Previous in Forum: Alfa Romeo 4C Spider vs Tesla Model X (Towing an Alfa Romeo 4C Spider)   Next in Forum: Can a UHF RFID Reader Sound an Alarm When the RFID Tag is Out of Distance?
34 comments
What Is It?
05/27/2016 12:01 PM
Hobbies - Fishing - New Member but not a new fisherman Hobbies - Target Shooting - New Member
Location: Formerly from NJ USA Planet Earth. Relocated to Space Coast FL
Re: what is it?
05/27/2016 12:15 PM
Microscopic view of some kind of crystallized metal maybe from chip or semiconductor manufacturing.
If you understand no explaination is necessary. If you don't understand no explaination is possible.
Re: what is it?
05/27/2016 12:59 PM
not even close
Re: what is it?
05/27/2016 12:28 PM
That last slice of bread, left for too long lingering on the back of the shelf....
Re: what is it?
05/27/2016 1:21 PM
Those new insoles you just got....
Re: what is it?
05/27/2016 2:27 PM
It appears to be a cross-sectional view of an RO membrane, a polyamide thin-film composite one, with the 0.25 μm permeation layer at the top, the cross-section showing the membrane support layer that is highly porous to transport water to the permeate envelope.
Re: what is it?
05/27/2016 2:32 PM
filtration isn't involved
Re: what is it?
05/27/2016 2:34 PM
here's a hint
Re: what is it?
05/27/2016 3:16 PM
Nice hint. So it's a rose petal, huh? No orderly structure, so I assume it is actually the aerogel.
Re: what is it?
05/27/2016 3:57 PM
aerogel has crazy properties but is just sooooooo brittle
Re: what is it?
05/27/2016 3:21 PM
Space Shuttle heat shield.
Re: what is it?
05/27/2016 3:46 PM
Graphene aerogel!
Re: what is it?
05/27/2016 3:55 PM
nope
Re: what is it?
05/27/2016 3:56 PM
you might have been in the neighborhood
Good Answers: 25
Re: what is it?
05/28/2016 12:50 AM
Sham-wow?
Re: what is it?
05/28/2016 1:04 PM
Super absorbent makes you say WOW!
Good Answers: 266
Re: what is it?
05/27/2016 3:47 PM
Tea tree oil will work wonders on that toenail fungus you have.
Re: what is it?
05/27/2016 4:33 PM
Aerogel was discovered in the 1930's but has never really been of much use due to cost and how delicate it is. several scientists for years have been trying to expand on the initial discovery and lower the cost and usability. the yellow material I posted is a polymer aerogel with the same insulating resistance to heat flow as 25mm of foam insulation while still being playable
http://www.gizmag.com/polymer-aerogel-stronger-flexible-nasa/23955/pictures
Good Answers: 25
Re: what is it?
05/28/2016 12:49 AM
Aerogel is one of the "secrets" of thermonuclear weapons.
Re: what is it?
05/28/2016 1:44 AM
playable pliable
Re: what is it?
05/28/2016 7:48 AM
don't trust spell check, it will make you sound foolish
Re: what is it?
05/28/2016 8:58 AM
Right. If your typo makes a real word, spell check remains happy. It doesn't like proper names. This means: in addition to spell check, you have to read your stuff to check for the meaning you wanted and things like to/too, in/on, etc, etc . . . .
Some people on here apparently don't believe in spell check nor reading!
Lehman57
Re: what is it?
05/28/2016 9:08 AM
it really can change what you thought you wrote
Re: what is it?
05/28/2016 11:09 AM
It's not the spell check!
Re: what is it?
05/31/2016 8:07 AM
Where can I get some of this polymer aerogel? I am setting up calorimetry on my fusion reactor, and I need to not miss even one 0.1 BTU, J, or calorie. (not converting units, obviously).
Re: what is it?
05/31/2016 8:51 AM
www.aerogel.org/?p=1058
Re: what is it?
05/28/2016 3:19 AM
Water Buffalo horn!
Re: what is it?
05/28/2016 11:56 PM
Water taxi...
Good Answers: 181
Re: what is it?
05/28/2016 5:18 AM
Lichen
Re: what is it?
05/28/2016 11:27 AM
Bone
Re: what is it?
05/28/2016 2:38 PM
quie similar in appearance but aerogel is a manmade material
Re: what is it?
05/28/2016 2:43 PM
NOT using spell checker can make you look foolish, too!
Re: what is it?
05/28/2016 2:46 PM
I had actually spelled it correctly then in a hurry, quickly agreed to the change and wound up with PLAY
Re: what is it?
05/28/2016 2:59 PM
That was my guess before I scrolled down to read the posts! I didn't want to spoil the surprise.
Re: What Is It?
05/29/2016 7:54 AM
The last thing a bug sees when he impacts the windshield at 70 MPH.
Register to Reply 34 comments
Deefburger (2); ed fuzzyE kedz (1); Ed Watts (2); Fredski (12); HiTekRedNek (1); James Stewart (3); Lehman57 (1); lyn (3); Mikerho (2); ozzb (1); SolarEagle (4); TonyS (1); user-deleted-1105 (1)
