Previous in Forum: drainage   Next in Forum: Real Life problems thru technology !
Location: South Range of Michigan's U.P. or known as da U.P.
“ANTENNA QUESTIONS!”
08/05/2007 10:49 AM
8/5/07
Dear Whomever,
Hello, I have been trying to locate a telescoping antenna with screw shaped ridges on the interior as well as the exterior surface of it. I haven't been able to locate one so I could continue with my research. Have you ever seen one of those or simply a device that has my particular styles on it?
I really appreciate the time that you spent answering my question and I am eagerly waiting for your response.
Sincerely, Louie
ldepuydt@charter.net
Good Answers: 12
Re: “ANTENNA QUESTIONS!”
08/06/2007 3:03 AM
What sort of frequency are we talking about? It sounds like you want to tune the antenna to a specific frequency, but is it 1.5 MHz or 1.5 GHz?? There is only about 1000 to 1 difference.
Tell us more about the application.
Sincerely
Bill
08/06/2007 7:40 AM
High Sierra makes antennas for the amateur radio community that will tune 3.5-50 MHz range. One will need an additional coil to go down to the 1.8MHz range. They have a 12vdc motor which moves the antenna up and down to tune on your desired frequency. I use one on my car and talk around the world going down the road. Their concept might help you with your needs. Here is a link: http://www.hamcq.com/index.php
Hobbies - HAM Radio - New Member Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member
08/06/2007 12:29 PM
GERARD18,
Your question is very vague. What is available depends to a great extent on what your parameters are for length, extended and collapsed, how many sections, whether each section should tapered or be straight, etc.
Also, do you require that the telescoping action be done by hand or remotely by electric or other power source?
Also, please explain your "screw shaped ridges". A sketch would be nice. Bit-map images and photos (JPEG) may be uploaded using the camera icon in the toolbar of the reply box. If you wish only to raise one section above another for tuning by changing the effective coil length, then the High Sierra antenna mentioned above (a so-called "screwdriver antenna" design) would work very well for HF frequencies, but is not very efficient, since it is a coil-loaded design.
Please bear in mind that a true telescoping pole, tube, whatever, must, by definition, have all sections collapse inside one. Therefore each section must be smaller than the last, and having both inside and outside threads requires a much thicker wall. A better alternative, for manual operation, is to have a spring loaded pin at the bottom of each section, with a matching hole near the top of the section below it. This allows a positive lock to support the weight of the higher sections. Some poles rely simply on the friction fit between tapered sections, or a locking nut over threads at the top of each section which creates friction by tightening the slotted end.
There are really many choices.
"What, me worry?" Alfred E. Neuman
08/06/2007 7:38 PM
What is the application for your antenna?
Almost every automobile on the road has an automated telescoping radio antenna. Not sure about the screw shaped ridges -- what is the purpose of them?
Register to Reply 4 comments
Rotag1 (1); Sciesis2 (1); STL Engineer (1); user-deleted-5 (1)
