Previous in Forum: What Makes TV Sports Interesting?   Next in Forum: Whatever Happened to Fluid Logic?
18 comments
Angle of the Slope for a Waste Pipe
08/16/2007 6:55 AM
I'm in the process of re-routing my waste pipe and want to know what is the angle of slope needed! I have vague memories of 6o but want to be sure! I don't want my garden or my bathroom filling with unsavory matter! can anybody clarify this angle?
Re: The angle of the dangle!
08/16/2007 6:59 AM
As a general rule, allow 1" in 10' (1:120) and it ought to be OK. Local building regulations may offer different advice/requirements. It is possible to go shallower, though not recommended for the unsavouriness that may ensue...
08/16/2007 7:15 AM
Thanks for that PW, I can carry on digging now! Or I may go to the shed and play with some radioactive stuff! I enjoyed that story too!
Good Answers: 97
08/16/2007 3:26 PM
My pipes run at 1:100. Would You suggest I lower the house by 13mm ?
Good Answers: 97
08/17/2007 3:40 AM
As a matter of fact I can't remember the slope (Done in 1970). I had to install a ski jump to keep the slope flatter.
Sloping to fast is also bad. The water tends to rush away leaving the stuff high and dry.
Good Answers: 97
08/16/2007 7:35 AM
PW - you are a spoil sport.
We could have first speculated about the diet (heavy metals or not) and moles and a lot of other interesting stuff. (heat of the meat excluded)
08/16/2007 7:57 AM
Engineering Fields - Marine Engineering - New Member United Kingdom - Member - New Member Engineering Fields - Mechanical Engineering - New Member
Re: Angle of the Slope for a Waste Pipe
08/16/2007 9:10 AM
Always best to have your bath outlet to the waste pipe uphill of your toilets this gives the unsavoury matter a bit more impitus and keeps things sweet.
Reset, Reset
08/17/2007 3:05 AM
I think that a few more details may be required here.
What is the pipe made of
What is the diameter
What is the waste - bath or foul water etc.
How many bends of what angle are there?
I use the 1 in 40 rule for most 40mm and 100mm plastic pipes without too many bends when installing bath, kitchen or foul water pipe.
If the 100mm pipe run is long and very straight and there are only a few joints - we try to use 6 metre pipe lengths, then I will go up to 1 in 80.... But no further.
The usual problem if you go flatter is a buildup of papers of various sorts on a joint or bend which is not flushed away by the water.
Hugh Mattos Chartered Engineer...... :---------: Through helping others we give purpose to our time on this earth and take pleasure from it.
08/17/2007 5:18 AM
OK you guys, you asked for it!!!
On Monday I ate for breakfast my toast with marmite washed down with a cup of coffee, then in the afternoon chicken stew, very nice! Tuesday morning, toast and marmite again, then an evening meal of prawn curry with popadums and lime pickle, mmmmm spicy! Wednesday, marmite for breakfast (fingers this time, I like to vary my diet!) and for tea, a large white flat fish, not sure of the name but it was succulent and hit the spot, Thursday, missed my marmite and had a few tomatoes instead, for tea lamb chops and chips with salad! This morning I had......wait for it.....marmite! All in all, regular and consistent, no problems with the pipes!
In my existing waste pipe system, all runs well with no back ups or blocks but, it runs through the nextdoors garden and they want to build so I have to move it! The new run is shorter with the same amount of bends (1)! It's in 125mm dia pvc tube (or pipe, depending on your persuasion) and it runs due west for aproximatly 10m then abruptly changes direction to due south and 10m later joins the main system for the town!
The main syslem is 77cm under ground, and my pipes (or tubes) start at 10cm under ground!
If you want more info, just ask!
08/20/2007 6:37 PM
tube and pipe are 2 different things regardless of my persuasion.
08/20/2007 7:03 PM
I would call it a pipe ie, waste pipe, but here in Spain it is a tubo, Spanish for tube! Strange world!
08/22/2007 6:20 PM
go figure. I'm still trying to figure out why I have a 12" ruler.
Measuring device that is, not a small king.
Here in the states tube refers to a hollow piece of material measured by it's OD whereas pipe is measured by it's ID.
This is a bit misleading as many would argue that to have accurate flow rates and or volumes monitored; a pipe (which is categorized as a vessel) would be more logical than a tube (which is considered as structural). The control feature on tubing is wall thickness for accurate content/flow analysis as well as a tightly controlled OD dim for precision joining/mating.
cr3
08/17/2007 5:45 AM
Here in the UK I would run the pipe at 1 in 80 to an inspection chamber, then out of that in the new direction to another inspection chamber on the edge of your property just before it falls at a steeper angle into the town sewer
08/17/2007 9:39 AM
Check out the Blog entry "New Wave Tech Digs Indiana Sewer" where they call out a 0.25% grade on a large project. My dad (retired industrial engineer having worked on waste management projects) said the most common mistake is to make the slope too steep on horizontal runs where the fluids drain away too easily leaving the solids in place. A more gentle slope allows the fluids to float or carry away the solids. He advised me for household plumbing to use 1/4:12 or a 2% grade or 1.2 degrees. However, as with all the advice, I would recommend you contact your local governing agency responsible for construction permits/approvals and find out what the standards are for your area. They may have to approve your work anyways. Better to know up front the requirements for your job.
Good Answers: 19
08/17/2007 9:43 AM
A good rule of thumb is 1/4" per foot . . . oh wait, all you blighters are on the wrong side of the "pond". I better convert my dimensions!
US codes will usually require 2% slope (1cm per 50cm run) for 100mm and smaller pipe, and allow 1% slope (1cm per 100cm run) over 100mm pipe. Slope is set to maintain sufficient flow velocity to carry any solids that are mixed in with the water, which is usually 2 to 3 feet per second. Our code books will have tables showing expected pipe flow capacity based on various slopes.
Good Answers: 11
08/17/2007 12:21 PM
For sewer lines I was always taught (and have used) 1/4" drop for 12" of run. Or 1:48, round to 1:50. By some magic of gravity and the surface tension of water that keeps the "solids" moving. If you can't manage that then a 45 degree drop or steeper is required.
That doesn't seem to jive with the 1:100 number I've heard, so I could make some comment about American's ... never mind.
Oh, as an American I would expect that if your sewer line is running through your neighbor's garden that there must have been some sort of agreement in the deed to the property or a right-of-way granted for the sewer line. So I would hire a lawyer and make them either pay to have it moved or build around it! How nutty is that?
Eric
08/18/2007 4:46 PM
Ask your neighbor what they are planning on growing in the garden. If it is going to be non-food plants, cut the pipe and let if flow into the garden. They will have the biggest petunias in the neighborhood!
Also (to add SOME value to this post) as a sewer system design engineer, we used 1/4" per foot as the optimum slope. 1/8" per foot is ok for larger pipes with greater flow and 3/4" per foot is the maximum. If the natural grade was greater that that, we added drop manholes to let the water free fall in the manhole to lose head.
Have you had a kindness shown? Pass it on. It was not meant for thee alone; Pass it on - Henry Burton
08/18/2007 10:01 PM
Each state and county has different codes .. best to call planning and zoning .... or whatever they call it to remain in code .... never hurts to be safe ... :)
The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair...Douglas Adams
Register to Reply 18 comments
Brave Sir Robin (1); ca1ic0cat (1); davah (1); Hendrik (3); HughMattos (2); Mr. Truman Brain (3); PWSlack (2); Ried (1); Superior Kayaker (1); TexasCharley (2); wgh71 (1)
