Previous in Forum: Surge Ring in HT Motors   Next in Forum: Books For Aluminium Bus Bars
13 comments
277 volt lighting
10/04/2007 7:34 AM
Can someone tell me how/if you can install a 277 volt lighting fixtures to 480 volt supply.
Re: 277 volt lighting
10/04/2007 7:43 AM
Is there a 'neutral' wire, electrically in the middle of each of the 480V phases?
10/04/2007 7:58 AM
I don't think so. There are 480V HID fixtures on the circuit now. I wanted to add fuorescent fixtures to the circuit if possible. 277 ballast are more readily availble then 480V.
Thanks
10/04/2007 8:01 AM
Then the answer is no, they can't, because of the absence of the neutral conductor.
10/04/2007 8:08 AM
So if I had a neutral wire, I would use one leg of the 480V and the neutral to get the 277V. Correct?
Thanks for the help
10/04/2007 8:17 AM
Correct.
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
10/04/2007 8:50 AM
If you need some, I've got some 480V ones in one of my skips in Basildon. Come and get them if you like. £5 each and you take them away? <Splutter>
Essex jobs for Essex yobs! <Burp>.
Location: Bolingbrook Illinois, a southwest suburb of Chicago.
10/04/2007 11:25 PM
If you want to use a wall switch, it has to be a 120 v operated relay for the 277. I'm sure the 480mis controlled by a relay already, but a separate switch would require the relay. The ground bus in your panel should be the neutral, except in the case of an isolation transformer. If ou plan on more than a single light in the circuit, then you shoould have an equal number on each phase, either 2 or 3 phases. They can share a neutral, and 3 phase will only carry harmonics, but they can be more than the neutral load, so don't push the loading.
RichH
"People find it easier to forgive you for being wrong than for being right" J K Rawlings
Good Answers: 18
10/04/2007 8:24 AM
277 line to neutral; 480 line to line. Very common. Ask an electrician.
10/04/2007 12:04 PM
Yes, It's very common! Or you could wire up a few in series! (I think that would work but I have never tried it!)
10/04/2007 11:36 PM
The 277 voltage would have to come from a three phase transformer that is connected in a 277/480 WYE connection which would give you 277 from the neutral to any of the hot legs. This is to better balance the load on the transformer.
Good Answers: 19
10/04/2007 11:53 PM
It looks like this...
http://www.patchn.com/wye.htm
India - Member - PROFESSIONAL Engineering Fields - Power Engineering - electrical planning - designing
10/05/2007 7:43 AM
provide 480 v/ 277 volt transfomrer of equal VA
nascon
10/05/2007 9:53 AM
IF you only have one circuit than I don't know of a good way.
If you have a bunch consider this;
I see this in all the data centers - They use a 480 volt 3-phase, 3-wire Primary to 277/480 Volt secondary, 3-phase, 4-wire transformer - you create a neutral. I think the smallest is a 15 kVA. The output feeds your new lighting panel. You would ground the neutral in this panel, or the transformer. This separately derived system with help you avoid building ground fault issues
Register to Reply 13 comments
4leafclovis (1); Bill (1); bubbapebi (1); dda (1); maintenance dude (2); Mr. Truman Brain (1); nascon (1); NoSciFi (1); PWSlack (3); Stinky Pete (1)
