Previous in Forum: Three Phase Ungrounded Fault - Symmetrical Components   Next in Forum: Failure to Latch in on Synchronous Idle
Substation
09/12/2016 2:23 PM
Pl.define substation diameter and substation bay
Pathfinder Tags: Electrical Substation
Re: Substation
09/12/2016 2:46 PM
substation diameter is the distance across the substation from one side to the other. Hope that works for you.
Substation bay is when you leave a Beagle dog inside the fence of the substation and they sit there barking and baying all night.
Actually substation bay is probably a cabinet where the controls for a particular tie line, transformer, cap bank, etc. resides.
Re: Substation
09/12/2016 3:25 PM
Substations are rectangular, usually with a big fence with razor wire on top all around
Substation bays are smaller that the whole substation and may be open on one end.
Try a search engine.
Web search engine - Wikipedia, the free encyclopedia
Re: Substation
09/12/2016 3:36 PM
I am confused by your posts regarding substation design and construction. What is your job role exactly?
I could understand if you are just involved in procurement but why can't your own substation design Engineers and consultants answer these for you?
Jack - Substation supplier
Re: Substation
09/12/2016 3:47 PM
Invitation declined, on the basis of insufficient information.
How it is possible to get a reasonable answer to a one-sentence blog post remains a mystery.
Re: Substation
09/12/2016 4:14 PM
You would do well to heed your own advice:
CAN ANY BODY TELL THIS?
HOW MANY GEARS IN A SWITCH GEARS?
To which you replied:
"don't sent idiotic question"
Again, you would do well to heed your own advice.
Good Answers: 22
Re: Substation
09/20/2016 11:35 AM
'Bay' is a general term and refers to a feeder or a CB coupled with associated Disconnecting switches in a substation.
'Diameter' typically refers to the combination of two Main bays for individual feeders and associated Tie bay in a substation with breaker-and-half configuration.
Raghunath
Re: Substation
10/29/2016 1:02 AM
Please ask a logical question. Don't as how hot is the hot water? No one can understand your question.
Register to Reply 7 comments
jack of all trades (1); James Stewart (1); lyn (2); PWSlack (1); raghun (1); Simon Wan (1)
