Previous in Forum: Monitor/Camera Advice and Recommendations   Next in Forum: Critical Components of Butterfly Valve
42 comments
Good Answers: 117
Something That Has Puzzled Me...
11/16/2016 8:30 PM
So... I take a frozen bread roll and defrost it using a microwave, it comes out of the microwave hot as if it's just baked. Nothing unusual there!
To slice it open I take a flat steel bladed kitchen knife and almost destroy the hot bread bun, as it takes a bit of pressure to cut the bread.
Yet when I take a similar bun, same temperature, just out of the microwave, and use a serrated steel bladed kitchen knife, two strokes of said knife, slices the bun (and hand if not careful) without pressure or damage or deformity of the bread.
Why?
Re: Something that has puzzled me...
11/16/2016 8:54 PM
the same reason a saw cuts a piece of wood and a razor wont
Good Answers: 117
11/16/2016 11:43 PM
I will disagree.
A saw when pushed forwards and downwards removes small parts of the material it is being used to saw/cut. It also has off-set teeth to make a slightly larger slot than the width of the saw blade to allow the blade to be moved without jamming.
The knife has no such small teeth and does not remove part of the bread.
11/16/2016 9:00 PM
Bread heated up in the microwave is usually tough and chewy, in my experience.
"It has to do with the nature of wheat starch, water content and microwaves.
When wet starch (i.e. dough) heats up (i.e. baked) it becomes partially gelatinized. That's the nice moist texture of fresh baked bread.
As the bread ages, it loses some of the moisture and the gelatinized starch starts hardening again and that is why a bread goes "stale" and hard.
When you put bread in the microwave oven, the microwaves cause the remaining water in the bread to heat up, and the warm water causes some of the hardened starches to re-gelatinized which makes the bread soft again. If you continue to heat the bread, the water in the bread starts boiling and cooking up the starch and as the starch boils it tightens up, which makes the bread feel rubbery. As you continue to heat the bread, all the water boils out of the bread, and all you left with is hardened, dried up starch. ."
https://www.quora.com/Cooking-science-why-does-bread-get-soft-then-rubbery-then-hard-after-being-microwaved
A serrated knife is more like a saw and breaks the rubbery starch.
Good Answers: 117
11/16/2016 11:47 PM
Yes bread OVERHEATED in a microwave does get all hard and rock like.. however my re-heating skills are not my question.
As the bread is soft and warm - reheated to perfection, as if it has just been baked, trying to cut it with a flat non serrated knife doesn't work, yet a serrated one does.. All I'm asking is why!
11/17/2016 6:56 AM
Maybe your knife is dull?
11/17/2016 3:01 PM
I agree. If your kitchen knife without serrated edge will not cut bread or a tomato pulling the edge against either, then it isn't sharp.
Some good kitchen knives are made tougher; more resistant to chipping, fracture. These knives don'the hold an edge as well as more brittle steel, and so should be 'steeled' before or after (or both) each uses. Steeling realigns the edge material.
The kitchen knives in most houses are dangerously dull.
11/17/2016 4:50 PM
Do you mean you normally assault fresh bread with a non-serrated blade? Oh My God, the Humanity of it all!
If I took a loaf of bread just out of my mother's baking oven (not the other one, silly person), and attempted that, she would have "mauled" me. See said so on more than one occasion and I still have the scars just from the laser hot word: "maul".
So stop mauling the bread.
11/16/2016 9:03 PM
My guess would be pressure points and a higher angle of attack. The scallops in a serrated blade create high points that concentrate the force and hence are more likely to penetrate the 'skin' of the item being cut. Then once the blade has penetrated the surface, the circular cut shapes of the serrated blade result in a higher angle between the cutting edge and the material being cut which again concentrates the forces on smaller points. A flat bladed knife is usually tangent to the surface until you get the cut started and you distribute the force across the entire contact surface.
Register to Reply Good Answer (Score 8)
Good Answers: 137
11/17/2016 3:57 AM
GA I think that's as good an explanation as any
11/17/2016 9:27 AM
Always look for the simple machines. This one is a lever or a ramp. The angle of the tooth on the blade is the key. Think of how a chisel cuts wood.
Drew K
11/17/2016 9:28 AM
11/16/2016 9:19 PM
That's why we have a set of knives that have all different shapes and sizes...
http://www.knifeart.com/plainbyjoeta.html
11/17/2016 11:52 AM
I also use a serrated blade for slicing tomatoes -- now that I think about it, the average tomato and the average bread roll are comparably soft.
So what's the deal with Santoku knives, with the odd dimple things? What's the principle behind them? Mr. Best in Show loves his.
11/17/2016 12:27 PM
Dimples break the surface tension. Similar to the groove placed in bayonets that allows you to pull it out of the body.
11/17/2016 4:53 PM
All comparisons of cheddar cheese and the bodies of enemy soldiers are against the Geneva convention!
Has anyone ever tried heating a nice dinner roll in a microwave until ignition?
11/18/2016 12:42 AM
Yes.
11/18/2016 6:59 AM
An extra long knife is missing! Reminds me of the sandwich maker who wanted a long knife so that he put three loaves of bread together and cut three slices in one go. The idea then extended to four slices at a time, but no luck in finding a knife long enough. He was advised that he might be have more success if he searched under 'cleaver' but (before Google) he trudged round the shops in vain and couldn't find any - which is not surprising because everybody knows four-loaf-cleavers are very rare indeed.
Good Answers: 137
11/18/2016 7:19 AM
Groan
11/18/2016 9:17 AM
I see you are doing your part for the "groaning" of England!
Four-loaf cleavers indeed. I suppose you have another one involving oatmeal?
11/19/2016 8:06 AM
I know I will regret asking, but what is the oatmeal connection?
11/21/2016 9:08 AM
Probably something to do with cleaving a Haggis. I am not as cleaver a wordsmith as you, so I will leave it right there on the table.
Doesn't one need a Claymore for that? On the other hand, slicing one's oatmeal rarely requires any degree of sharpness in my household. In such a case, I suppose a butter knife might work better than a steak knife.
A sidebar: I was totally shocked by the behavior of Poldark in this and last week's episodes. Kudos to Dimelza.
11/18/2016 10:23 AM
LOL!!
11/18/2016 1:11 PM
Then he started selling Razors.
Here's the commercial.
11/18/2016 7:41 PM
My design has 21 blades on a rotating drum. Motorized, of course.
11/18/2016 7:50 PM
I see.
11/18/2016 8:00 PM
I recall a cartoon of a giant shaving his face with a reel lawnmower.
11/18/2016 8:30 PM
Re: Something That Has Puzzled Me...
11/18/2016 9:57 AM
Most knife sets contain a bread knife, the bread knife is serrated.
It's a matter of pressure, a non-serrated knife spreads the down force over a much greater area. A serrated knife divides the down force over several very small points, thus the psi is higher even though the down force applied is the same.
Stated simply, the little points on the serrations poke through the crust easier and without flattening the loaf.
11/18/2016 10:10 AM
That's why bread knives are serrated.
11/18/2016 10:19 AM
Sir robin has some good answers. But it also goes further than that and it has to do with food science.
Different types of binders used such as gluten will get different effects for texture, body and aesthetics
Bread and a bun are actually different recipes, depended on what is needed. A bun has to be more robust to be able to handle juices as well as bulk such as a Hamburger.
Where bread may be used more for bulk.
Food science is pretty in depth. Which started with French chemist Louis-Camille Maillard discovering the Maillard Reaction. Which amounts to browning effects.
11/18/2016 10:26 AM
Bad link: your Maillard Reaction link.
https://en.wikipedia.org/wiki/Maillard_reaction
above link works just fine.
So that is why I hate a burned up dinner roll, whereas I would neither enjoy one without being fully
baked to its golden brown perfection. I am drooling already for my Thanksgiving dinner.
11/18/2016 10:36 AM
Dam it Jim!
you're too dam quick, I already fixed that. But here's to ya anyways.
11/18/2016 12:26 PM
Well just give that to the green-eyed goblin! It is illogical to do otherwise.
Get the away team ready, almost time to beam down for the weekend!
11/18/2016 12:38 PM
I got the away team assembled Jim..... Here's your Red Shirt.
11/18/2016 1:28 PM
Nooooooooooo....not the infamous red shirt. Isn't that the away team member that gets vaporized?
11/18/2016 1:46 PM
Its OK Jim, I'm a doctor. Just a sec.... let me turn the fan on to blow the smoke away so I can see you.
Jim, Where'd you go?
11/18/2016 1:54 PM
McCoy what in the name of Regulus are you doing? Are you playing mid-wife to the tribbles again? I know Scottie said he was giving her all he's got, but now you too?
11/18/2016 10:37 AM
I can tell you all that using a microwave for this is a huge failure.
A month ago I bought a Halogen Oven, that does bread beautifully!! and not just bread!
Jacket potatoes are fast and very tasty, as are roasts, whole chickens on a spit, Fries with either no oil or fat or just a light spray!!!
I have not exhausted its repertoire yet, but it is in use daily.
I do those partly cooked rolls for breakfast, hot (far hotter than the ones you buy and bring home!) and really tasty.....
The oven was really cheap and although it uses 1000W against the microwave's 750W, I find it far better and much faster. Depending upon rolls, between 7 and 11 minutes....
I wish I had seen them before I bought a conventional oven 10 years ago.....which uses 3KW if I remember correctly!!! and takes 5 minutes to heat up, whereas the Halogen Oven is almost instant!!
11/18/2016 10:39 AM
In the shipyard, we made an oven to heat our dinner with a industrial 200 Watt incandescent Light Bulb oven.
the slow cook even made leftover hotdogs and brats taste better.
I missed that oven...
11/18/2016 1:27 PM
I made a small test oven with a really small computer fan to circulate the air in it for ascertaining the output of my phonon cells I was fabricating...home research.
The oven use incandescent bulbs, and a light dimmer to control the setting, a bit crude but quite effective up to about 150 °C. Various wattage bulbs allowed finer tuning of the upper temperature and the ramp rate, so as to make the test series easy to evaluate. I tried using polystyrene foam - aluminum backed insulation, but found this to be inadequate at the high end, as it would tend to start to melt. Fiberfrax wool insulation works much better. I never tried warming up a hot dog in this, as (1) I didn't want the salts from the phonon cells or metals contamination in my food, and (2) I didn't want grease from food getting all over the inside of this oven to contaminate my experiments.
11/18/2016 1:43 PM
Mineral wool would work.
We didn't have insulation in ours, we just fabbed it out of aluminum, when we cam into work, for a big meal we'd put it in right away, smaller meals we put it in on our first break for lunch... It was surprisingly good,
if you had left over steak from the night before that was tough, you just wrap it in aluminium foil, and butter It was turned into a gourmet meal.
or a Brat do the same with butter... yum.
Or dried out hamburger you grilled that weekend,... heat it with butter wrapped in foil,,, wait..... maybe its has nothing to do with the oven.... maybe its the butter. ....
never mind
11/18/2016 1:53 PM
I suspect if you wrapped it in bacon the result would be as good as with butter. Everything tastes better with butter, or bacon, right?
Register to Reply 42 comments
Andy Germany (2); BestInShow (1); Brave Sir Robin (2); brich (2); Charlie Greenwood (2); Codemaster (2); Drew K (1); Fredski (2); horace40 (2); James Stewart (10); Janissaries (1); merk (1); phoenix911 (9); Rixter (1); SolarEagle (1); Tom_Consulting (1); truth is not a compromise (2)
