Previous in Forum: Something That Has Puzzled Me...   Next in Forum: SpaceX Wants To Deliver The Internet Via Satellites
Critical Components of Butterfly Valve
11/17/2016 12:14 AM
I referred one journal in that, they identified seals of Butterfly valve is more critical than other components..is it true?
Re: Critical components of Butterfly valve
11/17/2016 1:15 AM
The question is silly, and perhaps generated by an elastomer salesperson.
Good Answers: 137
11/17/2016 7:14 AM
Can't add anything to that!
Re: Critical Components of Butterfly valve
11/17/2016 4:45 PM
This is true only if the Butterfly (wafer) valve is supposed to actually block flow when shut, and not just be a minor impedance. If you were referring to stem seals, it depends. You can put a depends on the stem and soak up the leaky fluid.
Does that fill you up, Buttercup?
Register to Reply 3 comments
Codemaster (1); James Stewart (1); Tornado (1)
