Previous in Forum: Over Speed   Next in Forum: Why iPhone 5S Will Turn Off Automatically After Charging and Cannot Be Turned On
28 comments
Bus Bar Current Collect Wearing Out Quickly
07/25/2017 1:51 AM
Dear All,
I am no means a electrical guy but our current collectors on 380 v bus bar and wearing out too soon. We had replacement them 2 weeks back and now again they are completely worn out. What can be the reason. Please help us solve this issue.
Re: Bus Bar Current Collect Wearing out quicky
07/25/2017 2:07 AM
Are you talking about current transformers with an open secondary?
Reply Score 1 for Off Topic
07/25/2017 2:15 AM
No . I am talking about the powerrail for the cranes.
07/25/2017 4:51 AM
Oh. Too bad that was not described well in the first post.
07/25/2017 11:00 AM
Sounds like the current collectors were not set up in accordance with OEM guidelines.
You need to have a one-on-one, face-to-face meeting with whomever it is that services and certifies your cranes, explaining to them about what you are experiencing and why they are going to fix the problem.
If the thing was set up for a "clean" shop, and this is a smelter, or very dusty gritty environment, you probably do not have sufficient dust booting on the bus bars to prevent contamination damage.
07/25/2017 3:15 AM
What did the crane manufacturer say in response to the telephone call(s) that have been made to it on this topic?
07/25/2017 3:40 AM
There could be several reasons.....corrosive environment, overloaded, improper wiring, crane motor failing, damage to structure in some way, bad connection.....We would need good close-up pictures, ratings and current measurements, to even start....
07/25/2017 3:52 AM
...and so would the crane's manufacturer.
07/25/2017 3:53 AM
Were OEM parts installed, with warranty, or did the replacement parts "fall off the back of a lorry"?
07/25/2017 4:38 AM
It is troubling that <...no means a electrical guy...> is replacing <...current collectors on 380 v bus bar...> with all the safety implications that surround it.
One of the possible reasons that the things are wearing out quickly is installation otherwise than in accordance with the OEM's instructions. Those instructions cannot be seen from here.
07/25/2017 4:56 AM
What current are the bus bars rated at?
What current are the collectors rated at?
What current do the collectors carry: steady state and inrush?
Do the bus bars show any signs of damage/wearing out?
How long did the original collectors last?
Who manufactured the original collectors? Part numbers?
Who manufactured the replacements? Part numbers?
I am also no means an electrical guy.
07/25/2017 5:24 AM
Not sure
200 amps
Inrush
One of the lines showing a bit of damage
This is a fairly new plant May be around 6 months
Wampfler
07/25/2017 5:28 AM
Here they are. Pick up the phone!
07/25/2017 6:07 AM
Already called them before . They might visit our site next week
07/25/2017 6:12 AM
Then phone them again and convert <...might...> into "will", FFS!
  • What is the matter with people these days (rhetorical question - NNTR)?
<unsubscribes>
07/25/2017 12:00 PM
  • What is the matter with people these days (rhetorical question - NNTR)? "
Good chance that because so many use either text speak or technical abbreviations that are not universally know people have no clue what they are talking about and they ignore the advice given due to it's cryptic conveyance of anything useful.
(FFS, OMG, NNTR, STFU, LOL, WTF, FBI, SCr, HFe, CIA, NBS, PBS, MAGA, NIBY!)
07/25/2017 12:12 PM
You left out CNN, and NBC.
07/26/2017 6:39 AM
WTF...
Good Answers: 42
07/25/2017 12:39 PM
I agree with PWSlack : the manufacturer, it will be the best address. However, I think, usually the problem it is in brushes: the low pressure on the busbar- high contact resistance- or inadequate brushes.
Julius
07/25/2017 2:30 PM
Yes it could be a buildup of corrosion and carbon on the bars, possibly pitting....probably need to be cleaned....might try some conducting grease...
07/26/2017 6:41 AM
Possibly, though the forum cannot see the problem as well as the original poster, who seems to have vanished. Perhaps there are too many texts, emails and WhatsApps to send to maintain an interest here; who knows (rhetorical question - NNTR)?
Good Answers: 116
07/27/2017 11:07 AM
Look carefully PWSlack - unusually for anonymouse posters, "plckid" has emerged.
07/26/2017 8:15 AM
We have checked for corrosion but we had found of the lines colour seems to be a bit of black as compare to others. I dont know why .Also the power rails are galvanized . Just one question ,how do they align these power rails. Is there any instrument for this since the manufacture thinks the rails are not aligned and the current collectors are wearing out soon.
07/26/2017 8:31 AM
07/26/2017 9:33 AM
Nah, it is probably something in your local environment that is causing black oxide.
07/26/2017 5:47 PM
Check your spring tension, they have probably relaxed, and with poor contact, may run hotter and relax sooner.
07/27/2017 8:53 AM
Yeah, when my contacts are weak, I run hotter, and want to relax sooner also.
Good Answers: 116
07/27/2017 11:26 AM
Some thoughts.....
  1. "Rough handed" operator engages collector with too much force.
  2. Collector brought into contact with rail at start current when it should be off-load.
  3. The busbar damage should have been repaired when collector was replaced.
  4. The manufacturer will know what busbar alignment tools and methods are adequate.
  5. The manufacturer might now sell you busbar dust covers which should have been specified for your environment?
Re: Bus Bar Current Collect Wearing Out Quickly
08/04/2017 7:18 PM
Check the quality of the material. That is always the problem.
Reply to Forum Thread 28 comments
67model (2); 7anoter4 (1); Anonymous Poster (1); James Stewart (4); plckid (4); PWSlack (8); Randall (1); rwilliams (1); Simon Wan (1); SolarEagle (2); tcmtech (1); Tornado (2)
