Previous in Forum: South Australia Power Blackout #2   Next in Forum: Marshalling Box in HV Switchyard of Power Plant
8 comments
24 Volt Charger
12/10/2016 11:35 AM
Has anyone seen a 120 VAC source battery charging unit that can charge a 24 volt system (AGM batteries), with a 10 Amp maximum charge rate and at least one switchable output for a state/alarm status? The space available is a DIN mount rail with a foot print roughly 10" x 12" inside a cabinet 4' x 4'. Thank you for your help.
deanpavil
Re: 24 volt charger
12/10/2016 11:42 AM
Globalspec has probably seen some. They're right close by, too.
Re: 24 volt charger
12/10/2016 11:42 AM
Re: 24 volt charger
12/10/2016 12:08 PM
Re: 24 volt charger
12/10/2016 2:18 PM
Thanks everyone. I was looking at Phoenix power supplys because i knew they had alarm contacts and while looking that direction all my searches came up with these huge industrial battery chargers. I couldn't see the trees for the forest. Thanks for the help. Much appreciated.
deanpavil
Re: 24 volt charger
12/11/2016 2:00 PM
Lyn, in view of your answer, it's a wonder how you can maintain your sanity.
Can I give you ga ?
Re: 24 volt charger
12/12/2016 12:28 AM
Lady Gaga can give him two.
Re: 24 Volt Charger
12/10/2016 9:27 PM
Electric wheelchairs and "Gophers" use 24v power from AGM batteries and they all come with chargers. Readily available as spare parts.
Re: 24 Volt Charger
12/10/2016 9:31 PM
These are a good brand, and compact. All 240v for OZ. Use your eBay if you want this brand.
http://www.ebay.com.au/sch/i.html?_from=R40&_trksid=p2053587.m570.l1313.TR0.TRC0.H0.Xctek+24v.TRS0&_nkw=ctek+24v&_sacat=0
Jim
Register to Reply 8 comments
deanpavil (1); JIMRAT (2); lyn (1); tonyhemet (1); Tornado (2); Usbport (1)
