Previous in Forum: VFD Blower Efficiency   Next in Forum: geothermal energy
8 comments
Gear Whining Noise
10/01/2007 1:27 PM
Hi,
Gear whining noise is encountered in 5th gear of an automobile gearbox..can anyone suggest how to elliminate or reduce this problem. I read some technical papers and they suggest its the transmission error(TE) which is primarily responsible for this problem.
but can Transmission error be reduced in post design stage..? and what are the control factors which effect transmission error.
does crowning effect excess or less be responsible for gear whining?
please suggest....
best regards,
samson.
sam
Pathfinder Tags: gear whining
Re: Gear Whining Noise
10/01/2007 5:43 PM
hi Samlnt , your problem seems to be very common on most of the transmissions, there are some points that requird more details , is the transmission now on operation ? is this problem arises for most of the transmissions of the same kind or only one .that under investigation . ? would you specify what is the rpm of the input torgue?
10/01/2007 5:57 PM
The most common cause of whining in a car is the wife / girlfirend wanting to go shopping...
10/02/2007 2:53 AM
If it is not the girlfriend or wife, then go to a good transmission shop, one with a good name and get a replacement transmission with a proper guarantee from them.
Working on transmissions is not for amateur mechanics (no matter HOW good you are with engines etc) and a replacement is cheaper than wrecking it yourself and buying one from scratch!!.....
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
10/02/2007 11:01 AM
Good answer Andy.
Although I am an exceptional auto mechanic and I work on very sophisticated equipment at my company. I still will have someone else rebuild an automatic transmission.
Standard tranny's are easy.
Your best off to take Andy's avice on this one.
If necessity is the mother of invention then is laziness the mother of necessity?
10/02/2007 5:40 PM
Well put!!
Canada - Member -
10/02/2007 3:01 PM
Make sure there is enough oil in the tranny. The 5th gear is the smallest and more likely to be "above" the oil level. It happened to a friend of mine (4th & 5th gear) and a quart of oil fixed the problem.
Good luck.
Handle every stressful situation like a dog. If you can't eat it or play with it, just pee on it and walk away. - unknown.
10/03/2007 12:05 AM
yes..if it was my vehicle i would have got it replaced straightaway...i work for a automobile company an this prob is encountered in our gearboxes while testing..now what can be done to minimise the noise..
sam
Good Answers: 19
10/03/2007 4:43 PM
Try the similarity to help.
Whining noises in our high pressure 32 bar & high speed boiler furnace oil pumps are normally due to non balanced with motor. The pump shaft coupling need to be balanced with the motor shaft on a lathe. This I learnt after one pump simply "jammed" with excessive whining noise. I had replaced this pump and had not even taken payment. It jammed within 15 minutes of whining. Since I had lost the pump and my money, i had no option but to open the pump part by part then straightened it and then balanced the coupling on a lathe. No whining and happy running since 12 years. good News- Got my payment that very day.
Register to Reply 8 comments
Andy Germany (2); Anonymous Poster (2); dadima (1); double_j_b (1); ducon (1); Rick@cae (1)
