Previous in Forum: How to Specify Ambient Conditions For Power Plant.   Next in Forum: Air Compressor
17 comments
Pump Selection
05/13/2016 8:24 AM
hi,
please can any suggest me which pump i should buy, as its suction height is 55 feet and delivery 200 feet length and 32 feet height, i has to suck water from bore. its suction pipe dia is 1.5 inches and its delivery is 1 inch. i have tried two donkey pumps of 2hp but those two went out of order,their motor amperes were increasing. please suggest.
Re: pump selection
05/13/2016 8:34 AM
Impossible!
You can't "suck" water more than atmospheric pressure.
Atmospheric pressure will only push a column of water up about 33 feet. So suction height must be less than that.
A pump can generate more than one atmosphere pressure, so it will push to 55 feet no problem.
You need the pump at the bottom of the bore hole.
Reply Good Answer (Score 4)
Re: pump selection
05/13/2016 9:25 AM
I see a problem here. OP says "its suction pipe dia is 1.5 inches".
Re: pump selection
05/13/2016 1:34 PM
I agree with everyone so far (1) the pump has to be a submersible pump, or a pump with a very long shaft to the bottom (well pumps used to have these in many irrigation applications, but oil had to be supplied to the well shaft bearings as a drip.
The 1-1/2" diameter "suction" pipe is a bit narrow. You might have to go with something like a windmill water pump (uses a gear motor on a horizontal shaft wind turbine), the gear motor output has sucker rods (with leather seals, or could be rubber flap seals) that are mounted on the output wheel, resulting in sucker rod motion up and down cyclic. The water is actually pushed into succeeding sections of sealed off sucker rod during the down stroke, while the seals block off return flow during the up stroke.
Re: pump selection
05/14/2016 1:10 AM
yes it was mistake 1.5 inches dia pipe while carrying bore now it will be better to use submersible pump
Re: pump selection
05/14/2016 1:08 AM
well we have done this too and even though it is not working so submersible pump looks good solution.
Re: Pump Selection
05/13/2016 9:52 AM
Here some companies
flexcon
Pentair
Amtrol
A.O Smith, American Granby, Bake manufacturing, Boshart industries, Campbell manufacturing, Merrill Manufacturing, Simmons Manufacturing and Royer Quality casting
Email me
CR4 ADMIN - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Re: Pump Selection
05/13/2016 10:48 AM
As well as running contrary to the CR4 Rules it is highly inadvisable to use an email address in this forum. Spambots very quickly harvest email addresses and bombard them with adverts for personal appliances and services, etc., as well as schemes to get money out of Nigeria, rendering the address pretty-well useless.
Re: Pump Selection
05/16/2016 9:18 AM
Funny you should mention that, years ago, on an e-mail address I no longer use, I got a Nigerian Prince scam e-mail, and from reading it over (I was bored), it looked like it was the original text. At first I had a moment of - elation, appreciation?- what ever that sense of joy and wonder is called when you're viewing a Museum antiquity, then I realized that the sender was just too lazy to do more than change the 'contact info' to an account he had access to, so I deleted it.
Re: Pump Selection
05/13/2016 10:54 AM
The scheme needs reconsideration as #1 above is correct. There is no prospect of achieving 55ft lift as the pump will not prime, so the donkey pumps under trial will have failed due to no suction lift being available to enable them to be wetted. The installation as it stands is a non-starter.
Place a submersible pump at the bottom of the pipe instead, and displace the donkey pumps. Google "submersible pumps" in the first instance, narrowing-down the selection using details of the lift and flowrate required, what is available locally, access down the bore, power supply available locally, any spares compatibility, maintenance arrangements, what the bloke down the road says about them, etc., etc.
Good Answers: 92
Re: Pump Selection
05/13/2016 11:40 AM
If you literally only have a 1.5" well casing that is 55' to the water level, then you have 3 choices.
1- find a downhole (submersible) pump that will fit down that casing
2- use a jet pump or similar with a packing educator sized for 1.5" casing (if you can get it)
3- redrill to a bigger casing
If the casing is larger, find something that will work in that size. No matter what, if the water table is more than about 20' down you have to have a system that will push rather than pull the water up the bore regardless of where the pump situated.
Re: Pump Selection
05/13/2016 12:09 PM
Unless I missed something, I don't believe its the casing that's 1.5", its the suction pipe that's 1.5" diameter.
One other alternate, is to run a PVC line down there, with a check valve and use a pump jack. It would initially have to get primed.
Re: Pump Selection
05/13/2016 12:26 PM
Maximum suction height is about 25' at sea level....best to keep it as low as possible for efficiency....
Deep well pump
Re: Pump Selection
05/13/2016 1:44 PM
The pump you linked to is 1.25" suction size, how is that going to fit inside the well bore on the OP's well?
Re: Pump Selection
05/14/2016 1:26 PM
The outlet pipe is 1/1/2 inch,but the pump wont go inside of a 1 1/2 inch pipe.
Re: Pump Selection
05/13/2016 1:47 PM
Go back to the donkey pumps, as that is about all you will find to fit down the narrow well casing/suction tube. These pumps lift by forcing the water up into the pipe string.
Go over your donkey pumps - replace any worn out parts, parts that are attempting to seize up due to lack of lubrication and maintenance, and replace old dried up bearings that are rusty. Then put a motor on the pumps each that has a 2.5 HP rating, and you will be pumping water again.
Re: Pump Selection
05/13/2016 1:52 PM
Perhaps a diagram would help.....? What is your required GPM delivery...?
Is this the type pump you are using....?
https://en.wikipedia.org/wiki/Pumpjack
Reply Score 2 for Off Topic
Re: Pump Selection
05/14/2016 1:22 PM
You can use a packer jet kit with a regular shallow well pump.
The flow rate is very low for the HP used,but it is better than nothing.
This has a 1 inch diameter tube inside of the 1 1/2 inch pipe.
The kit has special turned couplings with a smaller O.D.
The two pipes are joined at the top with a flange at the pump,and a jet at the bottom in a special fitting containing the venturi and jet.
Been 30 years since I have seen one,and I am not sure if they are still available.
Reply to Forum Thread 17 comments
adreasler (1); Anonymous Poster (2); HiTekRedNek (2); James Stewart (3); JNB (1); lyn (1); MWills (1); phoenix911 (1); PWSlack (2); SolarEagle (2); user-deleted-1105 (1)
