Previous in Forum: Vent::::I Hate O'Reilly's Auto Parts   Next in Forum: Remember that Sinkhole
30 comments
Electro-motive Power Processing In Wheeled Conveyance
10/25/2015 12:48 AM
In a Wheeled Electromotive Transportation Power Process could the drive wheel torque to ampere ratio be optimized by placing the impulse at the rim of the wheel instead of at the axle? This appears to me to be the idea behind the "Pancake Motor."
Would it be possible to keep the required tolerance for efficient electromagnetic interaction between a frame mounted stator and rear wheel rim mounted permanent magnet rotor in a bicycle configuration?
In a transportation cycle (trip) the initial energy input reused in a regenerative capable system would be a function of how much grade braking and speed braking is required.
If the human body is about 25 percent efficient the input energy saved in a regenerative capable system would approximate the total energy regenerated and reused divided by .25. This could be a significant amount in hilly urban terrain.
Could there also be efficiencies realized in averaging power input over the entire transportation cycle (trip) rather than using simple real time demand?
In any self-powered system it seems intuitive that the maximum power requirements on the prime mover, and therefore the required mass and volume fractions dedicated to that prime mover, could be significantly reduced by averaging the power input over the entire transportation cycle.
In the case of a bicycle, Pedi-cab, or other human powered conveyance could an Input Power Averaged Regenerative Capable Electromotive Power Process significantly increase throughput energy efficiency?
I am not suggesting that an electromotive power process in a bicycle could be as mechanically efficient as inputting power using a pedal and a well-tuned chain and sprocket. What I am suggesting is there may be significant efficiencies achieved by processing the system energy throughout the transportation trip.
I have a high level of confidence that riding my bicycle would be way more fun and efficient if the system energy was processed beyond real time power and friction braking dogma. Especially if it allowed me smooth torque control of both pedal crank and drive wheel action.
I believe the maximum energy storage requirements of a Super High Performance Prime Mover Power Averaged Regenerative Capable Transportation Process would need to be no greater than 4 times the kinetic energy of the conveyance at maximum sustained cruise. For an optimized efficiency process this storage capacity could be reduced to about one multiple of sustained kinetic energy.
A Power Averaged Regenerative Capable Switching Locomotive would be cool.
A Power Averaged, Regenerative Capable, Four Wheel Independent No Slip Tractive Controlled Drive/Brake, Super High Performance Convertible Sports Car, with a 600 mile range and no tail fins, would be awesome.
But a Power Averaged Regenerative Capable Bicycle is - well - should be - more affordable and somehow, almost as eloquent.
The relay and commutation circuitry is a learning challenge; especially when considering circuit acceptance control instead of pulse width modulation for power and brake control.
Re: Electro-motive Power Processing In Wheeled Conveyance
10/25/2015 3:01 AM
Speakee Engrish even more awesome.
10/25/2015 11:10 PM
I spent the summer in the Andes and one of the Europeans I met told me that if you spoke more than two languages you are multi-lingual, if you spoke two languages you were bilingual, and if you spoke one language you were an American.
10/26/2015 3:21 AM
LOL!!!
How true!!
10/26/2015 9:32 AM
Its more like if you can't speak even one correctly your an American.
From my understanding, one of the largest if not the largest user of electromotive power for transportation are Railroads. Railroads found it more cost effective to make their grades as close to level as possible and not worry so much about regen braking. (other considerations were at play also) Not sure if the economics remain the same now that we no longer have millions of Chinese and Irish to use as slave labor to build them though.
It's not that we can't build a great pyramid like the Egyptians. Its more like who could afford it in todays labor market?
10/26/2015 12:44 PM
The rail industry has been using dynamic braking for many decades. The most significant difference between dynamic braking and regenerative braking is that the braking energy in dynamic braking is dumped through resistors where as in regenerative braking the energy is stored for reuse or returned to the supply power line.
The rail industry has been using regenerative braking since the early days in electric traction where the power is returned to the electrical supply lines.
In the case of Diesel Electric Traction the energies are too high for practical storage except in switching operations. Perhaps one day this challenge will be met by electrolysis where the products are then used as binary fuel for combustion energy.
Also, there is little advantage to regeneration in steady state operations.
Good Answers: 122
10/26/2015 3:08 PM
FYI: I think pretty much all Electro-Mechanical locomotive engines take advantage of a small amount of regeneration to supplement their dynamic-braking system. It is critical for downhill speed regulation and feedback control to the train braking control circuits. I believe it started in the early to mid 70's but I am not certain. I spent a few months in a General Motors GP series locomotive field repair shop a while back and there were several locomotive engines that came in for service and repair that had such a system on them. My part of the picture was on the automation and remote control side so I did not get into the braking systems very deep. The reason for low percentage railroad grades is because the engine wheels do not have enough surface area contact to overcome the reverse pull of gravity when going uphill and the axles/wheels will just spin in place if the grade is too steep. There are sanders on each engine wheel that automatically apply clean sand when wheel spin is sensed. Going downhill the train depends mostly on the surface contact of the loaded train cars for braking traction with the engine dynamic brakes needed but being supplemental only.
10/26/2015 9:12 PM
The coefficient of static friction between wheel and rail is independent of surface area. The limit to tractive effort on tangent track is a function of friction coefficient, weight of the locomotive, cosine of the grade angle, power, and knuckle strength.
In non-distributive power applications the limiting variable is knuckle strength.
Is it possible the regeneration that you are referring may be for self-excitation of the excitation field used by the motors during dynamic braking?
Good Answers: 122
10/26/2015 1:25 PM
Well said!
10/26/2015 3:19 PM
Your European friends have nailed it. Never met a foreigner yet that couldn't at least try to speak English to me.
Seeing your location is E. Texas, I assume you are bilingual. You speak English and Texan don't you?
10/25/2015 3:52 AM
I lost my way today, or ,may be not so lost, someday, some way, ever after, ever more.
The doctor said "just one post or reply aday in CR4, take it or leave it". I said, "what does that mean?"
10/25/2015 11:06 AM
Torque is something the load presents to the motor. Motor power is torque multiplied by angular velocity so in principle whether the motor is on the rim or on the hub matters not a jot. For power demand is rate of change of potential energy plus losses due to friction, which is a function of where the machine is and how its speed is changing. Introduce a gearbox and one inevitably introduces losses.
10/26/2015 10:58 AM
--------"Motor power is torque multiplied by angular velocity so in principle whether the motor is on the rim or on the hub matters not a jot."-----
Thanks for taking the time to reply. Please be patient with me.
The question was - "In a Wheeled Electromotive Transportation Power Process could the drive wheel torque to ampere ratio be optimized by placing the impulse at the rim of the wheel instead of at the axle?"
When I look at the definition of "Moment of Force" I find - "A measure of the tendency of a force to rotate the body on which it is applied. Measured by multiplying the magnitude of the force by the perpendicular distance from the line of action of the force to the axis of rotation."
Since the magnetic force acting on the rotor (magnets in the wheel rim) is going to be directly proportional to the current flowing in the stator coil and the moment of force (torque) is directly proportional to the distance from the axis of rotation; if follows that the amount of current flowing in the coils of the stator for each unit of torque will be inversely proportional to the distance from the axis of rotation.
This does not contradict your statement that Power = Torque * Angular velocity it merely extends that to Power = (F * r) * (angular velocity).
For any given amount of torque the required force (and thus stator coil current) decreases as r increases.
In terms of electrical power Voltage * Current = (F *r) * angular velocity
Does this appear to be an accurate assessment?
Any correction or other shared knowledge would be greatly appreciated.
10/25/2015 12:40 PM
I'm almost too tired to answer after reading all that...
I suspect gears are a more economical way to increase torque since most manufacturers use that method.
As for regenerative braking on a bicycle, I'm not sure it's worth the extra cost. I have an electric bike, and I can't say I use the brakes very much. The air drag on a bicycle accounts for most of the drag, and of course, that is not recoverable.
Here is an analysis that indicates that regenerative braking may not be worth the cost...
http://static1.squarespace.com/static/530f94cde4b0f38aa20cfad0/t/54e28e20e4b05ae6226b267f/1424133664794/regenbraking.pdf
10/25/2015 7:13 PM
10/26/2015 11:52 AM
Thank you for your link.
The analysis of an electric bike power usage and losses was quite interesting.
The proposed bicycle is not an electric bicycle in the conventional sense. It is a human powered bicycle that is trading off the efficiency of chain and sprocket for the advantage of electro-motive processing of trip cycle throughput energy.
The storage type described in the link as well as the regenerative efficiencies are not typical of the conceived process where the required amp hour storage is some small fraction of an electric bicycle and thus allowing for the adaptation of super capacitance for the storage medium. This greatly increases the power density in storage acceptance resulting in higher braking force as well as reducing the mass and volume fractions dedicated to storage.
Also; the efficiency of the prime mover, in this case a human is a huge factor in determining required energy input for any highly variable trip cycle.
Let us consider a prime mover that is 25 percent efficient in converting fuel to work.
In the case of an Internal Combustion Engine for each Joule of applied work 4 joules of combustion energy must be consumed. It then follows that for each Joule of energy regenerated 4 units of combustion energy is saved. This is NOT over unity; it is simply the relationship of prime mover efficiency to regenerated energy where energy not consumed approximates the energy regenerated divided by the prime mover efficiency factor.
10/26/2015 12:16 PM
I think you're saying the biker pedals all the time and charges super capacitors to help on climbing hills. Whether this would be easier on the rider, I don't know. There will be some loss involved in this process.
As far as motor vehicle application, I believe this is the principle behind hybrid cars, to run the engine at the most efficient speed and store the energy in batteries.
10/26/2015 12:47 PM
Current hybrid automobiles are parallel processes that put real time demand on the prime mover. As far as I know there are no manufacturers using power averaging in a series hybrid configuration.
10/26/2015 3:35 PM
Depends on the physical type the biker is. In cycling there are 2 main types of cyclists. Those that are very good at pedaling at a high rate for hours on end (mountain climbing specialists, and time trial specialists) and those who are much better at very high energy outputs for short time periods with rest in between. (sprinters) Basically the fast twitch versus the slow twitch fiber issue, which is very much observable in bicycle racing. Nairo Quintana versus Mark Cavendish for those familiar with the sport.
The proposed system would favor the climbing types, and definitely not me. Give me some rest periods between pedal sessions, please.
10/28/2015 3:05 PM
"Give me some rest periods between pedal sessions, please." -
Not a problem. The process allows for inputting and storing excess energy above the programmed constant.
In your case you would choose both the angular velocity and torque of input when you wanted to input VS the terrain or other variable making that decision for you:
The process is designed to accept excess storage energy - with in reason.
The total energy state being monitored as a function of Gravitational Potential, Kinetic Energy, and stored energy.
10/25/2015 12:43 PM
There are electric bikes with regenerative brakes, the problem is we need variable regenerative capability for greater efficiency....
https://www.youtube.com/watch?v=Rky9cX_-roI
https://www.electricbike.com/regenerative-brakes/
10/26/2015 12:22 PM
Sweet picture !!!!!!
--- "There are electric bikes with regenerative brakes, the problem is we need variable regenerative capability for greater efficiency...."
Thank you for your reply. I wish I could upload jpeg files but it just doesn't work for me.
I believe that in most regenerative capable systems storage acceptance rates are the greatest challenge in recovering energy from hard braking.
I would think that variable braking force could be accomplished by using pulse width modulation or "reactive" control. If the required component parameters for a "reactive control" method are available then it would significantly reduce the switching losses that I believe to be associated with pulse width modulation.
I have been working on a simplified circuit diagram for quite some time. This circuit diagram attempts to describe a "reactive control" method for both power and regenerative braking and I will put it out as soon as I am ready to be devoured by the brain zombies here and have figured out how to upload a picture file. I have no delusions as to its practicality as it currently exists; it is intended to be a used solely to stimulate technical discourse.
The "art" that I have been attempting to upload as part of this thread has a circuit as part of the picture but it is there only to show that the process involves electronic control methods and is nothing close to the descriptive simplified circuit diagram. The "art" is a graphic description of the overall process.
Any ideas on how I might be able to get the jpeg file uploaded?
10/26/2015 2:00 PM
Yes just click on the camera icon, and choose file...the file should be located in your computer somewhere I'm guessing..It should be saved in pictures or downloads or documents..what browser are you using....Chrome seems to work well...Tell me at what point you get stumped...
10/26/2015 8:59 PM
Thanks for your help Eagle.
I follow the icon, navigate to the JPEG file, and then choose "submit" and it acts like it uploads but does not show up on the site.
I have no idea why this is happening.
10/26/2015 11:31 PM
Does the file you've selected show up next to the "choose file" before you click 'submit'?....and is the file type .jpg ? as you see above 'archemedies sphere.jpg' as an example....
10/28/2015 2:41 PM
Yes. but it still won't work.
10/28/2015 2:52 PM
GOT IT _ Thank You Eagle !!!!! I used Chrome instead of IE.
10/28/2015 4:20 PM
You might have to post several pictures one section at a time... You can edit your pictures in any graphic program like "paint" ....perhaps increasing contrast for darker lines, and cutting redundant sections off the pictures....shoot the pictures directly over the surface for proper perspective ...Well done!
Good Answers: 122
10/26/2015 1:40 PM
It maybe possible however using current available methodology and equipment to capture, store, and release the regenerated energy would add far too much weight to the bicycle or other craft therefore minimizing or totally defeating any efficiency gains.
Below there is one of the many links to sites that display supposed perpetual motion generator technology all of which is a takeoff from Tesla's research notes.
If this is indeed "real"; I would assume this would be the direction to pursue in adapting this technology onto the wheels of the craft to maximize energy efficiency.
I personally think we are on the verge of some very big breakthroughs in this field of R&D.
http://www.dailymotion.com/video/xeujwp_best-perpetual-motion-electric-gene_tech
11/02/2015 10:54 PM
I am having a very hard time in finding the inductance of a typical electric bicycle motor.
Anybody have any ideas?
04/14/2017 12:32 PM
An Introduction to Reactive Proportional Control Theory as applied to Series Hybrid Electromotive Power Processes:
Reactive Control optimizes the physics of series resonance and is scalable from Bicycles to Locomotives; with applications in many other proportional control processes.
In a human powered bicycle or pedi-cab application, instantaneous power output of the prime mover approximates the force on the pedal * length of the crank arm * angular velocity of the crank. Those physical relationships remain the same; but that is where the similarities end.
Power provided by the prime mover is converted to electrical energy via an alternator and fed to a storage capacitance. Depending on the application this output AC is first fed to a high ratio transformer before a full wave rectifier and then into the storage capacitor.
Torque demand on the prime mover is controlled by varying the admittance of the Power Circuit. (1/z where z is circuit impedance) The torque demand on the prime mover is inversely proportional to Power Circuit Admittance (1/z). Maximum torque demand is greatest when capacitive and inductive values are at resonance with the generator frequency. The input frequency is defined by the rotational speed of the prime mover crank and number of magnetic poles in the generator.
The Power Circuit admittance is controlled by the operator via a variable control capacitance, inductance, or both. When combined with temporary storage this removes real-time demand on the prime mover and allows the operator to input power at any point in the trip; regardless of terrain or other variables. Peak demand is met by capacitated energy and can far exceed the peak power output of the prime mover for short periods of time.
This power production method also eliminates all mechanical linkage between prime-mover and drive wheel(s).
Power for propulsion is drawn off the storage capacitor based on real time demand; and regenerated brake energy returned to storage. The same proportional control methodology is used in the propulsion and regenerative braking circuits.
Below is the familiar equation for RLC series resonance. As stated above; maximum torque demand on the Permanent Magnet Alternator (PMA) occurs when the PMA output frequency is at resonance with the charging circuit. f=1/(2π√LC in HZ or ω=1/√LC
Register to Reply 30 comments
Andy Germany (1); Gavilan (13); Legolaz (1); Phys (2); PWSlack (1); rashavarek (1); Rixter (2); SHOCKHISCAN (3); SolarEagle (5); Tornado (1)
