Previous in Forum: Steam Turbine Rotor Eccentricity Problem   Next in Forum: Nuclear Energy in Context of Germany Withdrawing From it
10 comments
Playground Slide Support ... Please Help
04/09/2018 11:06 PM
can any one give me the solution for support for the slide..how to make..
Re: playground slide support..pls help me..
04/09/2018 11:08 PM
04/10/2018 12:35 AM
04/10/2018 2:56 AM
What - with no numerical information?
Is a quotation wanted? Why cannot someone locally do this? What country it is in would be a help! Yellow Pages?
04/10/2018 3:17 AM
04/10/2018 7:04 AM
Is that from a park or schoolyard? That looks to be fairly new, what happened to the one that came with the set?
Re: Playground Slide Support..Please Help
04/10/2018 8:29 AM
Canada - Member - New Member
04/11/2018 8:38 AM
As has been posted in many a thread,,, not enough information given to make any constructive assessment. You should be trying to find a qualified/knowlegeable person/engineer to make the assessment/design. Even they will need a lot more information that you have given and will need to evaluate the proposed installation location for soil conditions as well in order to design the proper base/footings.
Search close to home.
Never stop learning
04/11/2018 11:42 AM
Not factiously: A sawhorse set under the lower curve-exit straight junction. Style & safety it any way you want. As for material I'd recommend powder coated steel. If you want to get fancy and add lateral stability the "horse" cross-piece can be made (rolled) with slight to moderate upwards convex profile.
Re: Playground Slide Support ... Please Help
04/15/2018 3:08 AM
Looking at this in plan view, the top of the slide spirals downward for about 375º. You could drop a vertical pole down through the center of this, with maybe 4 or 5 cantilevered arms, each supporting a saddle-type clamp around the tube. Using a cone or gussets, flare out the bottom of this pole onto a base plate that can be grouted and bolted to the ground. If nicely executed, this will be simple, strong, and elegant.
04/25/2018 12:09 PM
Look at these for ideas.
www.8020.net
www.simplifiedbuilding.com
Register to Reply 10 comments
ismail623 (1); JRiversW (1); Kevin LaPaire (1); lyn (1); phoenix911 (1); PWSlack (2); SolarEagle (1); Stephen Archer (1); Tornado (1)
