Previous in Forum: Electrical Overhead Crane   Next in Forum: Short Circuit Current Withstand Capacity
16 comments
Two 110VAC Supply in One Multicore Cable
12/11/2017 7:59 PM
Hi,
I need to run two power cables to a panel and the panel has only one hole for cable gland. The panel is certified and new holes cannot be made only with re-certification. Is it possible to run two 110 VAC power source in one multicore cable? Will this violate some rules? Thanks.
Milan
Re: Two 110VAC Supply in one Multicore Cable
12/11/2017 8:59 PM
Yes. No. You're welcome.
12/11/2017 10:09 PM
Certified? is this a hazardous area distribution panel?
Why two sources? Is this for current sharing because the conductors are too small or a source-transfer application between two different independent supplies?
Multicore cables are generally for control logic, not power. What standards are you working too, is this an American installation or somewhere else?
Please provide more information.
12/11/2017 10:19 PM
Hi Jack,
The panel is hazardous area certified for explosion proof. We need two source supplied by two UPS incase one fails there is no down time. It is not in America but we are following American standards, the panel is supplied by US company.
I have never done this before as well and am not sure if it can be done. However, if it cannot be done, could you please explain why it cannot be done? I need to convince the people who are trying to go this path to not do it. Thank you.
Milan
12/12/2017 3:51 AM
<...two UPS incase one fails...> Are these cables to be supplied from two fuses, in case one blows, then?
12/12/2017 7:35 AM
<...explosion proof...no down time....> Then the panel has to be functioning correctly before it is installed and energised, for no testing or modification will be possible once energised. That is the drawback with <...explosion proof...> equipment over other methods of achieving safety of electrical equipment in hazardous atmospheres. Incidentally, it will prove possible to install it only using non-sparking hand tools, in that case.
<...have never done this before...> If no training has been completed, then either carry out training beforehand or delegate the task to someone who has been trained. This is a specialised field and not one for the uninitiated.
Other things of note:
  • It is not possible to have humans inside ATEX hazardous area zone 1, as the facility would face enforcement and/or prosecution for non-compliance on health & safety grounds. So the panel goes either into ATEX hazardous area zone 2 or the safe area; if going into the safe area then a hazardous-area-certified unit is not required, and best dispensed with.
  • If the ATEX hazardous area zones are large, then the facility has a major materials containment problem that requires addressing immediately on health & safety, environmental and economic grounds.
6
Good Answers: 445
12/11/2017 11:45 PM
From a "best practices" standpoint, do you really want to carry your backup source in the same cable as the main supply? Typically they are brought in in separate cables/conduits/trays so that a fault or damage to one source will not impact the integrity of the other.
12/12/2017 1:14 AM
I cannot see any issue with using a multicore cable as long as it is appropriate for the power transmission, which means voltage rated, current rated, and following any other necesary standards for this application.
The only problem you may have could be that multicore cables have worse heat dissipation, so compared with single core cables, you may need higher cross section, incurring in more expensive cables and maybe some dificulties to get the multicore cable trough the core.
If it does not fit, you can use military rated cables, aa long as you can afford it!
Building the future!
Good Answers: 804
12/12/2017 1:51 AM
I don't know if any regulations applying to the US that would forbid you punching another hole in the box. Listing of a control panel has no bearing on the number of holes in it, other than the fact that all holes must have something in them, either a cable gland, conduit or a plug. But neither is there anything prohibiting you from having multiple circuits in the same cable. I have used cables with up to 42 separate circuits in the same cable.
12/12/2017 2:54 AM
Thanks guys. My management has agreed not to use multicore cable for the UPS supply and proceed with drilling holes and recertification as required by our supplier.
12/12/2017 2:59 AM
Who gets stuck paying for that?
12/12/2017 3:07 AM
Above my pay grade. LOL
12/12/2017 1:22 PM
Good. This is the best solution in this case given the information presented.
12/12/2017 3:47 AM
US codes not my space, but if that was for underground coal mining in Aus, would need re-cert for any modification to the level of seal. Any new hole = re-cert.
Re-cert testing of a modified unit usually cost more than obtaining an alternative certified unit that would suit.
Congrats for taking the conservative approach and getting the testing done.
Re: Two 110VAC Supply in One Multicore Cable
12/12/2017 2:40 PM
Interesting. Congrats on the decision to run two supplies separately, and re-certify the enclosure.
12/13/2017 8:22 AM
Not sure what you mean by "certification", but if this is a UL 508A inspected panel, the new holes, if filled by a gland with correct rating for the area, are allowed. Our in plant shop built UL 508A panels are often inspected before the holes are even made. It is also common to get UL 508A inspected panels for our process skids, built by another shop of the end customer's choosing, not our own in plant shop, with no holes. We add them as needed to run the skid wiring. UL 508A still applies to the panel.
12/13/2017 8:47 AM
http://www.cooperindustries.com/content/dam/public/crousehinds/resources/pdfs/other-pdfs/crouse-hinds-codedigest2014.pdf
Dave Oliver
Register to Reply 16 comments
daveoliver (1); Ivanov327950 (1); jack of all trades (2); James Stewart (1); JRaef (1); Just an Engineer (1); Phys (1); PWSlack (2); RaiMilan (3); RAMConsult (1); Tornado (2)
