Previous in Forum: Fluid Compressibility   Next in Forum: Shaft Rotates Inside Inner Bearing Ring
50 comments
Heat
10/24/2015 3:43 AM
Is heat all electromagnetic? Or just some heat?
The doctor said "just one post or reply aday in CR4, take it or leave it". I said, "what does that mean?"
Pathfinder Tags: heat
Good Answers: 61
Re: Heat
10/24/2015 6:28 AM
Heat is the result of the vibrational, rotational and translational energies of atoms and molecules. When something is "hot" all 3 of these modes are at higher frequencies and speeds. When cooled to absolute zero temperature (minus 273 C), all motion ceases. Heat is not "electromagnetic" but electromagnetic radiation can be used to raise the temperature of matter since certain frequencies (infra-red, ultraviolet, visible) coincide with some of the frequencies of the 3 modes mentioned above and thus energy is absorbed. Conversely, a hot object can lose heat through radiating electromagnetic waves in the infra-red, visible and (if very hot) the ultra-violet region.
This article gives a good summary of the effects of radiation on matter, including microwave radiation:
http://hyperphysics.phy-astr.gsu.edu/hbase/mod3.html
Good Answers: 61
Re: Heat
01/23/2016 10:05 AM
Correction: All motion does not cease at 0 deg. K. Vibrational motion persists at this temperature and substances therefore posses a vibrational zero-point energy.
We live and learn.
Re: Heat
01/25/2016 9:49 AM
zero point energy is not necessarily motion. It is the zeroth quantum state for vibration (example is a simple diatomic molecule of HCl). The energy of this vibration state is above the potential well of the molecule in terms of potential energy vs interatomic distance. The same can also be stated about the rotational quantum states. There is no particular energy to be gleaned here, since the lowest quantized state is the state of the system a 0K.
If there is no vibration-rotational energy in the bottom state, then how is there motion? I keep hearing about zero-point energy, but I am completely skeptical about its importance or relevance to the matters at hand.
Good Answers: 61
Re: Heat
01/25/2016 4:43 PM
Thanks for your response. I quote from "Inorganic Energetics" by W. E. Dasent. He definitely knows more about it than I - so I must defer to him.
Re: Heat
10/24/2015 7:04 AM
Is ignorance all idiocy? Or just some ignorance?
Re: Heat
10/26/2015 10:04 AM
Quantitative idiocy is proportional to ignorance, however the converse cannot be derived.
For example, there is a cure for ignorance called education (whether self-inflicted or not), and has even been tried with some success on prison inmates. The contrapositive is not proven, as there is no cure for idiocy.
Re: Heat
10/26/2015 10:32 AM
Mike, Ignorance is NOT idiocy.
Ignorance = Not knowing the answer.
Idiocy = Not understanding the answer.
We are all 'ignorant' of things until we learn about them. Remember, the CEO if International Business Machines thought that the market for Personal computers would be 'six, worldwide.' We were all 'ignorant' of the power in these devices back then.
Re: Heat
10/26/2015 10:50 AM
As has been stated: no cure for idiocy, or insanity. Both expect to do things the same way and expect different (successful) results.
At least an ignorant scientist (such as myself) can have hope. I can hope to learn what I am ignorant of that is stalling my present research, but I would be a complete idiot to keep doing the same failed experiment over and over (and seeing an output impedance of 100-1000 Ohms), but expecting that "next time" it will work, and I will "magically" get 1 Ohm.
For instance: I was making a thermal battery (recharges using heat). I had some that were demonstrating about 10 Ohms output impedance at 80 C. The problem was the configuration was eventually shorting out the potential against the steel container. (Who told me a steel container was a useful idea in the first place?)
I wanted to try getting the electrodes nearer each other, so I tried some off the shelf battery separator (made for wet cells), that was highly porous thin PP (I won't mention the trade name of the material for obvious reasons). The cells made thus far with this material simply do not work at all, or have really high output impedance (>1000 Ohms). If I was an idiot, I would keep making them the same way, expecting a better result. If I was smart I would go back to what was working, and figure out using the same materials as before (natural fiber) to get thinner electrode separation without shorting, and also use a non-conductive high temperature limit container.
Am I making sense here, or is this mostly illegible babble?
Good Answers: 26
Re: Heat
10/27/2015 12:24 PM
Q:What is the difference between ignorance and indifference?
A: I don't know and i don't care.
Re: Heat
10/27/2015 12:32 PM
You, sir, have hit the target dead center.
I had actually forgotten that old 'two liner' joke that explains the terms so succinctly.
Good Answers: 26
Re: Heat
10/27/2015 12:53 PM
I think that line was from Pretty Woman.
Re: Heat
10/27/2015 1:50 PM
another strike
Re: Heat
01/26/2016 8:55 AM
Both ends at once - double diarrhea.
Re: Heat
10/24/2015 9:37 AM
They are related but they are not the same thing. Everything that has heat produces electromagnetic radiation. The net flow of passive heat transfer will always be from the hotter to the cooler objects. The three techniques of heat transfer we experience is conduction, convection and radiation.
Re: Heat
10/24/2015 11:31 PM
But why not, everything which has heat does not emit its molecular kinetics in the realm of radio, UHF, VHF frequencies' bandwidth, why at some bandwidth in the infrared and above? Quite weird, actually. It must have been directly dependent on molecular dynamics.
Re: Heat
10/25/2015 8:30 AM
You gave yourself a big hint, "Quite weird, actually". Very often when Physics seems weird there is a quantum mechanics effect happening that is making things a little weird.
Max Planck is the one who explained why radio frequencies are not part of the spectrum for a black body. Max's contribution comes in near the bottom of one of the secondary links in that collegiate paper. The mathematics is condensed in those two citations but they are accurate.
Re: Heat
10/25/2015 8:52 AM
Wow, you must have been through to all these. Awesome links by the way.
Re: Heat
10/24/2015 10:22 AM
The heat that comes from my wood burning stove is NOT electromagnetic!
Good Answers: 61
Re: Heat
10/24/2015 10:33 AM
But the heat radiated from it, is.
Re: Heat
10/24/2015 5:54 PM
Good Answers: 18
Re: Heat
10/25/2015 12:58 AM
Please define what "heat" is to you. By my way of thinking the "heat", which traverses space to get from one object to another falls somewhere on the electromagnetic spectrum. Does it not? Ergo it is electromagnetic!
Re: Heat
10/25/2015 8:45 AM
The sub-set of a set is not the same thing as the whole set, even when the other sub-sets happen to be empty in a given circumstance. In thermodynamics, radiant heat transfer can never be an empty set but the other two transfer mechanisms of conduction and convection can be empty sets.
Hobbies - CNC - New Member
Re: Heat
10/26/2015 9:37 AM
Are you sure that someone didn't slip an electromagnet into your stove?
Re: Heat
10/26/2015 9:45 AM
Since the Curie point of iron is about 770°C and wood burns at about 1980°C, one can make permanent magnets with an electromagnet and a cast iron stove.
Re: Heat
10/24/2015 1:49 PM
WHY DON'T YOU LEARN HOW TO USE A SEARCH ENGINE????????
Thermal radiation - Wikipedia, the free encyclopedia
Even someone as dull as you can do it, I'm sure.
Good Answers: 70
Re: Heat
10/24/2015 3:04 PM
There's no hope for idiots. Now, if we could just roll the rock back over the hole he came from, the world would be a better place.
Re: Heat
10/24/2015 9:41 PM
Are you sure about that?
Register to Reply Off Topic (Score 8)
Re: Heat
10/24/2015 9:38 PM
Re: Heat
10/25/2015 6:51 AM
Not any more! There seems to be dull and duller!
Re: Heat
10/25/2015 7:07 AM
No wonder. Hmmm. Gender test might not be essentially done through an ulltra scan.
"It's a girl!, Madam".
Re: Heat
10/24/2015 11:12 PM
How do heat and light reach earth unless they travel in the form of radiation(waves)?.
pnaban
Re: Heat
10/26/2015 8:03 AM
Bob Uecker: "Good afternoon folks, Bob Uecker here,..... and what a wonderful day for baseball, its the top of the 3rd inning, and rookie Lego is up to bat, With lyn on the mound..... Lyn has been spot on all day by throwing a lot of balls.....he's is actually known for that and for being the best in the major leagues with that pitch....."
Bob Uecker: "Lego steps in the batters box, lyn winds up, throws, the rookie Lego swings,.... and ..... OOOHHHHH,.... another ball..... Folks,... that's gotta hurt."
Re: Heat
10/24/2015 9:49 PM
Basically, heat is the motion of atoms and molecules. For a given temperature, atoms and molecules emit electromagnetic radiation. A black body radiates the maximum amount of radiation for its temperature without coloring it, i.e. favoring certain wavelengths, and produces the familiar black body radiation curve.
The amount of radiation is proportional to the fourth power of the absolute temperature and the peak wavelength is proportional to the inverse of the temperature. Objects that are hot enough radiate within the visible light spectrum. Objects at room temperature glow at a wavelength 10-20 microns as can be seen using a thermal imaging camera.
Re: Heat
11/04/2015 9:36 PM
At what distance or wavelength attenuation of sound,light,heat,smell disappear.
pnaban
Re: Heat
11/05/2015 8:12 AM
Smell? really? Are we holding a calf branding this week? Basically one has to be upwind of the calf (and the branding iron) if one does not desire a snoot full of hair smoke.
Re: Heat
10/24/2015 11:24 PM
Just the radiated heat, not the conducted or the convected.
United States - Member - If it broke, then you didn't weld enough metal on!
Re: Heat
10/25/2015 1:52 AM
Perhaps I can explain it so a cowpoke would understand. If you are standing by a branding fire with the hot sun beating down on your neck, the heat you feel on your neck is radiated heat. As you grumble about getting sunburned you reach out and grab the working end of the branding iron. The brief moment before grasping the iron you feel a small rush of hot air into the palm of your hand, this is convection heat. As your hand closes around the red hot iron, and you are getting 2nd and 3rd degree burns, you are now experiencing conductive heat.
You want a little salve with your lesson?
When you feed the bull, remember to watch where you step.
Good Answers: 70
Re: Heat
10/25/2015 2:34 AM
I still prefer Utter Balm for everything except for sheep The greatest thing ever invented is barb wire- saves a lot of un-necessary running, the sheep can't get away anymore
Re: Heat
10/26/2015 10:11 AM
Sheep really are scared in Sacramento, are they not? They look scared.... and that professor is creepy.
Re: Heat
10/25/2015 4:04 AM
I've heard down south many were poked. A burning fire that never runs cold, could be a a form of radiated heat.
Good Answers: 61
Re: Heat
10/25/2015 6:20 AM
Exit stage left - screaming.
Re: Heat
10/25/2015 6:53 AM
Fiction and fairy tales!
Re: Heat
10/26/2015 10:13 AM
Could you please go back to middle school and re-learn American English with an emphasis on what a complete sentence actually is and how to write one?
Re: Heat
10/26/2015 10:10 AM
Nice one! There IS a balm in Gilead! If there were more cowpokes, and less cell phone geeks, the world would be much safer, and more enjoyable with a cold one!
Re: Heat
10/25/2015 8:36 AM
The heat of passion might be due to animal magnetism, but that is not the same as electromagnetism.
Re: Heat
10/25/2015 8:47 AM
Good Answers: 122
Re: Heat
10/27/2015 3:38 PM
Probably not. Due to recent breakthrough discoveries in the scientific world we are on the edge of learning many of our theories and assumed physic laws may be somewhat flawed. It could well be that the presence of heat in some cases might just be the absence of cold. No? Have you ever noticed that when cold is applied to one end of a hot piece of metal the opposite end of the metal sometimes increases in temperature. I wonder why?
Re: Heat
11/04/2015 2:37 PM
Probably whoever is holding the hot end of the metal is now facing neural sensation he was not sensing when the metal was just lying there hot all over, but now he is holding the hot end up, and dipping the cold end in the bucket of cold water, hence the metal seems to be hotter.
Good Answers: 26
Re: Heat
11/05/2015 6:58 AM
Once while doing a study of thermal dissipation on stacks of steel plates (controlled cooling for H elimination) i brought the scans (IR gun) down to near ambient. I noticed that the heat was slowly transferred down the plate like a wave going from one end of the plate to the opposite end. As the plate reached ambient the waves were less pronounced.
Re: Heat
11/05/2015 8:17 AM
So you are saying there exists a transverse wave, or is it more axial in the direction of heat flow?
Register to Reply 50 comments
adreasler (2); Bullfeeder (1); dj95401 (2); energyconversion (5); IdeaSmith (2); James Stewart (10); Legolaz (7); lyn (1); Mikerho (1); Original_Macgyver (1); phoenix911 (2); pnaban (2); redfred (4); Rixter (1); SHOCKHISCAN (1); StandardsGuy (1); SWB123 (1); texasron (3); Tom_Consulting (2); Tornado (1)
