Previous in Forum: The H1B Visa Crunch   Next in Forum: How to Remove Deformation in End of Aluminium Pipe?
How To Create An Adjustable Co-Ordinate System in Abaqus?
01/19/2018 3:30 AM
Hello all, I have created a solid shaft inside a solid shell and fixed the shell as a BC in the first step. In the second step, I have applied load on the surface of the solid shaft which generates stress. In the third step, I want to rotate the shaft with a reference point coupled to the surface of the solid shaft as a constraint. How can i create a coordinate system and reference point which updates with the position of solid shaft after it is subjected to stress in the second step ? As there is a small clearance between the pin and shell, the pin‘s rotation centre would surely move when subjected to loads. How can i achieve rotation on such an axis which varies its position after the shaft is subjected to loads ?
Pathfinder Tags: abaqus engineering FEM Mechanical
Re: How to creare an adjustable co-ordiante system in Abaqus?
01/19/2018 4:11 AM
Well, one of the ways is to sign-up for a training course on <...Abaqus...>.
01/19/2018 4:18 AM
Thank you but not helpful. If you want to help, you can or leave it to people who would rather prefer to help.
Good Answers: 11
Re: How To Create An Adjustable Co-Ordinate System in Abaqus?
01/19/2018 8:38 AM
Being that Abaqus is a specialized software for FEA, the point is that you may first want to seek out support from them than from a broad-based engineering forum. It may be a more efficient use of your time and ours.
People Living in Competition, All I want is to have my peace of mind - Boston
01/19/2018 4:47 PM
Have you tried using spherical coordinates on this?
Register to Reply 4 comments
AverageJoe (1); James Stewart (1); PWSlack (1); srimanishreddy (1)
