Previous in Forum: VCB Closing and Opening Coil Inrush   Next in Forum: Low Voltage on a Motor
API Bubbles
08/07/2016 7:15 PM
I have been digging around for a few days looking for the API documentation that explains how to determine the area or bubble zone for Class 1 Div II rating. No luck so far. Is it 5'- 10'? I have a 3R disconnect panel near a oil pump and motor and need to know what the distance should be for separation. Thanks
deanpavil
Re: API bubbles
08/07/2016 7:45 PM
Not sure about your part of the world but the information on zone determination is generally found in a purchased standard (for example for us it would be IEC 60079.10 - Classification of Areas - Explosive Gas Atmospheres) and zone areas specified by the applicable project contractors (NOT the equipment supplier).
If you are just an equipment supplier then this is not your job and you should be contacting the customer or their consultant to provide this information for you.
Have you tried a search of the standards websites? Due to the specialist nature of zone determination you will likely need to buy the applicable standard(s) to assist in guiding you through the process (I doubt it will just give you a distance value) if you are the one who is contracted to designate the zoning on site.
Zone selection is a bit of an application and equipment specific risk management art form.
Good Answers: 104
Re: API Bubbles
08/07/2016 8:47 PM
Try API RP500, RP505, and possibly 14F.
Re: API Bubbles
08/07/2016 11:40 PM
Re: API Bubbles
08/08/2016 6:40 AM
It depends upon the nature, the quantity and the frequency of the release.
If in doubt, consult an appropriately-qualified Chemical Engineer locally.
Re: API Bubbles
08/09/2016 6:08 AM
Are you a licensed electrical contractor in the USA?
If so, you should be able to find this in the NEC.
If you are not a licensed electrical contractor,you should not be doing this type of work.
There are many caveats involved with hazardous locations that you should be aware
of,including the sealing of conduits entering the hazardous area from a non
hazardous area,disconnecting of ALL conductors entering the area(including neutral)
at the panel,etc.,etc.
Sounds like you are in over your head.
Consult a local inspector,or a qualified electrical contractor for information.
Re: API Bubbles
08/09/2016 2:25 PM
If you know it is Class I Div.2, who determined that? Usually the determination of an area classification also includes the boundary points as well. Ask the person responsible for the classification determination where the hazard rating ends.
If you determined that yourself, I think you may be attempting something beyond your capabilities. I am sure your insurance company will have some thoughts on this.
Register to Reply 6 comments
bigg (1); HiTekRedNek (1); jack of all trades (1); Phys (1); PWSlack (1); SolarEagle (1)
