Previous in Forum: Bus Bar Current Collect Wearing Out Quickly   Next in Forum: How to Design a Thyristor Gate Driver Circuit
18 comments
Why iPhone 5S Will Turn Off Automatically After Charging and Cannot Be Turned On
07/25/2017 4:42 AM
A Customer Use an unoriginal USB cable to charge iPhone 5S and it will turn off automatically after charging and is unresponsive when press the power button
Re: Why iPhone 5S will turn off automatically after charging and cannot be turned on
07/25/2017 4:45 AM
It is either replaceable under warranty, or it is chargeable. Go for it.
Re: Why iPhone 5S Will Turn Off Automatically After Charging And Cannot Be Turned On
07/25/2017 9:42 AM
Have them try an "original" or Apple OEM USB lighting cable and charger.
When you say "after charging" - did it actually charge, or do you mean "after removing from the charger"? Do you see a battery charging indicator when it's plugged in? Does it turn off immediately after unplugging from the charger or will it keep running for any amount of time? If it can only run while connected to power it would seem it's the battery that's at fault.
Are you able to open the phone? If so, do it, being mindful of the home button cable still attached to the motherboard which must be disconnected prior to lifting the screen away completely, along with the digitizer/lcd cables. (Guide) Look at the water damage indicators - the motherboard, the battery, or both may be damaged. Try replacing the battery. If that doesn't resolve the issue, it's probably the motherboard.
07/26/2017 3:45 AM
Good questions! (I will read further down and see what answers you get!)
My bet is that the phone was NOT charged and eventually the battery was empty and it powered down. This is also why it will not power up!!
Just guessing.....
Good Answers: 445
07/25/2017 10:41 AM
Maybe you should contact this guy.
Good Answers: 804
07/25/2017 10:57 AM
Known issue: on all iPhone 5 series, once the battery begins to degrade, it begins to display irrational behaviors around charging and battery level issues (most notably that it tells you that the battery is dead when it is fully charged or it suddenly goes from 50% to 0% while you are using it). Apple can test it for you at the Apple Store (if you have one you can get to); the test gives you a graphical representation of battery stability, and once you drop into the "red zone" you can no longer predict how it will behave. Around here, they will replace the battery for about $180, but you lose all of your data (so be sure to have it backed up first). Other than that, it might be time to upgrade.
07/25/2017 11:04 AM
Or you could just use the iphone for a fishing lure/sinker.
07/25/2017 11:47 AM
Or a door stop?
07/25/2017 12:08 PM
OOOOO! I like that idea! That one and as a gravity tester!
07/25/2017 6:30 PM
07/26/2017 9:01 AM
Gutmonarch: I have to admit that is your best post ever! That was a giant laugh riot, especially the Siri part ( she is a racist ), and the part about the fake British accent. OMG, that guy is crazy funny.
Way to go! You made my whole day! Apple is just under Windoze 10 on my sheite list.
07/26/2017 10:18 AM
And you would call it a "fish i"?
07/26/2017 1:50 PM
On my iPhone 5 a similar issue was resolved by changing the charging circuit board rather than the battery. As a bonus the non-OEM cable was found to be in perfect charging order.
07/25/2017 12:17 PM
Vipfixphone try a hard reset by holding both the power on & home buttons and wait for the Apple to appear.
07/25/2017 12:30 PM
That is the probably the first and only sane answer to be had! I have done that even on Android, except there is no "home" button, and holding down power button works in that event.
07/25/2017 1:30 PM
This is a spam post...vipfixphone sells software kits for iphones....I flushed, but this looks like a floater...haha
http://www.dhgate.com/store/product/vipfixphone-32bit-and-64bit-ipad-iphone-nand/398015768.html
07/25/2017 1:37 PM
sometimes those things just keep swimming.
07/26/2017 3:51 AM
Great topic, some good answers and some funny answers!
A further reason for me to continue to never every giving any money to Apple for anything, ever.
They make the most expensive doorstops (good one!) in many different sizes, all over priced.
07/26/2017 12:23 PM
Perform a hard reset; hold down the upper power button and the lower select button at the same time. It will reboot the entire op system.
Register to Reply 18 comments
Andy Germany (2); gutmonarch (1); James Stewart (5); JRaef (1); phph001 (1); Phys (1); PWSlack (2); RAMConsult (1); roadapple (1); SolarEagle (1); WoodwardDL (1); yamdankee (1)
