Previous in Forum: Windows 10   Next in Forum: Just When You Think You Seen or Heard it All
18 comments
What is it...erm, What is it Called?
07/19/2016 2:39 PM
I have seen them on many products, but no idea what they are called or where to find one :-/
I need the little round plastic semi cylinder bit on the end so I can bolt my pole onto a part.
Drew K
Re: What is it...erm, what is it called?
07/19/2016 2:42 PM
Are you looking for a ferrule?
07/19/2016 3:03 PM
No, those go on the inside. this is the plastic bit on the outside...but the design has already been denied as too cumbersome and bad because it sticks out from the profile of the pipe.
Drew K
07/19/2016 3:14 PM
Stages of ferrule installation on billiard cue.
Cable ferrules
07/19/2016 3:40 PM
I sit corrected. I always thought the copper compression bits here were ferrules.
Drew K
07/20/2016 5:39 AM
I've always known those as olives.
07/20/2016 12:01 PM
In highly technical, sophisticated, scientific parlance, those are ''tubes''...
Re: What is it...erm, What is it Called?
07/19/2016 3:46 PM
Barrel nut?
What is a semi cylinder bit?
07/19/2016 3:53 PM
If you did a larger sketch of what you're looking for, then saved the image as a jgp file, you can use google images to do a search for matching images and you'll likely find the name of the part and a source for it as well.
When you go do google images, there is a camera icon that lets you load a file from your computer, and it will search for images that more-or-less match.
07/19/2016 4:20 PM
I might try that next time...if they like my design improvement change.
Drew K
07/19/2016 5:04 PM
What's a jgp file?
07/19/2016 5:47 PM
It's the tyep of fiel my caemra takes when my figners get twisted.
07/19/2016 4:50 PM
07/20/2016 11:56 AM
Good Answers: 94
07/20/2016 5:57 PM
Can't see very well from the illustration as it is too small but, if you're joining something tubular to a flat part, you might need a saddle washer.
07/21/2016 4:48 PM
Bingo! that is the part I was thinking of.
You are right, I should have zoomed in closer to show in the picture better.
Drew K
<Someone please give him another GA for this>
07/21/2016 8:25 PM
i'm glad you asked the question. I have several of these that i saved when old wheelchairs were dismantled, but i have not known what they are called. I too, could not buy new ones because i didn't know what they were called. I could, however, make them if i really needed to. I gave a GA to NIGH. Jim
Good Answers: 123
07/22/2016 10:44 PM
Drew, for what its worth, After 40 plus years wrenching, the only ferrels I was aware of were variations of what you posted. I have seen saddle washers in MSC direct I think.
Bob
07/21/2016 8:28 PM
Thanks for the link. Very useful company for the small bits i often hunt around my screw buckets for. Jim
Register to Reply 18 comments
bob c (1); DodgySolenoid (1); Doorman (2); Drew K (4); JIMRAT (2); lyn (1); Mikerho (1); MR. Guest (1); Nigh (1); SolarEagle (2); Usbport (2)
