Previous in Forum: Engine Runs without Air Supply   Next in Forum: Replacing Formed Channel with Rectangular Tubing
12 comments
How to Design a Shaft With Low Deflection and Twist?
02/25/2016 9:59 AM
how to design a hollow shaft to hold and rotate a component by belt and pulley assembly which is to be ground.shaft is to be hollow because internal spindle passes through this hollow shaft to grind the component internally.after internally grinding ,external grinding is performed.please help me in designing this shaft.also what type of bearing to be used,how many bearings to be used.?my component internal dia is 342mm and external component is 350mm.
Good Answers: 183
Re: how to design a shaft with low deflection and twist?
02/25/2016 10:25 AM
It is not clear - at least to me - what you want; make a sketch so that we can better understand. Any way you will need preloaded bearings. Give as well the part weight it helps to see better what is your need.
02/25/2016 10:39 AM
"Every couple has its moment" - Anon.
It is not possible to carry out design based upon the information listed. Is there some sort of fear about listing everything the forum needs to answer the question, for some reason?
  • For example, it is impossible to determine whether the assembly is made of ultra-high-molecular-weight plastic, or mature cheddar cheese.
02/25/2016 11:34 AM
Who ground the cheese?
02/25/2016 12:14 PM
He is trying to create a CNC machine from the ground up - 1 post at a time.
02/25/2016 2:01 PM
No, he's wants to design this. That's different than creating it. A whole other thing is verifying that it works as designed.
02/25/2016 2:51 PM
Actually, to be correct, he wants US to design it. He is just the great idea guy.
02/25/2016 3:14 PM
Stop talking about me? I'm the original great ideas guy
02/25/2016 4:53 PM
Amazing, isn't it?
02/25/2016 3:10 PM
1 post piece at a time.
Johnny Cash did it.... there were even songs written about it....
02/25/2016 4:06 PM
Trying to design a custom CNC machine from scratch with technical design support from an online forum isn't going to work, and not just for the reason that we don't think what you are trying to do is either practical or economical (machine large bullet shaped sintered silicon nitride blocks no less).
Perhaps if you answered our previous questions regarding what you are trying to accomplish and why we could offer suggestions, but we are not going to help you try and build something as complex and potentially dangerous as a CNC machine when you don't appear to know how yourself. It isn't practical or safe.
02/25/2016 6:19 PM
Make it really short and/or heavy-walled.
02/25/2016 7:13 PM
You are incapable of designing this.
Give up.
Quit.
Cease.
What you want the forum to do is read your mind and then render that into an intelligent design.
Unfortunately, the source (your mind) is lacking adequate information.
Good luck!
Register to Reply 12 comments
Anonymous Poster (1); jack of all trades (1); Kilowatt0 (2); lyn (1); nick name (1); phoenix911 (2); PWSlack (2); redfred (1); Tornado (1)
