Previous in Forum: Oil Seal Mfg   Next in Forum: This is an Interesting Concept
AHU/ACCU UNIT
03/05/2018 1:18 PM
This is a duty and a standby separate AHU & ACCU unit.
a) Why can't load both the units to 50% instead of operating it one as a duty and the other as a standby unit?
b) Which method produces better efficiency?
Re: AHU / ACCU UNIT
03/05/2018 2:02 PM
Aa) Because that's the way it is designed. 2*100% gives redundancy in case one of the units fails for whatever reason.
Ab) 2*100%, obviously.
Re: AHU / ACCU UNIT
03/05/2018 4:29 PM
The more fully any individual unit is loaded, the better the moisture removal.
Re: AHU / ACCU UNIT
03/05/2018 8:55 PM
It's set up this way so there is no down time when a unit needs repair....the standby unit should be tested at regular intervals....it's not about efficiency, it's about critical application...
Re: AHU / ACCU UNIT
03/06/2018 10:50 AM
The units typically run more efficiently when near rated levels. The idle unit can fail due to lack of use. I would suggest that you alternate use of the units on a regular basis as in 1 week A, then one week B and so on. It should actually extend the life of the backup unit. The only issue I would see is there is likely to be autostart controls for the backup unit and if you alternate unit operation you would also need to be able to switch the autostart controls between units as well.
Re: AHU / ACCU UNIT
03/06/2018 11:28 AM
It is sometimes of advantage to advance the "run hours" [RH] of the principal unit in advance of the backup one, so that the backup one has rather less "run hours" than the principal. That way, the unit with the longer RH can be taken down for periodic planned maintenance [PPM] as a priority over the other, with the backup accumulating more RH than usual while the other is under PPM. That way, if there is a delay with the unit under PPM for whatever reason, the other can be used in the knowledge that there are spare RH to use up before the second overtakes the one under PPM; PPM on the units can be staggered to optimise the resources available with which it is to be carried out.
Which has nothing to do with unit efficiency and everything to do with resource efficiency.
Jpfalt (1); PWSlack (2); SolarEagle (1); Tornado (1)
