Previous in Forum: Nichrome Resistance Wire Globule Formation   Next in Forum: Characteristic of 16A Drop Out Fuse. Slow Type.
9 comments
Drop-Out Fuse and Fuse Link
07/18/2017 10:35 AM
Hi,
A 100 kVA 11/0.4 kV transformer will have 5.2 Amps as HT full load current. So, 5.2 amps or next higher standard rating will be drop out fuse rating. So this shall be the drop-out fuse rating or fuse link current rating?
Regards,
Re: Drop-Out Fuse and Fuse Link
07/18/2017 11:32 AM
07/18/2017 3:33 PM
100 divided by 11 was about 9.1 when I went to school.
What am I missing or don't understand?
07/18/2017 3:56 PM
its a three phase 50 Hz transformer.
07/18/2017 5:03 PM
÷ √3 ?
07/19/2017 1:35 AM
There is NO WAY anyone is getting a license for 100kVA phase imbalance in the three phase grid
Building the future!
07/19/2017 9:56 AM
A fuse is there to protect the CABLE. So, as the wiring installation detail has been withheld from the forum it would be unreasonable to expect a valid answer from it!
07/19/2017 1:31 PM
And it does protect cable by providing for interruption when the transformer attached downstream (these should usually be found on the service pole, correct?) will have a current such the range {Irf, I3} values (the in-rush and fault currents) will include the rated value of the fuse. If the fuse is outside these limits (usually I3 is about 3-6 times the in-rush) then it will be inappropriate for use, as the established arc upon failure may be able to sustain itself for an undue (indefinite) period of time.
07/20/2017 6:36 AM
It is a mystery to this reader why anyone would intentionally install a fuse assembly that is capable, on rupture, of producing a self-sustaining arc, and therefore a potential learning exercise therefrom.
07/20/2017 12:26 PM
We are speaking of those special life-learning moments when we see Jesus face-to-face, quite right?
Anonymous Poster (1); Ivanov327950 (1); James Stewart (2); PWSlack (2); Randall (1); SolarEagle (1); Tornado (1)
