Previous in Forum: Software To Read The Data On RS232 (DB9) Port of PC   Next in Forum: Electric Arc Furnace Transformer
Electrical Heater
07/21/2016 2:13 AM
Please suggest which better option air heater in oven for safety fuses or MCCB?
Re: Electrical Heater
07/21/2016 2:26 AM
There may be small (dis)advantages either way as to safety, but cost and convenience will probably weigh more.
07/21/2016 2:40 AM
Probably should have both, and an over temperature safety cut-out...
07/21/2016 6:47 AM
MCCB can be a convenience.
07/21/2016 9:21 AM
In the "bad old days" the fuses had an advantage over the breakers when it came to short circuit current interruption, but not anymore. We've switched to breakers for anything that might need to be shut off occasionally for testing/maintenance. They cost more, but the switching capability is far easier than pulling fuses.
Good Answers: 804
07/21/2016 8:30 PM
Depends on a number of factors not in evidence. For example if the available fault current is higher than what the MCCB is rated for, fuses may be the only option. There are other issues beside just that.
JRaef (1); Mr. small (1); Phys (1); SolarEagle (1); Tornado (1)
