Previous in Forum: diode   Next in Forum: WX Satellite inferference
Engineering Fields - Automotive Engineering - Race ya there... Engineering Fields - Mechanical Engineering - Take everything apart, and while you're in there... Engineering Fields - Manufacturing Engineering - Metal, Metal, Everywhere. United States - Member - Good ole' USA.
Need some IC Help
09/23/2007 12:01 PM
I'm disassembling a circuit to salvage the components from it and I've run across some ICs that I can't find datasheets for. The board is quite old, it came out of a copier that looks to be 20 or 30 years old.
The one I'm really curious about is a 42-pin DIP labeled "D546C 043"
I also have 5 16-pin DIPs labeled "μPA2004C"
and one 8-pin DIP labeled "C393C"
All are manufactured by NEC. If anyone could help, that'd be great. Thanks!
David
I reserve the right to be wrong, or of no help what so ever - Del The Cat
Re: Need some IC Help
09/24/2007 5:29 AM
write to NEC
Good Answers: 18
09/24/2007 11:33 AM
The uPA2004C is probably a custom processor, and the other numbers look suspiciously like they may be too. There's a chance that the 393 is a comparator, but I doubt it.
09/24/2007 4:44 PM
There are IC's checking kits available with emulation firmware/software , i don`t have idea if its going to work for those 20 to 30 year old technology, but if such data base is available for that "ancient" technology .
You can still check with board circuit layout , can identify power pin , ground pin , crystal oscillator connection , various buses etc ,may be able to identify nature of the component and its function ,i don`t think any use it can do to todays far supperior technology but curiosity is different(great) thing .
09/25/2007 5:27 AM
Hi David,
your µPA2004C is a seven channel darlington array with protection diode used for control of LED or relays. You find it at www.necel.com/nesdis/image/IC-1401.pdf. It can be replaced by other parts if no longer available.
Googling "D546C" you find suppliers of those 42pin ICs who have datasheets available if you make a request.
Regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
09/25/2007 5:30 AM
Your C393C is a normal Comparator like LM393 from National Semiconductors or equivalents from Motorola.
Uwe
Anonymous Poster (1); Bill (1); uweka (2); vikas (1)
