Previous in Forum: Lifting Lug Design Loads   Next in Forum: Basics of Motorcycle Dynamics
8 comments
Crank Case Pressure Ventilation
12/13/2017 12:24 AM
IN JENBACHER GAS ENGINE JGS-620-F CURRENTLY ISSUE IS GOING ON HIGH CCP, PREMATURE BREATHER FILTERS CHOKING.
SOME TIMES CCP GOES HIGH AND SOME TIMES COME SUDDENLY LOW. I WANT TO KNOW WHY IT VARIES IF THIS GOES HIGH SHOULD REMAIN HIGH.
PLEASE PUT YOUR NECESSARY FEED BACKS.
Re: CRANK CASE PRESSURE VENTILATION
12/13/2017 12:56 AM
12/13/2017 3:38 AM
The telephone was invented to help with problems like this. So, ring the original equipment manufacturer, and ask directly. Only, DON'T SHOUT otherwise the individual the other end might get a bit annoyed and hang up without helping. CR4 readers do the same. Try and use the word "please" in the dialog, too - that always helps.
Re: Crank Case Pressure Ventilation
12/13/2017 11:26 AM
Is it running on old, broken down, oxidized oil? Are the rings worn out, and engine flooding or near flooding under certain conditions (like start-up)? Gasoline could build up in the oil enough to create vapor pressure.
Even water getting into the oil is sufficiently volatile to result in higher than normal CCP.
You could provide more information about operating conditions of your engine, but I doubt you will.
Australia - Member - New Member Pakistan - Member - New Member Engineering Fields - Automotive Engineering - New Member
12/13/2017 11:43 PM
thanks for the feed back yes you are right today we have carried out its video scope and results are not fine scuffing was found on liners and white ash was also lying on piston crown.
this is gas engine and running at 3000 kw IP reduction also being observed due to knocking so as a mechanical engr i have suggested my company to have its maintenance to chnage its power units so that problem can be solved.
be sincere to your work...
12/13/2017 1:44 PM
CHECK FOR LEAKS. IT SOUNDS LIKE YOU HAVE AN INTERMITENT LEAK.
Yes I am also yelling, I have worked next to these on a gas generation rubbish tip site and they are loud.
12/13/2017 2:06 PM
ROFLMAO!!!
12/13/2017 11:45 PM
hahahah thanks and exactly leakage is these its piston rings are worn out and we need its urgent maintanance.
12/14/2017 5:00 AM
<unsubscribes>
Reply Score 1 for Off Topic
jack of all trades (1); James Stewart (2); lyn (1); PWSlack (2); user-deleted-1071 (2)
