Previous in Forum: Taxpayer Funded Fiber Internet   Next in Forum: All Bent Out of Shape
34 comments
Panama Canal Expansion - Drill Rig
04/05/2016 2:50 AM
The other day I saw a documentary on the Panama Canal expansion project. I was quite intrigued with the barge/drilling rig they used to drill holes for explosives. It has four cranes that are extended off the barge to drill, as the water is too shallow to approach the bank to closely.
I am a Meccano/Erector collector who also sometimes gets around to building models. Having previously built a sea exploration drilling rig off a phote, I am considering this as a project. However, the detail on the barge and drilling rigs are not readily available. Google has some photos, but these are from a distance and tend to be from one side only.
Anyone out there with an idea of where I can get more pictures or ideally a diagram and some specifications?
Thanks
Andries
Re: Panama Canal Expansion - Drill Rig
04/05/2016 3:23 AM
I would Google everything I could. For instance, you may have already searched on "Panama Canal Expansion". From there, look for any company names, and Google those. If they have any Web sites bragging about their abilities, they might also have some decent pictures. I don't know the name of the Panama newspaper, but that might be another source of photos. Good luck in your searches; this seems a fun project.
04/05/2016 4:51 AM
I keep on getting pictures of the barge from the one side only. I can see the 4 derricks, the 4 pins and the drill house, but no detail on the drill side. I am quite interested in how the derricks are moved away from the barge.
The people claiming to supply the drilling equipment only show their standard drill rigs and indicate that they can build special equipment, but nothing specific on this rig.
Andries
04/06/2016 1:23 AM
"I don't know the name of the Panama newspaper"
It's called the Panama Papers.
It's in all the papers.
Floss or die!
04/05/2016 7:34 AM
try searching for 'suction cutter dredger' and variations of.
04/05/2016 8:20 AM
Interesting fact: To travel from the Pacific Ocean to the Atlantic Ocean you have to travel in a westerly direction through the Panama canal.
Good Answers: 151
04/05/2016 2:06 PM
Continuing this off topic reply: If global warming continues on schedule, will we even need a Panama Canal?
04/05/2016 11:02 PM
Only if there is a warming that also comes with a heavy sea level change.
04/06/2016 6:49 AM
or if the oil price stays low. Quite a few non time critical cargoes are now bypassing the panama & suez canals as the fuel to go the long way round is cheaper than the fee for the canal.
04/11/2016 12:15 AM
hi greg, haven't seen you post for sometime now. nice seeing you here.
formerly Legolaz
04/11/2016 12:27 AM
04/05/2016 3:25 PM
04/05/2016 3:36 PM
04/05/2016 3:45 PM
At least two different rigs are depicted here, and, as the OP mentions, all from nearly the same side. The bases of the latticework frames are all concealed, so I can't tell what is at the bottom, but it doesn't look as though anything articulates. My guess is that they are always vertical (except for slight list of the whole barge).
04/05/2016 3:43 PM
Are there any web cams for this project? The New NY Bridge, as the replacement for the Tappan Zee bridge is known, has construction cameras. Local cameras might give you additional angles. Along the same line of thought, you could search for amateur photographs from people who've seen the drill rig in person. Or find someone who's willing to take some pix for you.
Is there a list of the contractors? If so you could get in touch directly with the rig's operator ... as long as it's not considered industrial piracy the owner/operator might send you some pictures. Good luck and remember to share with your CR4 community!
04/05/2016 4:21 PM
04/06/2016 1:39 AM
Meccano - Wikipedia, the free encyclopedia
If you build it, can you send us photos as the project progresses?
It would be very interesting to see.
04/06/2016 2:15 AM
Thank all of you for the images - I got the same lot with my searches. The best I got was on wikipedia - Thor_Barge_in_Gailard_Cut.jpg This picture does show the derrick side in somewhat more detail. If I could just lay my hands on a schematic drawing or contact someone who worked on this barge!
As I understood from the TV programme, the drills extend over the side. What I am interested in is: Once the barge is stable - do they extend further out, or remain static and drill down. The latter would be easier, but if they extend, replicating the mechanism will be very interesting.
I will gladly post pictures, but my rate of progress is not likely to be very fast - PhD overdue, full time job, list as long as my arm from the wife, ..
04/06/2016 5:22 PM
04/06/2016 5:38 PM
That pic should help the model quite a bit. Good detail there.
Good Answers: 153
04/06/2016 6:29 AM
Go onto Google Maps and zoom in on the Panama Canal about 1km south, south east of the town of Gamboa. Flip to Earth and at least one of the barges can be seen in plan view on the south west shore of the Chagres River. Click on imagery and scroll through the images. There are images showing the rig vessel Thor and the other rig vessel from the side you have not been able to view. There is also an image of the dredger that you can see in the Earth overhead view about 2-300m along the river.
04/06/2016 8:23 AM
Just saw the photos SolarEagle posted. if you can model that, you're very good. I am trying to model a blending plant at a refinery on my HO train layout. I need that kind of skill - care to help?
04/06/2016 11:08 AM
Some of the guys in the Meccano Club of South Africa are brilliant at making models that are hyper realistic. One guy built a replica of the wire strandin machines his company operates, another did a full deep shaft mine, staring with the head gear, crusher and ending with the refining section, still another takes CAT brochures and replicate yellow iron.
I can simulate the blending plant and if you are close enough would love to help, but, the list .....
04/06/2016 11:32 AM
Yeah...until they develop teleportation the distance is a bit much.
I have done the well sites very closely, and in HO, where a 2" pipe is only 0.03" plastic rod, that is not so easy to do as it sounds. The problem with the blending plant, is I have to guess at quite a bit of the piping, as:
1. it was a full refinery once, and almost all piping, used or abandoned, is still in place making for a very cluttered scene.
2. since 9/11/2001, they refuse to let non-essential personnel in to look around. They even chased me away when I was taking pictures from a public road.
3. Google maps/earth blurs certain areas of the plant for the same reason as in 2, is basically worthless when viewed from above, and "street view" is from a public road, which means certain areas are not visible in "street view".
My train layout is going to take some time to finish in the area of the blending plant.
Thanks for the return response. Have fun building your drilling rig.
04/06/2016 12:03 PM
Could you approach the blending plant execs, explain your purpose, and maybe even be given a tour?
04/06/2016 1:56 PM
That's a murky area for me to go. The company I work for builds process skids for the refinery that owns this blending plant. Not sure I want to try that route. Don't want them to think I'm expecting something just because we work for them.
Best not to go there. If I didn't work where I do, I'd give it a try. Thanks.
Maybe I should model another plant -there's two within 30 miles that we don't work for.
04/06/2016 2:23 PM
Speaking as a former "higher up" in a technical company, if a trusted supplier asked for a tour of my plant and explained why, I'd assign someone they worked with to show them around.
I'd think of it as a partnership building exercise.
As long as no intellectual property or trade secrets were disclosed in your model, I'd have no problem letting you in.
04/06/2016 3:49 PM
Thank you for your suggestion.
Let's drop this now - I'm getting more posts than the OP. That doesn't seem right.
04/06/2016 3:00 PM
You wouldn't have to play any cards; just be Joe Q. Citizen, and don't mention any other connections.
04/06/2016 3:51 PM
Let's drop this now - I'm getting more replies than the OP. don't want to step on his gig.
04/06/2016 5:57 PM
Maybe they: Download our general folder here - Shipyard De Donge would send some information.
04/07/2016 1:47 AM
Thank you Lyn - this is the best result so far! It answer the fundamental question - yes the drill towers move. I will follow up with the company and see if they are willing to help. Hopefully some pictures of my Meccano version will start emerging - ont of these days.
04/07/2016 9:50 AM
Good luck!
04/07/2016 9:34 PM
Nice find..
04/07/2016 9:48 PM
Thanks.
Register to Reply 34 comments
abotha (4); Anonymous Poster (1); BestInShow (1); gringogreg (1); HeHound (2); IdeaSmith (1); jhhassociates (1); lyn (5); Peterpipper (1); Phys (5); Rixter (1); SolarEagle (5); Stuart21 (1); Tornado (5)
