Previous in Forum: Remote Control of MCCB (Molded Case Circuit Breakers)   Next in Forum: A Medical First
11 comments
Resorcinol Catalyst
10/13/2016 11:32 AM
This early 2-component waterproof glue was used effectively to build wooden-framed aircraft among countless other things. Present-day makers jealously guard control of it. I have a quantity of the resin but no catylist. Anybody know what could be used? Thanks
Pathfinder Tags: catylist glue
Re: Resorcinol catylist
10/13/2016 12:06 PM
10/13/2016 1:01 PM
Info on the glue:
https://en.wikipedia.org/wiki/Resorcinol_glue
http://www.christinedemerchant.com/adhesive-glue-resorcinol.html
Have you checked the resin to make sure it hasn't hardened? I gleaned that it doesn't have a very long shelf-life.
Talk to these suppliers:
http://www.cpadhesives.com/adhesive-solutions#resorcinol]
http://forum.woodenboat.com/showthread.php?67683-cascophen-any-info
Re: Resorcinol Catalyst
10/13/2016 3:51 PM
You could try buying some para-formaldehyde, but that is hard to come by.
paraformaldehyde
If you take formaldehyde liquid, and store it cold, the paraformaldehyde polymerization results in a white residue at the bottom of the container. Cold storage is recommended. I have no idea how long it might take to arrive at a suitable product.
Methanol (small amounts is needed to control the extent of polymerization to the number of units desired.
Personally, unless you have a tremendously large amount of the resin, I would start over with a new kit. I was not aware this was sold to individuals within the United States due to the carcinogenicity of formaldehyde decomposition product.
10/13/2016 10:24 PM
Thanks to all 3 fellows who offered info. All were helpful. In the last analysis the shelf-life proved decisive. It's much, much older than that, thu not yet hardened. Not worth the risk of failure, given what's involved. Thanks again for the help!
10/14/2016 4:23 AM
Hey, not a problem!
I used this type of adhesive when I made my hammered dulcimer. It is a great adhesive for joining tight-tolerance wood joints!
It would be interesting to know how you fare in your search for the adhesive and how you're going to use it.
Welcome to CR4!
10/14/2016 12:43 PM
A hammered Dulcimer! How cool! In the closing days of Nazi Germany they built a "flying wing" (as in today's stealth bomber) put of plywood using this glue.It as a "Horton" and was jet-powered!! Thanks for the welcome!
10/14/2016 1:41 PM
We totally rebuilt a 40' offshore catamaran, built in the 50's, with resorcinol... Sailed it for over 2 years when we had it, in some very challenging conditions (storm warnings, twice), with no delamination or failures.All marine grade plywood, and lots of glue. What a mess, if allowed to get outside of areas not intended for use, as well as leaving some marked stains on one's hands....Good stuff, if allowed to fully saturate the substrate, and to make sure of no dry contact spots due to premature absorption of the glue into the wood. Also, read about and understand the size of gaps allowed (or if one can use fillers for large gaps), and pay attention to the clamping schedule recommended.
Resorcinol Catalyst
12/24/2016 11:23 AM
Bet yer Bucket , Bob . Formaldehyde . Phenol Formaldehyde Resorcinol .
2 part , maybe . 3 part , much more likely . Resin is used as wood to wood F.A.A. Approved adhesive and is Commercially available at present. You are absulutely correct , this is a closely guarded secret . It's been one since Cleopatra had barges .
DRAGON BLOOD , the Romans called it , because it's red .
I buy mine through CHEMPOINT , an Oregon based Company . PRF Cascophen 75 LT .
Steele113
12/27/2016 11:03 AM
I wonder where the Romans sourced their chemicals to make this glue? Any links on the history of that?
01/09/2017 3:50 PM
yes, that would certainly be my question. And why the 2 or 3-part distinction. Is the phenol sometimes added before sale? Is that why shelf life can be limited to a few months or in other cases much, much longer.
01/09/2023 11:36 AM
Probably on Amazon or Alibaba.
Register to Reply 11 comments
C-Mac (1); Dragon113 (1); greasy (3); James Stewart (2); Mikerho (2); PWSlack (1); Rixter (1)
