might get one through the other and how long it would take.
If that doesn't help, image that each of your bottles has a cross section area of 1cm2 and work out the length of the bottle.... then multiply it by the number of bottles.
Then imagine this long column of your favourite beverage and how fast it woul have to travel to get it through the aperture.
Maths and numbers have no purpose or meaning unless you have some feel and understanding for what they mean and represent.
A thousand Qatloos on the newcomer!
Good Answers: 18
09/30/2015 11:00 AM
Hi Del,
I like your analogy of a 1 sq.cm area bottle.
Doesn't that mean the 1 litre bottle would be 1 meter long and the whole thing would be 3500 meters long and would need to pass through the orifice in 1 second. I think that equates to 210,000 meters/minute or 12,600,000 meters/hour which is 12,600 Kilometers/hour.
I tried picturing it and things got a bit blurred.
I would imagine any liquid you tried to do that to would "flash off" due to the heat but that's a whole new ball game.
Best regards,
John.
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
Good Answers: 18
09/29/2015 11:29 AM
Hi moataz,
I must agree with Crabtree, the figures you are quoting are astronomical.
I might be "miles out" but figures of 2100 litres /minute (460 Gallons / Minute) at 420 Bar (6174 psi) is in the region of 1900 kilowatt (2500 Horse Power).
Just looking at 3500 square centimeters piston area at 10 centimeters / second is 35 litres per second (hence my 2100 litres / minute.
As I said I might be miles out and for your sake I hope I am, otherwise you have one hell of a project ahead.
Best of luck
John
09/30/2015 2:16 AM
Insufficient information again. The rpm will depend on the displacement of the hydraulic pump, which has not been given.
09/29/2015 8:37 AM
Re: A Technical Question
09/29/2015 9:18 AM
Do your own homework. CR4 is not a homework cheat site; however, if you have questions about understanding concepts or how a portion of a problem is derived, these types of questions will be accepted.
09/29/2015 9:58 AM
it is not a homework i am graduted from mechatronics department and i am working in a project now and i have forgotten the hydrolic laws and i have some questions and i thought u could help me
09/29/2015 10:56 AM
You have indeed. Well, you ought to be aware that this site doesn't do education catch-ups, so I would suggest you continue your quest elsewhere. We're clearly into Ex-Lax territory here, and I have other things to do.
Good moaning!
09/29/2015 12:50 PM
I like the horse though Mildred
The doctor said "just one post or reply aday in CR4, take it or leave it". I said, "what does that mean?"
09/29/2015 3:03 PM
"I am graduted from mechatronics department"
I believe that Walt Disney coined the term "mechatronics" to describe the animated mechanical devices he used in Disneyland.
So, this must be some kind of Mickey Mouse project you are working on?
Good Answers: 117
09/30/2015 12:24 AM
Sir
as a graduate, you should know where to look to find what you have forgotten!
Be honest, this is homework, and mechatronics... M.I.C.K.E.Y. MOUSE! (I'm not gonna get that tune out of my head all day now)
09/30/2015 7:21 PM
And just exactly where was this ( mechatronics department ) located ?...
09/29/2015 9:18 AM
Power = pressure x flowrate.
PowerOut (ft lb/sec) = pressure (lb/sq in) x flow rate (cu ft/sec) x 144 (sq in/sq ft). Divide by 550 to get PowerOut (hp).
PowerIn = PowerOut/efficiency.
09/29/2015 10:30 AM
Insufficient information given; we need also to know the flow rate.
Theoretically HP = (delta P)(GPM)/1714, but to account for inefficiency you might estimate (delta P)(GPM)/1500.
Hydraulic, not hydrolic.
09/29/2015 1:34 PM
Hmm... Farmer math says,
420 Bar = ~6000 PSI
3500 cm x 10 x 60 = 2100 l/min
2100 l/min = ~555 GPM
rule of 1500 says 1 GPM @ 1500 PSI or 1500 GPM @ 1 PSI = 1 Horsepower
So (6000 x 555) / 1500 = 2220 Horsepower
General rules of hydraulic fluid flow suggest no less than 4 inch dia piping and or port/valve sizing for 555 GPM flow rates and recommends 5 - 6 inch for continuous flow applications.
Well that wasn't so hard.
Personal opinion also suggests buying books like this whenever you can find them.
Pocket Reference Book.
They can even make dummies like me look like real educated, experienced and widely diversified engineers.
10/01/2015 11:54 PM
The OP said he wanted to get 3500 liters in one second, so the volumetric flow rate is 3500 l/sec, not 2100.
To the OP: the formula you have forgotten is simple:
Q = A x V where Q = volume flow rate, A = area of the nozzle or pipe, V is the flow velocity.
The numbers you give are not credible. To get 3500 l/sec through a 1 cm2 opening would require a flow velocity of 114,444.4 ft/sec or approximately Mach 104. Hypersonic indeed. Converted to miles per hour it exceeds escape velocity of the earth's gravity by a factor of three.
If you look up typical flow velocities for hydraulic oil online, you will find a high pressure line might have 25-30 ft/sec. Put that value into the formula I gave you above and you will find you need about 4000 times as much area as you propose. The proof is left as an exercise for the student.
May I also suggest you bookmark www.engineeringtoolbox.com so you can find all the formulae you need there?
10/02/2015 9:16 AM
"i had a pump pressure =420 bar carries a pistone mass=20 ton and its area = 3500c.m2 this pistone moves with velocity =10 cm/s so the motor needed how many horses should be and it r.p.m ??"
I take 3500c.m2 to be 3500 square centimeters which if I was wrong and it's 3500 square meters (to lift 20 tons?)then everything I said would just need to be multiplied by 1000.
Good Answers: 97
09/29/2015 2:38 PM
You can know that a 2" Viking positive displacement pump, without a bypass valve, driven by a 5 hp motor, will continue to develop head pressure against a closed valve, to the point at which the head bolts stretch, fluid sprays out, the motor trips out on overload, then runs backwards until the pressure bleeds off. The guys that put this together were dead heads.
CRTL-Z
09/30/2015 9:37 AM
All i know is that airplanes fly on 1.01 bar and pressure slightly lesser than that.
Canada - Member - New Member
09/30/2015 10:17 AM
I don't know if they are still available, but Womack had a great series of handbooks on fluid power. If you can locate them, they are a great source of information and formulae.
Never stop learning
09/30/2015 5:44 PM
You don't need any if there is no flow. -- JHF
09/30/2015 10:13 PM
I can give you the answer for Camels. If you are interested PM me.
Lots of flow for Mechatronics assignment. There is not a single pump that can do this.
10/01/2015 12:05 PM
I disagree. The huge plunger pumps used for oil formation fracturing can easily do those pressures and flow rates.
10/01/2015 9:30 PM
Note that you said pumps! I have not come across a single pump that can do this flow rate and pressure. And even then 1320 barrel per minute is a big stretch.
Pumped at 6100 psi this is 200,000 HP. You need your own power plant or some very big diesel tanks plus assorted over hundred 2000 HP pumps and CAT engines.
I disagree that you disagree!
10/02/2015 9:09 AM
Okay where are you getting your numbers from?
We've already figured out that the OP's flow rate was ~555 GPM at ~6100 PSI which as I know is well within the working HP limits of a single FMC 5 piston high pressure plunger pump being driven by a 2500 HP Caterpillar diesel engine.
10/02/2015 11:20 PM
From the horse mouth! See here.
Clearly says 3500 liter per second.
We haven't figured a thing in this thread.
10/03/2015 10:37 AM
I took that as he was asking if it was logical not what the power requirements were like in the posts I was referring to.
Register to Reply 34 comments
brich (1); Circuit Breaker (1); Crabtree (2); Fredski (1); IdeaSmith (3); jesw55 (2); Kevin LaPaire (1); Legolaz (2); lyn (2); moataz (4); MR. Guest (1); pdef1949 (1); PWSlack (3); Rixter (1); tcmtech (5); Tornado (2); Unredundant (1); user-deleted-1105 (1)
