Previous in Forum: Kitchen Exhaust   Next in Forum: Name of Corrugated Teflon Bellow Flange?
26 comments
Pipe Hanger
12/13/2015 6:29 AM
In my current project, I observed the piping contractor hang the horizontal pipes consist of cast iron sewer pipe, uPVC rain water downpipe and uPVC sanitary pipe (all 4" dia. above) on an angle bar with an U-bolt on top to hold the pipe in position. I understand that this is not a proper installation because it will concentrate the weight to one (1) point at the bottom of pipe. Normally, using a swivel ring or clevis hanger shall be the correct practice. With the wrong installation, what would happen in long run ? Anyone can share me your experience ? Thank you.
Pathfinder Tags: hanger Mechanical Pipe
Re: Pipe Hanger
12/13/2015 9:40 AM
Did you ever consider another line of work?
One in which your complete lack of knowledge would not be such an impediment?
Did you ever consider consulting asking local agencies???
Did you ever consider that the contractor probably knows much more than you do?
Hangers - Support Spacing and Rod Size for Horizontal Pipes
pipe hanger spacing & weight chart - Guenther Supply, Inc.
Good Answers: 181
Re: Pipe Hanger
12/13/2015 2:54 PM
At least he's not messing about with electricity now.
Although he would be better suited to
Re: Pipe Hanger
12/13/2015 9:55 AM
Lyn.. you can be quite the booger.
Way to harsh the young man's mellow.
I assume you've never been a teacher or a manager.. At least not a very well respected one. And no.. Fear doesn't count as respect.
To the OP. It's very dependent on spacing if there will be an issue. If the hangers are close together it's a non issue. If the hangers are too far apart sagging and breakage become a possibility regardless of the style used.
Lyn. I don't think the decaf is working. (how's your mellow)
Re: Pipe Hanger
12/13/2015 10:17 AM
Take a look at OPs history. Every time he has come here it is to ask the forum to do his work for him. He's questioning the work of a contractor whose job it is to hang pipe.
The answers to all his questions can be found in code books, reference books and, when all else fails, on the internet by a SIMPLE SEARCH!
Or he could simply let the contractor do their job.
This person is being paid as a consultant. He should have the gumption to find the correct sources himself.
I an hear the conversation with his boss.
Boss: "What made you think the hanger spacing was wrong? On what did you base your determination? Local codes? National codes? Best industrial practice? Your experience? A pipe suppliers guidebook? An industrial manual? A text book? The pipe suppliers recommendations?"
cckla : "Well, no. I got it from some anonymous person, on an anonymous web-site called CR4 on the internet, so I must be right."
You did see that I included two links to sources which may have been of help to the uninitiated. My bet is that neither of you did, or will, look at them.
You? You provided an unsubstantiated opinion. "Close together" and "too far apart" hardly qualify as any guideline for pipe hanging.
If the truth hurt his feelings, too bad.
Re: Pipe Hanger
12/13/2015 11:07 AM
You've fallen into the grey realm of being right and wrong. You correctly answered the question the OP should have asked. What they actually asked is what could go wrong with a bad pipe hanging and not how to correctly hang pipe.
The problem with answering such a basic question is two fold, not enough information provided and if one has to ask such a simple question I wonder if they'll understand the answer. I'll give it a try.
Failing to properly hang a pipe will have two basic failures:
  1. The pipe and/or hanger support fall. When they fall they may damage people or other structures on the way down.
  2. The contents inside the pipe will now be exposed. It now depends on what is inside these pipes to say if this is a nuisance or a catastrophy.
Re: Pipe Hanger
12/14/2015 5:44 AM
Sure I know what I am questioning here. I am not here to ask stupid question as Lyn always thought. Actually I more keen to know whether any defect will happen on the pipe in long run. The pipe support rods are suitable from not causing it to drop.
Re: Pipe Hanger
12/14/2015 7:21 AM
I'm glad you know what you are questioning, I don't. That is a failure to communicate.
It seems that your worries are not about things falling. That eliminates part 1. Your defect concerns do not address if the pipe defect will expose the contents. You're ignoring part 2.
I'm again reminded of a quote from the satirist, Tom Lehrer. "I feel that if a person can't communicate, the very least he can do is to shut up."
Re: Pipe Hanger
12/14/2015 5:21 PM
(the grey realm of being right and wrong)
Yes, right, about the OP. You can lead a horse to water, but you can't change his spots. His problem can't be fixed with duct tape.
Wrong for offering any help, at all.
I pity poor GW, who offered exactly what the OP had already described as an unacceptable mounting design to him. No good dead goes unpunished.
I'm left wondering how people such as the OP seem to always run into the simple problems they face and yet can never solve them. Never mind how they stay employed.
Apparently, close together and too far apart are good enough for some employers.
Good Answers: 42
Re: Pipe Hanger
12/14/2015 6:21 PM
Don't pity me - I figured the OP hadn't googled anything, was not familiar with the scope of what was currently offered as standard hanging devices, and had not been around the block too often. All I was trying to do was point out "see, there is what they are doing - it is off the shelf mounting".
The OP kind of reminds me when we got a new CSA inspector literally fresh out of school. She (trying to not sound prejudicial) did the factory tour and immediately pulled our tickets because our hydraulic crimpers for 0000 TEW wire did not have a sticker saying they were approved for the lugs and cable we were crimping (it was at a transition time between when crimping tools originally were not "certified" for a particular crimp barrel and wire). We had pull-out test records, polished cross sections etc, etc. She would not bend. I was livid - I had her sit down and I called her boss - He talked with her in private, the phone was returned to me and he explained she was inexperienced and our facility was setting the industrial standards. Red faced she handed the tickets back to us and we never saw her again.
I try not to rise to the bait so fast anymore - it just labels me as a crotchety old man now.
Re: Pipe Hanger
12/14/2015 7:00 PM
I accept the label.
Don't get me started on calibration and government inspectors.
We used a lot of certified two part epoxies in a past life of mine. Military/NSA satellites and all. It took my boss and me two years to get mixing, repackaging and freezing these materials accepted as Ok for flight use. Never mind that freezing effectively slowed the chemical reactions of the materials. Now companies sell these materials pre-"everythinged".
Then there's calibration of triple beam balances. Never mind that the guys using them were not certified.
Good Answers: 42
Re: Pipe Hanger
12/14/2015 7:20 PM
Perhaps they should have been certified---
Reminds me of another story about a man getting killed in an industrial fire - the man stood there and watched the fire engulf himself. If he had so much as sauntered away nothing would have happened to him. He had "frozen" in place.
Turns out he had recently been released from a psychiatric hospital - but you cannot ask that on a job application or interview. My friend was the plant manager, and around here when an employee is killed on the job site manslaughter charges are automatic. It put him through hell for a couple years until the courts determined due diligence had been taken. Unfortunately in these cases the burden of proof appears to be with the defendant and not the crown proving there was lack of due diligence.
OK, you've got me going again...
Re: Pipe Hanger
12/13/2015 11:09 AM
..not an unsubstantiated opinion. I've enjoyed running a licenced electrical contracting business in chicago where things of this nature are done by the book.. Which i have read.
It's a common sense question that deserves a common sense answer.
You did so well by providing the link.
It's interesting how you pick and choose when and who will be given your unbiased support, but not that interesting.
Re: Pipe Hanger
12/13/2015 2:59 PM
Did the contract specifications say anything about this beforehand?
Re: Pipe Hanger
12/14/2015 5:35 AM
No. Even the consultant also have no comments on it. But in my opinion, the bottom of pipe would face a concentrade force due to the weight of the pipe + water. I just wonder whether the pipe would deflect or last long in this condition. However, the pipe are hang in 2m apart. May be this would help.
Re: Pipe Hanger
12/14/2015 3:40 PM
In that case it cannot be "wrong" from the perspective of paying the contractor who is installing it. The cock-up lies further upstream through the organisation (is that word accurate? - rhetorical question - NNTR) not having any standards against which a contractor can lay pipe and a judgement can be made.
Good Answers: 42
Re: Pipe Hanger
12/13/2015 11:46 PM
Do you mean like this?
http://www.gshangers.com/pipesupportdetails.php?supid=26
Most "googled" hangers appear to wrap the bottom of the pipe, but some don't.
Your described arrangement also appears to be an accepted method - but beware - I'm an EE, not mechanical.
Good Answers: 203
Re: Pipe Hanger
12/14/2015 12:25 AM
As some others have alluded to, your information is insufficient to give you a reasonable answer. What size angle is being used (width of each side, thickness of the sides), the span of the piece of angle, size of rod that it is hung with (rod that is too small in diameter will fail before the angle) the spacing of each pipe to the adjacent pipes, is there going to be expansion of any of the pipes, length of the angle, the height of the ceiling and the height of the angle, etc.? Another thing is what does code say? Are there any other codes that might also apply to this?
Why is the contractor using angle instead of Uni-strut (sp?) channel? Although more expensive it's use is much quicker in time and choice of configurations for mounting the pipe. Who said that the angle was "not a proper installation"? The Unistrut (also called Kindorf (sp?) and several other names) channel has numerous pipe mounting types, some of which will support the pipe for the complete bottom half of the pipe. Is that what your concern is? If so why wasn't that specified in the original RFP?
Good Luck, Old Salt
Re: Pipe Hanger
12/14/2015 6:05 AM
Yes. My concern is mostly pipe hanger manual use hanger which covers most of the part of pipe for firm holder and load discipation. There must be reason why pipe not mounted on a flat surface. My question seems simple but in term of engineering, there must be a more convincing explaination.
Good Answers: 266
Re: Pipe Hanger
12/14/2015 9:20 AM
Those pipes could be buried in the ground a flat surface. All the weight would be on the bottom. Plus any weight that would inserted on the pipe from the soil above. No one questions this practice.
I have seen pipes run in buildings like this many times with no problems. Either on perforated angle or unistrut bound with U bolts. With multiple runs it's usually faster and materials cost less.
When a single pipe is run hangers are used. Still most of those are just a saddle the weights still on the bottom.
Good Answers: 26
Re: Pipe Hanger
12/14/2015 7:40 AM
A simple CALCULATED strap on the bottom of the pipe. Geee!
Good Answers: 122
Re: Pipe Hanger
12/14/2015 10:49 AM
Not sure where you are located however the following apply:
Size of clamp/hanger, size of u-bolt, type of hanger & bolt assembly, and hanger/clamp spacing are dependent on:
1) Diameter of pipe.
2) Pipe wall thickness.
3) Weight of fluid being conveyed through the pipe.
4) Anticipated moments of inertia and resultant induced vibration/pipe movement.
5) Ambient environment conditions. (Temperature, humidity, caustic or acidic, etc.)
All pipe hanger manufacturers provide application tables and very acute information pertaining to installation of their systems.
It is in your best interest to determine the hanger/clamp assembly Original Equipment Manufacturer (OEM) and consult their applicable table(S) to discern whether the installation meets all requirements.
If you are unsure about any of the process variable values and/or mechanical loading variables and/or ambient conditions that could affect the stability and safety of the installation, I suggest you hire a competent mechanical engineering company to examine the process specifications and installation for the purpose of minimizing liability and risk factors.
Good Answers: 19
Re: Pipe Hanger
12/15/2015 2:54 AM
To try to answer the original question, the concentration of weight over that short a length of pipe (2m) on the pipes described seems unlikely to produce any over stress in the pipe itself. With high pressure it might be different.
Many of the failures of rain water down pipes occur at the joints and not in the main pipe (except for external pipes which can receive blows from cars etc). I have seen failures on construction site rainwater pipes and this was due generally to too few hangers and especially not near the bends. There is a considerable horizontal and vertical force at these areas due to the change in direction of the water and the head of water. The obvious consequence is a flood.
As far as I am aware, the waste water pipes suffer from head pressures when blocked. A it more messy if that were to blow. I've not seen any of this as I am involved with the construction side.
One of the reasons for collars is also to prevent horizontal movement which would mean misalignment of the joints and the higher likelihood of a leak.
omw7
Good Answers: 76
Re: Pipe Hanger
12/15/2015 5:39 PM
Run the calculation to identify the force required to either reach initial yield or change the diameter of the considered cross-section in a vice. If you don't have it, get yourself a copy of Roark's Formulas for Stress and Strain.
Then ask yourself, under worse-case operational conditions, will the pipe ever see that kind of loading?
Good Answers: 42
Re: Pipe Hanger
12/15/2015 6:05 PM
Sheesh - you expect a calculation?
Re: Pipe Hanger
12/15/2015 6:26 PM
Here's one, based on what the OP knows.
2 meters of pipe weight + 2 meters of water weight ÷ support surface area.
The first two numbers are easy. It's that third one that's tough.
Maybe there's help:
Good Answers: 42
Re: Pipe Hanger
12/15/2015 6:33 PM
I guess OP never tried to break/bend a piece of that pipe!
A Mech Eng once told me "make a conservative guess" - you're probably pretty close.
Funny - he was mostly right - if I thought it was close - it definitely required calculations.
Register to Reply 26 comments
cckla (3); GW (5); JavaHead (1); JE in Chicago (2); lyn (5); old salt (1); omw7 (1); ozzb (1); PWSlack (1); redfred (2); SHOCKHISCAN (1); texasron (1); TonyS (1); Tornado (1)
