Previous in Forum: Power Plant Tripping Due to Load Fluctuations   Next in Forum: Micom P63X Differential Relay Setting Calculation Derivation
10 comments
Energy Meter Reading Coefficient Factor
01/03/2016 12:24 PM
Dear Experts
What will the coefficient factor for a 3Ph energy meter which is designed for CT 400/5A but it is using with CT 150/5A?
And what will be the coefficient factor for a 3 Ph meter which is designed for CT150/5 but it is using with CT 400/5A?
Thanks & Regards
Re: Energy Meter Reading cofficent factor
01/03/2016 12:54 PM
Depends on the ratio of garbage in to garbage out!
Algebraic Expressions - Jamesbrennan.org
ELECTRICITY METER READING
Do not pass go, do not collect $200.00. Go back to square one and start over.
Reply Score 1 for Off Topic
01/03/2016 1:35 PM
Experts? Here? X-spurt you mean. X is an unknown quantity and spurt is a drip under pressure.
Good moaning!
Good Answers: 181
01/03/2016 4:01 PM
X also equals a has been.
X wife (we'll not follow that path)
01/04/2016 4:44 PM
Almost got it - that's an old joke and it goes:
Definition of expert - a has been drip under pressure.
01/03/2016 2:05 PM
Exchange the CTs and skip the arithmetic?
01/03/2016 2:20 PM
A power meter multiplies the current times the voltage to give power. Current is measured using current transformers (CTs). A current transformer converts the line current to a lower current which is fed to the power meter. CT 400/5A means that a line current of 400 Amps is converted to 5 Amps, a factor of 80:1. So you can do the math.
Good Answers: 181
01/03/2016 4:06 PM
Where did these experts come from? I thought this was an after hours drinking club.
OK, maybe that's where the ex-sperts came from.
01/03/2016 4:43 PM
This information may be found by:
  • Looking in the instructions that came with the equipment
  • Ringing the equipment supplier's Technical Helpline
  • Looking on the equipment supplier's website
and in that order.
Re: Energy Meter Reading Coefficient Factor
01/04/2016 8:33 AM
We do not do math home work for elementary school students.
Ask someone with more advanced math skills;perhaps a 2nd grader to help you.
If not,go sit in the corner.
Good Answers: 122
01/04/2016 9:56 AM
Here is the first step to solving the equation:
400:5 CT => 80:1 => For every 80 amps of current flowing through the CT primary there will be 1 amp of current flowing through the secondary.
150:5 CT => 30:1 => For every 30 amps of current flowing through the CT primary there will be 1 amp of current flowing through the secondary.
400/150=>2.6667 (Metering error ratio caused by using a 150:5 CT instead of the required 400:5 CT.)
1) If meter reading is 120KW then 120KW x 2.6667 => correct/actual power reading
150/400=>.375 (Metering error ratio caused by using a 400:5 CT instead of the required 150:5 CT.)
Apply required math steps to solve equation.
Crabtree (1); HiTekRedNek (1); lyn (1); Phys (1); PWSlack (1); Rixter (1); SHOCKHISCAN (1); TonyS (2); Tornado (1)
